Question about Imperial IFS40 Deep Fryer
Hi actually i have imperial ifs40 gas deep fryer,recently change the control thermostat,the pilot and thermopile is good working ,because the pilot stay on when release the knob on the gas valve,after that i have to turn the knob to ON position on gas valve,and call for burner heat by turning the control thermostate,but when i turn the control thermostate for burner to comes on,the fryer goes off totaly include pilot,could you help me please. thankyou there is no control board in this fryer,is just control thermostate ,high limit thermostate,thermopile and robertshaw millivolt gas valve. and other things could you let me know how conect all thermostate and thermopil in to the gas valve, there is 3 screw on gas valve.(TH,TH-PG,PG) thankyou
    Guru:
  • 415 Answers
This wiring diagram should help you. After ensuring all of the wiring is correct, ensure all connections are clean and tight. Make sure the thermopile is properly positioned such that the pilot flame engulfs the thermopile. Test for continuity across the High Limit terminals to ensure the switch is closed and voltage is passing through it. If you continue to experience problems, replace the gas valve.
Owner's Manual
I'll look forward to hearing back from you. :-)
Posted on Apr 28, 2010
Imperial gas fryer burner wont light
Check out the over heat is not shutting down to soon or thermostat is not opening ,
Sep 01, 2012 | Imperial IFS40 Deep Fryer
I have an imperial fryer. Pilot is on but main burners don't ignite. Pilot looks normal & thermostat clicks when turned
Number 5 is your thermopile/pilot generator. It is a pilot generator that does 2 things. It holds open the valve with a safety magnet and it operates the safety valve solenoid whenever the control stat calls for heat. Overtime they get weak and will hold the pilot but not operate the valve solenoid. I would replace that pilot generator.thermopile and party on!
Jul 30, 2012 | Imperial IFS40 Deep Fryer
How to test thermopile on Imperial IFS-40 deep fryer
Hi there.
You will be needing a dc voltmeter set at millivolt to test a thermopile.
measure the voltage across the termials of the thermopile when it is heated by the pilot flame, you should have 600 to 750 millivolt reading.
If the reading is less than 600, try cleaning it with non metal scrubbing pad and/ or try increaing the pilot flame or you have to replace it with a new one.
Try the same with your other fryers with thermopile.
You will be able to find parts at http://www.imperialrange.com
Regards.
Jul 09, 2012 | Imperial IFS40 Deep Fryer
Pilot light wont stay lighted
Hi there.
Try cleaning the thermopile (cylindrical piece of metal behind the pilot) wwith a non-metal scrubbing pad. thermopile needs the heat of pilot flame to keep the pilot flame lighted as well as burners during operation.
Kindly check also if the gas has sufficient pressure.
Regards.
Jul 05, 2012 | Imperial IFS40 Deep Fryer
Pilot light wiil not stay
Check if the gas pressure is of rated pressure as stated on unit's nameplate.
Make sure that the thermopile is free of soot or any form of dirt, a clean thermopile will absorb as much heat from pilot flame as it needs to generate small amount of voltage to energize pilot and main valve coils of the gas valve.
The pilot flame quality must be good.
Hi limit must have continuity across its terminals when tested with an ohm meter.
Regards.
Jun 19, 2011 | Imperial IFS40 Deep Fryer
Hello i have a J5 lincat fryer and the pilot stays alight but the burners won't connect (light) have replaced the thermostat and the thermo couple but still no joy any ideas on this not sure what to do...
Check if there is 500 to 750 millivolts across the thermopile wires; thermopile generates 500 to 750 millivolts if properly heated to energize pilot and main valve solenoids of the gas valve for pilot and main burner operation. If the voltage across the thermopile is good and all wiring connections are ok, I think you have to replace the gas valve.
Regards.
Jun 15, 2011 | Imperial IFS40 Deep Fryer
Hi actually i have a cifs40 deep gas fryer and recently i change the control thermostat,now when turn the pilot on ,after 15 second the pilot stay on,but when turn the control valve knob to on position...
Hi, from the above question, the problem is not with ht thermostat but with the control board. The control board fails to hold onto power when the device is heated up, that why it goes off automatically..
Take care
Apr 26, 2010 | Imperial IFS40 Deep Fryer
Imperial deep fryer IFS40 pilot lights, turn on gas valve main burners come on run for awhile then everything shuts down main and pilot. You can disconnect the thermostat and the same thing happens, main...
Hi there, it sounds like your thermopile, for the pilot, is failing during use, when this happens, the small DC voltage it generates is less than the gas valve requires to stay open, and shuts off the pilot, which shuts off the main burners. Another thing that could be happening, is the hi limit is opening prematurely, instead of shutting of the pilot at 450 deg. it now is opening at 325, or 225 or 250. Sometimes the sensing bulb gets broken where it pass's through the oil tank causing this symptom. If you temporarily bypassed the hi limit to test this also, and it still goes off, you need a thermopile. If it stays on, check your temp with a reliable thermometer, and see if it reads fairly close to your setting, if so, then you need a hi limit.
Hope that helps, and thank you.
Feb 18, 2009 | Imperial IFS40 Deep Fryer
Imperial IFS40 Deep Fryer Logo
190 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
