Question about IBM NetVista Intel Pentium 3 1GHz / 256MB SDRAM / 30GB HDD / CD-ROM / No OS / Off-Lease Barebone De... (6578XX3)
Netvista 2.0Ghz with windows xp keeps cycling through the system start up for about 30 minutes before it successfully loads the OS.
CHANGE 9 CAPACITORS AROUND THE PROCESOR
Posted on May 27, 2010
Dell computor message on a black screen windows root \system 32\hal.dill what do I do
Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
  1. Use the Windows XP CD-ROM to start your computer.
  2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key.
  3. Select the Windows installation that you want, and then type the administrator password when prompted.
  4. Type bootcfg /rebuild, and then press ENTER.
  5. When the Windows installation is located, the following instructions are displayed: Add installation to boot list? (Yes/No/All)
    [Type Y in response to this message.]
    Enter Load Identifier:
    [This is the name of the operating system. Type Windows XP Professional or Windows XP Home Edition.]
    Enter OS Load options:
    [Leave this field blank, and then press ENTER]. After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
    After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
May 16, 2011 | Dell Microsoft Windows XP Home Edition
Tip
Windows XP Repairing
XP is a windows based operating system. XP is client OS which file format is Fat32 and NTFS. Some time for user fault, unauthorised operation, improper shutdown, viruses or any other cause may corrupt this file system and it may crash your windows also. Formatting and reloading of windows can solve your problem easily. But maybe there formatting is not possible for important data or for product key. So there repair of OS is only way to recover.
I have facing almost the same problem once. There customer have a confidential file in his system's desktop. Desktop belongs in C: drive where the OS resides. First I tried to recover the data but nothing is possible there. Then I started to repair the Widows. I insert the XP CD in DVD-Rom drive boot from it. Start the windows setup after loading files it ask for a repair (R key) I have ignore it by pressing Enter then the license agreement screen appeared. Then the OS instruct to press F8 to agree with the license and continue setup. After pressing F8 it will find the previous version of OS, if setup found any previous version then it will give you option to repair the OS again. But that day I don't get this option. It shows total disk space of C: drive have remain free space. So that there was not any file to recover the OS.
Then I go to boot the system again but formatting is not possible so after loading files at the first while the first repairing option appeared I have accept this repairing option. This option is from dos repairing option. After pressing "R" while appear the dos screen. Then press Enter to continue. Then I run the command "chkdsk" in C: drive to check the disk. After complete the disk checking and fixing the error I reboot the system again. After that I have Boot the system and after completing the whole process I choose the second repairing option. Then I got the previous version of OS and start to repair the previous OS. It now just loads the file and get started XP after booting. I got success to repair the OS and recover the data.
So it is a secure and easy process of recovery.
on Mar 12, 2011 | Computers & Internet
Tip
Upgrading Windows XP
Most users of Windows XP are using Windows XP service pack 2.
You can upgrade Windows XP service pack 2 by installing plain service pack 3.
This will upgrade and improve functionality to your current installation to Windows XP.
There are alot of versions of Windows XP Service pack 3 but i recommend downloading an official version from Microsoft's downloads center through the link below.
To after download is complete, install the file. Installation takes about 10 to 30 minutes depending on your system specifications.
If your current installation of Windows XP has too many errors, installation of service pack 3 may not be successful.
The solution to this is to reinstall your Operating System (OS) using your OS installation CD, then install Service pack 3.
How ever, OS re installation will erase all your data in your system partition so back up all your data.
To download an official copy of Windows XP service pack 3, follow this link:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en
on Jan 07, 2010 | Computers & Internet
Audio driver ibm netvista p3 1GHz for XP
Driver should be included in the XP operating system. Or anyother operating system.
Dec 23, 2010 | IBM NetVista Intel Pentium 3 1GHz / 256MB...
Problems loading OS in Gateway desktop
Normally installing the os on a different mechine, and then putting into another pc dosent work.
If the hardrive is the oringinal drive, which came with the system, and you want to install xp on, you will have to use a dos disk with fdisk on it, delete all partitions on the drive and create a new partition, then start loading windows, it will give you the option to format the drive for nt(ntfs) file system and setup windows.
If you do that and it still gives you protecting files error, you will have to take the side panel of the computer tower, unplug from the mains and take the cmos battery out for about 30 secs, put the battery back in, plug in the mains and reboot the computer, start loading windows again
Hope this helps and post back if you need further assistance.
Feb 19, 2010 | Gateway GT5220 PC Desktop
Ibm desktop cannot start windows xp But have drive windows. problem windows loading beak down.
try to install another operating system if it show the same problem means it's yours hard drive problem.
Dec 25, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
SYSTEM IS SLOW
Try running a disc cleanup and then defrag. They should be located in your control panel under the maintenance & performance tab. Doing this regularily will help keep your system running smooth. Hope this helps.
Apr 19, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
Os install problem
firstly insert windows xp disc in cd drive
then restart your system
select first boot device cd rom
you have a option i.e press any key to boot from cd, press any key
setup will start
follow the option
select the drive in which you install the windows xp
after complete these steps
system will restart
when system restart
it takes apx. 30 minute to complete the installation
Apr 10, 2009 | Computers & Internet
IBM NetVista 6790 31u - Need to reformat single HD computer.
The PC comes with a restore CD. This to reinstall or repair your OS which is a genuine copy(look for the sticker)Use te restore CD while startup and follow the instructions...........sodeep
Apr 07, 2009 | IBM NetVista PC Desktop
IBM NetVista Intel Pentium 3 1GHz / 256MB SDRAM / 30GB HDD / CD-ROM / No OS / Off-Lease Barebone De... (6578XX3) Logo
64 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
