Question about C3RS665 Remote Start Car Starter Alarm Keyless Entry System
How to install two wires from alarm brain to a four door cadillac
    New Friend:
  • 103 Answers
You will need to add diodes to the circuit.
Posted on Aug 13, 2010
HOW DO YOU UN INSTALL PRO ALARM 750
You would need to locate the alarm brain box, track down each wire and disconnect while making sure that all of the factory wires remain intact and insulated. If you are not familiar with the workings of an alarm system and vehicle wiring this may not be a diy type job. Any car audio shop should be able to do it for about an hours labor. You might be able to just unplug the brain depending in the vehicle it may not cause any issues. Just be sure to tape up the connector to prevent accidental shorts.
Aug 26, 2016 | Cars & Trucks
Why alarm only works when close to car
Poor range can be caused by a number of things. Has this problem only been occurring recently? If yes, try replacing the battery in the remote transmitter since a weak battery can be a problem. If this is a new install, bring it back to the installer to have them check it. Other possible causes can be improperly positioned antenna, the alarm brain installed too close to an electronic control unit, the alarm brain mounted to a large ground plane or a defective alarm brain.
Oct 22, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
I can not use my power door lock(no power) when i turn off ign key on 2004 lexus rx330
It could be an alarm programming issue. If you have an aftermarket alarm system check the fuses on the alarm brain, normally the brain is under your drivers dash or drivers side kick panel area, if its a factory alarm then it may be same issue or it could be a power issue with the factory alarm brain, also you may have a power door lock actuator problem, if the actuator is failing then it has to be replaced.
Jun 23, 2010 | 2004 Lexus RX 330
Alarm is armed, and I dont have a remote.I need to manually dissarm the alarm or my car will not start
Open the door, the alarm will sound , go under your dash, normally installation techs will install a kill switch or alarm override button either in the drivers side kick panel to the left of were your left foot rests or inside the fuse box panel, under the steering column or by the center column somewhere but most likely the drivers kick is the spot. So open the door and find the kill switch or override button and put the key in the ignition turn it to the on position without cranking and press or toggle the switch after you turn the key, this should override the alarm and let you start the vehicle, otherwise you have to remove the alarm main fuse from the brain and rewire your starter kill to factory so that you can start your vehicle normally again until an alarm tech corrects the alarm wiring.
Good luck my friend, hope it is helpful.
Jun 12, 2010 | 2002 Oldsmobile Alero
Have a 1998 lincoln continental that has factory alarm. but i dont have a keypad. i would like 2 disarm it, it goes off for no reason.
if its an aftermarket alarm, which im sure it is, find the brain to the aftermarket alarm and unhook it. trace the brain back from the car alarm siren hardware. it shoud b mounted somewhere under the hood. theres not a lot of available space in the engine compartment. so you should easily find the siren hardware. trace the wiring back to the brain and disconnect it. it cant be factory alarm. factory alarm only goes off when u dont use keyless remote or key to unlock a locked door or trunk. factory alarm blows horn and blinks parking lights
May 26, 2010 | 1998 Lincoln Continental
Alarm burning issues. Electrical or just a cheap alarm?
means you have a shorted wire, it keeps touching the body or a ground wire causing the door to say its open. you also more then likely have a bad door switch. check the simple things first
Jan 28, 2010 | Vehicle Parts & Accessories
Disarming chapman vehicle alarm system on 94 chrysler new yorker
If you have removed the brain, I don't see why you need to remove the rest, unless you just want it out of the car. Without the brain the wiring should cause no problems to your car unless there is a bad connection. If you need more info on how to remove the remaining alarm---
remove the siren in the engine compartment. Most everything else will probably be found under dash drivers side. If it has been installed with connectors, remove them at point of connection. If solderd cut at point of connection and use electrical tape to cover exposed wire. You will have one wire connected to the dome light circuit, one to the parking lights, one to a relay to disable the starter. Cut it out and reconnect starter wire. Led, a switch, maybe a button also-not hard but maybe not necessary?
Sep 13, 2009 | Vehicle Parts & Accessories
1995 ford escort, alarm keeps going off and car wont start
The alarm brain should not be the easy to locate if stock. Put everything as it was. The alarm brain, control, module or whatever any one wants to call it is most likely behind and under the radio possibly on the floor but in that area. That is if it is OEM if not then it should have been installed under the instrument cluster. I should be a small box probably held with zip-ties and it should have all the information, manufacturer, model and wire functions on the brain. If you think he found the right thing then have him look for the red wire that connects to it. It should have a 15amp fuse on the cable. If its taken out this will disable the alarm. What ever he found should say Security, Alarm or something like that. Not door control or anything other.
Jun 20, 2009 | 1995 Ford Escort
Intermittent arm/disarm of Python model 560XV
this "could" be a bad ground, however, usually when these units lose ground, they activate the siren at a really low level, because they are trying to ground through the siren.
I would say to check where the antenna plugs into the main unit,(brain) but honestly, in 17 years of dealing with DEI alarms, 99.9% of these problems are due to the transmitter - it may blink the LED like it is supposed to, but that doesnt gaurantee it is sending a signal. I would recommend buying a new transmitter and programing it to the brain.
Jan 15, 2009 | DEI Python 1400XP Remote Start/Keyless...
Car won't start after change battery
Your vehicle has 2 ignition wires that you can put back to factory, and start the vehicle.
The wires you are looking to put back together are PINK and DARK GREEN - and found under the D/S dash. (ignition harness - right side of steering column) They will be larger in Diameter than the others.
They were cut to install the security system. They go into the "brain" and out the other side. A relay inside the BRAIN is most likely failing.
If you no longer want the alarm installed, simply match up all of the factory colors. Use crimp-on but t-connectors for secure connection.
Let me know if you need more help.
Jan 14, 2009 | 2001 Chevrolet Monte Carlo
C3RS665 Remote Start Car Starter Alarm Keyless Entry System Logo
70 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
