Question about Kenmore Elite HE4 Electric Dryer
Kenmore elite elec dryer, 110.64972300. runs no heat
10 ohms at heating element, 0 ohms at thermal fuse, thermostat + thermal cutoff. 17000 ohms on thermister at about 62 degrees.
got my full 220ac. All vents are clean and free.
if i connect each leg of the heating element to frame i get 110 on each but if I put it on both legs when its running I only get 75 vac.
what am I missing??
  • 3 more comments
  • victitious20 Apr 28, 2010
    I do thank you very much, I now see what I was doing wrong measuring the element. I just need to find out how the lever (8066120) actuates the switch. (279782). Is it automated where something is driven down from the Mot, to the actuator? or something on the belt tensioner that actuates it? If you can let me know I would greatly appreciate it.
  • victitious20 Apr 29, 2010
    I still have my issue with no heat. I traced the wire back to the heater relay, I swapped the motor relay with the heater relay and still have this issue. I can assume if the relay was bad, the motor would display issues now??? All the thermisters, cutoffs, + heater all check out with a meter.
    I found the tech sheet and followed the heater strip circuit. 2 items that i could not check was the electronic control and the centrifugal switch. but getting back to the thermister I do not have any AC here. I really hope this helps you to help me. thanks again.
  • Anonymous Mar 30, 2014
    Kenmore dryer not getting hot heating element is find change the thermal cutoff and the thermostat next to it and it's still not getting hot model 11067902792 90serial what could it be
    Kenmore dryer not getting hot I change the thermal cutoff fuse thermostat next to it and the heating element look ok it's not broken so what could it be model 11
  • Kenmore Master
  • 1,606 Answers
Pull one wire off the element and start the dryer in a heat cycle . Check power from that wire to the cabinet . Touch the meter to the terminal you pulled that wire off of , and check that voltage . You cannot get correct voltage by checking across the element . Trace the wire NOT getting 120 volts . It will either go to the timer or motor . It will lead you to the problem .
Posted on Apr 28, 2010
  • Mike Smith
    Mike Smith Apr 28, 2010
    The part numbers you have given , are the door switch actuator (lever ) , and the door switch . These are actuated by the door closing . What is your dryer doing , and I can give you a place to start diagnosing .
  • Mike Smith
    Mike Smith Apr 29, 2010
    terminal you pulled that wire off of , with the wire off, and check that voltage . Trace that wire . If it goes to the control board , replace the control board . If it goes to the motor , then replace the motor . Most likely , the control board is bad . Not sending 120 v to the element for the 240 v element requirement .
I have a Sears dryer, model # 110.87562601.
#1 reason of dryers going bad is woman's bra's....the medal sewed in the cloth itself for support comes out and goes into the small holes and hits the heating element on both sides and shorts it out...Change the heating element....It's in back of dryer.
Oct 06, 2017 | Kenmore Dryers
Electric dryer spins no heat, replaced heater element and high limit thermostat, tested thermal fuse and it does have 0 ohms, thermistor reads ~50 ohms.
in addation to checking the high limit t-stat have you checked the thermal cut off (the small t-stat) on the heater housing where the element fits into, the high limit t-stat and the thermal cut off BOTH shoud have 0 ohms (the thermal fuse is in the blower housing) the cut off is on the heater box, if you have checked those to be good, check that the heat relay on the control board is closing and sending power to the element, if not replace the control, if all above are good then the motor switch is bad and not sending power to the element(thats a built in safety feature so the dry would never heat when the motor isnt running)the element of course heats only when 240 volts ac is to the element ,120vac from the relay on control through the high limit t-stat then through the thermal cut off finally to the element and 120vac from the motor switch for a comined 240 vac
Jul 20, 2011 | Kenmore Dryers
Model No. 78932791 Kenmore Gas Dryer will not heat, and I checked the troubleshoot list. How do I inspect thermal fuse? SearsDirect doesn't have mod. #.
With a multimeter. It should ohm out at 0 on Rx1. But if your dryer is still running than it is not your thermal fuse it is one of your thermal cutoffs which should be attatched to the side of your element., or your element is bad.
Aug 21, 2010 | Kenmore Dryers
My Kenmore elite electric dryer will not heat. I
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If that’s fine then the Heating Element should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite dryer just quit heating up...is it the heating element or possibly a fuse? The lint trap had qite a bit of lint in it..maybe it just over heated and blew a fuse?
There is a thermal sensor attached to the housing of the heating element, you can check the thermal sensor by jumpering the two wires to the thermal sensor together, and then run the dryer and see if the heating element is now working, if the dryer is now heating up then replace the thermal sensor.
May 10, 2010 | Dryers
Heating problem with kenmore elite he4 electric dryer. drum turns, lent trap clean, heating element ohms ok, thermo coupler ohms ok, thermostat ohms ok, timer counting down. still no heat.
limit switch stuck open should be behind motor housing is a tight fit to get to but there are two there on the element one on vent tube the other is thermal switch recommend chang the two on the tube ck element limits should all read continuityif not reolace
Jan 26, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Model 110.96585200 No heat!
You probably have a bad thermal cut-off . This is the small thermostat , located at the top of the element housing . This " thermostat " should read infinate resistance ( no resistance ) . You can put the 2 wires togather , and see if heat comes on . pt # 3399848 . Both thermostats , should read 0 resistance . They are normally closed . The thermal cut-off , will not reset itself , if open . This is a safety t-stat , for when dryer gets too hot , and will have to be replaced .
Nov 11, 2009 | Kenmore Dryers
Kenmore elite , no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 27, 2009 | Kenmore Elite HE4 Electric Dryer
Drum turns, no heat
either the heating element or the thermal fuse very worst case would be the timer but i have all parts in stock whirlpoolpartssurplus.com
Jun 24, 2009 | Kenmore 63942 Dryer
Kenmore Dryer Model 110
If all of the components are reading ok then you need a timer. Touch your 2 leads together. 0 ohms rght. That means you have a complete circuit.If you get the 0 reading then the element must be otay. Bad timer. Take that fancy meater of yours and atttach one of them leads to the timer leg marked RH. Yank the wire off the terminal beore you test. Move the timer around. You should get the famous 0 reading along the way. If you don't then that means you have the bad timer.
Feb 04, 2009 | Kenmore 62602 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
971 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
