Question about Toshiba Satellite M55-S135 Notebook
How do you reset the CMOS - Toshiba Satellite M55-S135 Notebook
  • inoastar
    inoastar May 11, 2010
    What part of the CMOS?
  • 185 Answers
How to reset the bios
You have to open the bottom of your laptop and find a watch battery, remove it and replace I would recommend you to get a new battery now that the laptop is open; that would reset the bios so you would have to set the time and date again from the bios and then from windows
if it works for you don't forget to rate me
thx
Posted on Apr 28, 2010
Reset cmos
Removing the CMOS battery for 15 mins will reset the CMOS.
The CMOS failure most likely is caused by a flay CMOS battery. replace the CMOS battery will fix this problem.
Oct 24, 2012 | IBM ThinkPad T41 Notebook
Tip
How to reset the bios password using PC CMOS Cleaner.
Burn the PC CMOS Cleaner iso ..using ImageBurner or Nero
1.Start up
Insert PC CMOS Cleaner CD, Set BIOS to boot from CD/DVD-ROM.
The first page presents to user is : PC CMOS Cleaner is ready to run.
PC CMOS Cleaner will try to decrypt the encrypted password store in CMOS and list the possible results in the list box:
BIOS type : the type of the BIOS.
Possible passwords:
possible passwords store in current computer. The passwords are listed between '' .
3. Reset the BIOS to default state
If the possible passwords do not work. PC CMOS Cleaner will try to reset the BIOS to the default state.
This action will blank the BIOS password. You may also lose all your previous settings.
There are two choice for you:
Choice 1: Reset password (try to keep date and time)
This choice will try to reset the BIOS, but keep the date and time.
Choice 2: Reset bios (all setting will be set to default, password will be erased)
This choice will reset all data in BIOS to default state.
Please try the Choice1 before Choice2.
on Jan 12, 2011 | Microsoft Windows XP Professional
Toshiba satelite bios password recovery
On laptops there isn't an easy way to recover passwords in the BIOS. Sometimes you can reset the password. Other times, you'll have to contact the manufacturer to get it reset.
Some laptops will allow you to reset the BIOS password by pulling the CMOS battery. The CMOS battery is typically located under one of the bottom panels for access to the memory or wireless cards. Some models have the CMOS battery connected by a small wire with a clip connector, others have the CMOS battery placed directly on the motherboard with a metal retainer clip.
Here is a link to a removable CMOS battery with wires: http://www.laptopparts101.com/wp-content/uploads/2008/12/removable-cmos-battery-560x420.jpg
Here is a link to a CMOS battery that is directly on the motherboard: http://www.laptopparts101.com/wp-content/uploads/2008/12/coin-cmos-battery-560x420.jpg
On a laptop, if you unplug the power cord, remove the laptop main battery and then remove the CMOS battery - and then wait at least 5 minutes, some models will blank out the BIOS password. Not every BIOS password can be erased by removing the CMOS battery - but if you are comfortable working on the laptop parts it is worth a try.
If removing the CMOS battery doesn't fix the BIOS password, the only option left is to contact the manufacturer for a reset. (If you took your laptop to a certified technician - they would just contact the manufacturer for the reset, and then bill the time to you!)
The number to contact Toshiba is 1-800-457-7777.
Nov 19, 2011 | Toshiba Computers & Internet
Would like to reset CMOS on inspiron 6000 - will not boot up to BIOS How do I reset CMOS
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
scroll to load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart this will reset your cmos after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
cmos is located in BIOS or
you will need to remove the cmos battery for 15-30 mns this will reset your cmos
im not sure where its located on this motherboard or whether its soldered in
hope this helps
Aug 08, 2011 | Dell Inspiron 6000 Motherboard - W9259
How can i reset the cmos in my ms200 all in one computer?? it shows that my hasrd drive is not working, and it is really working in other computer
To reset the CMOS the easiest way is, remove the motherboard battery for ten minute then install it again. It will clear the CMOS. Then reset the CMOS/BIOS setup, date/ time etc. Another way to clear CMOS is, reset the CMOS Jumper in motherboard.
To detect your hard drive you can try to check by change the hard drive cables. Change the port in motherboard. Check the BIOS setup and reset it if need.
Jul 06, 2011 | HP Pavilion AllinOne MS214 185" Desktop PC...
I need to reset the CMOS Password for my acer extisia 4230
for that you need to open back cover of laptop .
Then find motherbord there.
Pull CMOS cell from motherbord for 10 minutes then refix it .
Also you can clear cmos with jumper find jumper near cmos cell named "clear CMOS " it has 3 pin
Set jumper i 2-3 position then power up 1 time then again set jumper in 1-2 position then it not ask for password.
Let me know if you need more assistance.
Thanks.
Oct 21, 2009 | Acer Extensa 5620-4020 Notebook
BIOS reset
By resetting the CMOS battery all you need to do is to teardown your laptop and have to remove and reinstall the CMOS battery. And for the replacement of the CMOS battery of your Samsung laptop just call SAmsung technical support so that they can give you the exact model of the CMOS battery and where you can have the battery. Thank you.
Oct 10, 2009 | Samsung X05 Notebook
Reset Cmos Settings for Acer Computers
There might be a jumper on your motherboard that's labelled CMOS, or reset... you just have to move the jumper to the other pin combination, power up your PC, then turn it back off and replace the jumper.
If you can't find a CMOS jumper, try unplugging your computer and removing the battery on your motherboard for a few minutes. When you turn it back on, your CMOS should reset to factory defaults.
May 07, 2009 | Computers & Internet
Resetting CMOS due to virus
You will be able to reset the cmos settings if you can enter the cmos setup during startup.
Nov 24, 2008 | Computers & Internet
Cmos password reset
Take out the CMOS battery for some time and then put it back and restart ur machine.
ur CMOS password has been reset.
Aug 19, 2008 | HP Pavilion dv2000t Notebook
Toshiba Satellite M55-S135 Notebook Logo
262 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
