Question about Maytag PAV2300 Top Load Washer
LEAKS AND SQUEAKS
WASHER LEAKS DURING CYCLE. ALL CONNECTIONS TIGHT. SOMETIMES SQUEAKS DURING AGITATION CYCLE.
  • bookmack Mar 24, 2008
    how do i remove the agitator in my maytag top load.
  • BDUBYA Apr 22, 2008
    that stopped the squeak thanks a lot got the water leak while we were there
    Scholar:
  • 116 Answers
If you suspect the leak is from the main drum seal.
To remove the agitator, remove the softener cap by pulling, look inside the agitator, undo the bolt (4) with long socket extension and then lift out.
LEAKS AND SQUEAKS - 5e90500.jpg Not sure if you can see the seal ("O" ring at this point, you may need to remove the inner drum.
Isolate the supply.
Lift the top cover by inserting a flat blade approx 4" in at each side at the front to release the two top clips, top cover will lift and hinge backwards out of the way.
To remove the top ring (13) from the drum, unclip each clip around the top untill released, then remove.
to remove the inner drum (10) , unbolt (7) from the inside, lift out inner drum.
Seal (1) should be visible.
Posted on Apr 19, 2008
Maytag washer # MAV208daww squeaks on agitation cycle,when full.
How do I get corn starch into brake area? No luck with front cover off.
Posted on Feb 03, 2009
SOURCE:
Washer squeaks during agitation, both wash and rinse. also makes thumping sound for few seconds after spin cycle stops.
Hello Chris, thank you for your post!
I see that the washer on your Frigidaire laundry center is squealing during agitation. This noise could be coming from the motor or transmission and you may need to have the washer disassembled to locate which component may be causing the issue. For proper disassembly you may need to seek assistance from a professional technician. A technician will have the appropriate tools needed for complete disassembly of the washer without causing personal injury or harm to the laundry center. Hopefully this information is helpful towards your repair. -Matt
Apr 20, 2016 | Frigidaire fex831cs stacked washer&dryer...
My GE washer leaks from Hose Flood during agitation - how do I fix it?
It should be connected right next to the drain hose.
Jul 04, 2014 | GE Washing Machines
Washer leaking water during wash cycle. Does not
There is a bad seal where the tub mounting with the transmission shaft to cause the leak. It leaks when it tuns. To access this, the agitation fin need to be out so you can see the big nut holding the tube in a place with the shaft. Below this nut is a seal or gasket to prevent the water getting out of the bottom tube. Replace this then you are good . Good luck.
Apr 21, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Kenmore Elite 22982 Squeaks during agitation
I'm pretty sure what you are hearing is the outer tub sliding on the bottom frame. There are three tub wear pads located around the top of the frame between the tub and the frame. Click on this http://www.partselect.com/PartDetail.aspx?Inventory=334620&SourceCode=8 these are the parts that I think you will need. You can click on the parts select home at the top right of the page and it will take you to their home page. There you can enter your complete model number and it will bring up diagrams of your machine . Once you find these part the diagrams willshow you where these parts go. Good luck.
Nov 24, 2009 | Kenmore 22982 Top Load Washer
Whirlpool Estate etw4300sq squeaks during spin
WASHER IS FINE, SOMETIMES SQUEAKS WHEN THE TEMPERATURE CHANGES
Nov 08, 2009 | Crosley CW5000 Front Load Washer
WASHER MAKES SQUEAKS AND SOUNDS REAL LOUD DURING
it could be a split pipe but its far more likley to be the drum bearings on the way out thats why its so loud and thats also were the water is coming from as well
not a cheep repain to get done,,,
sorry for the bad news
Oct 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
Aug 31, 2008 | Maytag MAH2400A Front Load Washer
Squeaking Top Load GE Washer
I bought a new GE Washer GTWN5050MWS yesterday. From the first load it squeaked each time the tub moved back and forth (no agitator in the infusion type) It is a quick squeak and kind of resembles a cat getting it's tail under a moving rocking chair. I checked the entire owners manual and it describes several noises and not one of them describes what my new washer is doing. It does not make this sound except for when it is in the wash cycle. Spinning is quiet, and during the agitation of the rinse cycle it is a much more subdued squeak. But during the wash cycle it is not acceptable.
I called GE this morning and they told me it was normal operation for all infuser types of their washer to make this noise. Tomorrow I will be taking it back for a full refund.
We purchased this machine because our 2-year old front loading GE washer broke down (discharge pump I think) and to get it fixed usually takes a couple of weeks. We thought it might be better to have a 2nd washing machine instead of paying the laundry mat. It took a month to get the last one declared unfixable in 2008. Maybe I was wrong. But this is very bad luck to have a brand new washing machine squeak so loud out of the box.
Mar 15, 2008 | GE Profile WPRE6100G Top Load Washer
Kenmore 20903 Top Load Washer Problem: No agitation
the lid switch is fine. check wiring and motor connections.it could also be a bad timer
Dec 27, 2007 | Kenmore 22422 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
766 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
