Question about Konica Minolta Office Equipment & Supplies
My copier says code sc23-03 - Konica Minolta Office Equipment & Supplies
    Problem Solver:
  • 6 Answers
SC23-03 code is the M-2 Motor Drum. To clear PWR Off/Then ON. If it returns either the Motor or Main Board. Also check the drum it may be jammed or paper is causing it to jam.
Posted on Apr 28, 2010
2 Suggested Answers
firecontrol7
  • 6161 Answers
SOURCE: ERROR CODE SC23-03 ON A 7155 WHAT IS IT?
SC23-03 code is the M-2 Motor Drum. To clear PWR Off/Then ON. If it returns either the Motor or Main Board. Also check the drum it may be jamed or paper is causing it to jam.
Posted on Apr 07, 2010
How to clear e000067 for canon irc2880i copier
What is the meanin of error e000067 for canon irc2880i - Fixya
www.fixya.com/.../t26059344-meanin_error_e000067_canon_irc2880i
Jun 6, 2010 - Question about Canon Printers & Copiers .... How to clear e000067 for canon irc2880i copier ... How to clear error 000062 canon ir 2880i.
How to clear error 000062 canon ir 2880i - Fixya
www.fixya.com/support/t26059317-clear_error_000062_canon_ir_2880i
Jan 11, 2010 - Question about Canon Printers & Copiers. Open Question .... How to clear e000067 for canon irc2880i copier. Jan 18, 2016 ' Canon Printers & ...
Error code E000067 on canon iR3170Ci copier? - How To ...
www.howtomendit.com > Office Appliances, Photocopiers
Free repair help - error code e000067 canon ir3170ci copier. ... could anyone tell me what the error code E000067 represents and how can I clear this code.
Canon ImageRunner Error Code Reset - Question Defense
Jan 18, 2016 | Canon Office Equipment & Supplies
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
The L6 code is flashing on my copier
No you can't, it is the polygon motor not rotating. It is inside of the Laser unit. You should replace the polygon motor. The part code is RMOTN0028QSZZ. It will cost you about US$ 80
Jun 04, 2009 | Sharp AR-160 Copier
Panasonic copier DP8530 has a E4-02 code.
hi i am working on panasonic copiers.E4-02 this code shows there is some problem in fuser unit
1.pull out side fuser unit from copier
2.check it is movig easily
3.check all gears
4.check thermostate and thermistor
5.bearings and seals
6.for to reset heater codes press function, orginal size,3.F1 will display press 9 ,06(ram initialize) sub code 04 start .fuser code will bi reset.
was it helpful .not forget to rate me .MIAN AKHLAQ
May 08, 2009 | Panasonic DP-8035 Grayscale Copier
Savin 2545 copier error code sc541
Hit the yellow botton ( Reset/ CA), then 1 then 0 then7 , then hold down the (Stop) botton till the display changes... Then turn the copier "OFF" then "ON" it may clear the code. The code has to do with your fixing unit.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Copier not working
Is the copier a Minolta? If so what model there are different ways to rest code.
Feb 09, 2008 | Konica Minolta DiALTA Di200 Copier
Sharp AR-C270 Copier Error code F11
Have you tried unplugging the finisher to see if that eliminated the code? Or gives you a different F code?
Feb 08, 2008 | Sharp AR-C270 Color Copier
5020i error code E000001-0000
turn on the copier and quickly press * (with the little head around it) then 2 and 8 at the same time, then the * again... this should put you in service mode. now press copier >funtcion>clear>err>ok. now turn the copier off and back on, If the code comes back call your service local service tech.
Jan 08, 2008 | Canon imageRUNNER 5020 Copier
Changing Security Code
pleaz see the operating manual ,main code is 00000
Aug 02, 2007 | Sharp AR-M237 Copier
312 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
