Question about GE Profile JB968 Electric Kitchen Range
My display is all set to one position and none of the buttons are responsive and I can't change the clock or use the oven. I tried to turn off power to the Range for 15 min and then turned it on and it still shows all the features light up and none of the buttons are responsive.
  • 1,998 Answers
Defective touch pad depending on how old the unit is if your going to fix you might want to call a technician
Posted on Apr 28, 2010
Built-in oven-- clock unresponsive
You do not need the clock I removed it and wired the oven direct.The wires are easy to get at when the front panel is removed. If you look at the manuals on line they will guide you with the correct wires to use
Apr 06, 2014 | Zanussi ZBF360 Electric Single Oven
you have to push 2 of the buttons at the same time. usually - and + for 3 seconds. you will see the display change. good luck.
Jun 01, 2017 | Zanussi ZBF360 Electric Single Oven
I've shorted out my oven after attemtping to change the light bulb.
most ovens will not operate until you set the clock - doesnt matter what you set it to as long as it isnt 00:00
Nov 30, 2013 | Dacor Preference RSD30 Gas Kitchen Range
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
How do I set the clock
Set the clock by following these steps: a). Touch TIME pad. b). Turn rotary knob clockwise until CLOCK appears. c). Touch TIME pad. d). Turn rotary knob in either direction. The time displayed will change in 10-minute increments and indicate AM or PM. Turn the knob in the opposite direction and the display will change in one-minute increments. e). Touch TIME pad. The clock is now set. in some units there is button instead of knob in that case the clock indicating button has to be pressed . This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
Power went out. Microwave just scrolls press clock!!!!!!!!!
Did you figure this out? I am having the same problem. I see PRESS CLOCK on the control display. But none of the keys on the touch pad work. GE sucks bigtime !!
Jan 17, 2010 | GE Spacemaker JVM1540 Microwave Oven
Kitchenaid superba 27 double oven clock - can't change the time!
I went to the website:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203177060.pdf
http://www.kitchenaid.com/custserv/service.jsp
from page 8
Turn the knob to the left until a tone is heard and "time" appears in the display window. The previously set time will appear in the display window.
Continue turning the time knob in either direction until the correct time of day appears in the display window
Press the START button to begin clock operation
Nov 17, 2008 | Ovens
Burners and oven wont get hot and light wont come on
The input power is incorrect. The neutral connection may be missing
May 22, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
hutchipop@yahoo.com
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
Feb 06, 2008 | Ovens
Sony demo
Had the same problem. The display of the home cinema system kept showing "sony demo". I went to the system menu and reset all settings to factory!
Nov 20, 2007 | Sony CMT-M100MD\W CD Shelf System
GE Profile JB968 Electric Kitchen Range Logo
118 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
