Question about Frigidaire Built-In Microwave
Keypad is locked on frigadaire 2.0 microwave oven
Keypad is locked
  • Frigidaire Master
  • 9,047 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Apr 28, 2010
When I attempt to enter anything with the keypad the display says "locked". Is there some way to unlock it.
Many microwaves have children locks. Of course they are for safety reasons. they are for tricking the little kids from playing with the big people toys.
Process A
To Turn the Control Lockout Feature On or Off:
  1. Make sure the microwave oven and timer are off.
  2. Press and hold the CANCEL keypad for 3 seconds.
  3. 2 tones will sound and "LOC" or a padlock icon will be displayed (indicating the control is LOCKED).
  4. Repeat to unlock. Again, 2 tones will sound.
Process B
  2. Press and hold the START keypad for 5 seconds.
  3. 2 tones will sound and "L" will be displayed (indicating the control is LOCKED)
Hope this helps?
Jan 12, 2016 | Microwave Ovens
Is there a fuse in a frigadaire microwave
Good Afternoon Friend,
I understand that you want to know if there is a fuse in your Frigidaire microwave, model# FGMV174K. Looks like there are 2 different fuses inside your microwave. Neither are fuses like in your home's circuit breaker. There is the magnetron fuse, which controls the heating, and the monitor switch with ceramic fuse. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your microwave status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire FGMV174K Microwave Oven
How to replace humidity sensor for samsung microwave oven?
I thought I needed a sensor also ( and you might), but first try this. Remove keypad. Find ribbon connector near lower edge, Gently slide a plastic ball point pen between the 2 ribbons to gently separate them. They may feel glued together. I then used a Q-Tip with a drop of alcohol to swab between the ribbons. Then cut a small piece of paper, cardboard or plastic and slide between the separated ribbons. Re-install keypad. Problem with mine was the keypad was basically shorted out. The ribbon connectors being stuck together caused multiple errors like child lock and daylight savings errors. Hope this helps someone.
Jun 03, 2014 | Samsung SMH9187ST Microwave Oven
Touch screen displays is lit up , but will not respond by touching any of the promts. I have unpluged the unit hopeing to reset no change. unit was working fine the day before.
HELLO.
The solution is to troubleshoot the microwave as explained below.
1 Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
2 Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
3 Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
4 Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
5 Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
please let me know the outcome..
thanks.
Sep 10, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave is locked up. Says Lock on screen and cannot get it to go away after hitting Clear several times. How do I get it off "lock" status?
HELLO.
GE manufactures various models of microwaves with a range of features.
Among them is a child safety feature that allows parents to lock the keypad. Though children can still open the door, the keypad lock prevents them from starting the microwave. The lock is in the form of a keypad code that renders the buttons inactive.
* 1 Press and hold the "Clear/Off" button on the microwave's keypad.
* 2 Hold the button down for three seconds.
* 3 Wait for the "L" on the keypad's display to disappear and display the time instead, signifying that the device is no longer locked.
Willing to help solve more problem.
Thanks.
Aug 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave has power but it appears to be locked up. Any ideas?
Try unplugging the oven from the electric outlet, let it sit a few seconds, then plug it back in. This might reset the computer if it's locked up for some reason.
The oven's child-lock feature might be engaged. To turn it off, press and hold the "0" key, then press "2" and release both buttons. (From Samsung's website)
If neither of these help, the control board likely needs replacement.
Hope this helps you. Thanks for using Fixya!
Feb 10, 2010 | Samsung MW6470W/MW6471G Microwave Oven
Microwave is locked. It says "Keypad touch locked"
Hold lock button for a few seconds and it should return to normal
Apr 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave keypad is locked
Touch and hold START more
than 4 seconds. "L" will
disappear and you hear two
beeps. At this time the oven is
ready.
Jul 29, 2008 | Goldstar MV-1615 Microwave Oven
Bosch HES435U - Stove Keypad is Locked
Locking or Unlocking the oven control panel
1. Access Select Function Menu
2. Turn knob clockwise until Lock Keys is flashing
3.Touch Start. Key Pad locked is displayed.
4. To unlock keypads, touch cooking mode and hold for 5 seconds. Display will read unlocking key pad
5. When unlocked the clock will again appear in the display.
Apr 29, 2008 | Bosch HLK4525GB Convection/Microwave Oven
It's displaying "lock" and The keypad is not responding.
1. Touch the "CANCEL" pad. 2. Touch and hold the "0" (zero) pad until the word "LOCK" disappears from the display and a single beep is heard. The microwave is locked the same way. You can download a manual similar to your model here: http://tinyurl.com/vpxss
Nov 03, 2006 | Tappan TMT104E1 Microwave Oven
Frigidaire Built-In Microwave Logo
204 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
