Ecoquest Living Air Classic Air Purifier Logo
Posted on Apr 27, 2010
Ecoquest Living Air Classic Air Purifier has a strong chlorine smell when it is on. What can I do to fix this problem.
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Apr 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
3768
Points
12
Turn down your square footage level and it will decrease
4helpful
Model xl15 "living air" purifier, where might i
Here you go my friend...
http://alpineairproducts.com/?action=Products&Product=79&PHPSESSID=7a86f6ae93806cddc78aea015eb0c1a5
Hope this helps.... Please leave feedback for me!
3helpful
Green purifier light no longer comes on
the plates are damage you need to replace it and be careful wen it`s to much humidity because that can damage the plates,and the ligth its the uv ligth you can get parts at ecoquest
CONSTANT CRACKLING SOUND FROM CLASSIC LIVING AIR PURIFIER
Check the plates for cracks and make sure the metal contacts are making a good connection with the metal grid on the plates. Either problem will cause the crackling problem
2answers
It is not putting a good smell in my home, It smells like cigarette smoke. I have a classic air purifier, and a newer model with ultraviolet light. They both do not put a good smell, in fact the one in...
Hello, To smell like cigarettes, you would have to be smoking ? I would recommend calling the manufacturer and describing this problem to them. Somethings going on, and I would start there. I hope they can be of help to you.
Good Luck, Shastalaker7
I have an EcoQuest "Flair" purifier with a shorted grid. Does it have any value for recycling?
You might want to check into upgrading. There could be a $100 rebate when you trade-in an old purifier when you buy a new one.
Pretty good deal.
Dutch
5helpful
Looking for a manual
HI, go to www.healthylivingia.com and click on products. Halfway down the page you will find the Living Air Classic. Under the support tab you can download the manual in PDF format.
Living Air Classic Emitting awful Smoke smell
Hello DWolfS,
1) Are you still looking for a solution?
2) Are you able to trace the odor (e.g. do you see any visible signs of scorching or burning, esp. with the electronics components?
3) Unless you are an electronics technician, you won't be swapping out cooked parts from a circuitboard (and if you were, you wouldn't need my advice......(;^]). If the circuitboard is bad, it's probably more trouble than it's worth to fix.
EcoQuest Int'l, manufacturer of the Living Air, no longer provides repair or refurbishment of the Classic product, but they do offer a trade-in on a newer version. If you can't locate the dealer you purchased it from to assist you, you can likely find a dealer in the LA area (Google or Yahoo keyword search "EcoQuest Dealer, Los Angeles"), or contact EcoQuest directly aT 1-800-989-2299 or [email protected].; I'm sure they can put you in-touch with a dealer in your area.
The company website is www.ecoquestintl.com/
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance,
Jon
Top Ecoquest Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
