Question about Dell 5110cn Laser Printer
Paper Jam when printing on cardstock 2nd run Dell 5110cn
I need to print twice on A5 cardstock, and I have the paper selected as "Coated Thick Side 2" for both prints, thinking that this would be the lowest heat setting. But I keep getting jams on the second run through. Any suggestions or help would be greatly appreciated.
  • Anonymous Mar 25, 2014
    Every time I go to print something, it says "paper jam" "clear paper jam and then hit select" when I do that, then it says, "out of paper. It is not out of paper. Don't know what to do or try?
    Sergeant:
  • 406 Answers
You were using this prevoiously; I mean previously it was fine. now you have problem.
Because usually this may not be the problem with a printer. This is a problem of paper. You may use duplexing if it allows you.
Posted on Mar 24, 2008
SOURCE:
With the espon TX810FW can i print on clear paper / over head projector sheets?please answer quickly it is important
You can get special overhead film for your Epson printer. It is coated for use in your printer, and has a backing sheet so the paper sensor can see that paper is loaded.
Sep 03, 2014 | Office Equipment & Supplies
I have an oki c9650 when I print on cardstock the blacks become bubbly and flake off, but only when printing on cardstock
Set it or computer, whatever you are using to cardstock, or it may be called thick,there are multiple selections depending on the media. Beacuase thick paper requires slower speed and hotter fuseing.
Sep 26, 2012 | OKI C9650HDN Led Printer
When i use card stock it acts like a paper jam,with a little help it prints fine
Make sure that you are setting the proper paper type before printing any paper other than "plain" by going into the printer's "properties/preferences". If it's thick paper, choose "thick" or "heavy" or "cardstock" in the drop-down arrow.
Unless, of course, your printer doesn't accept cardstock at all, then you're out of luck.
Hope this helps. :)
Sep 29, 2010 | Dell Office Equipment & Supplies
How to prink on cardstock on Ricoh Aficio CL2000N
To print on cardstock:
- Load the cardstock paper in the paper tray and make sure the fences are snug but not too tight.
- Press Menu.
- Scroll down to find Paper Input and select it.
- Select Paper Type.
- Select Tray 1.
- Scroll to find "cardstock" on the list and select it.
You'll also have to set your print driver for cardstock or auto select, because if the print driver shows plain paper and the printer shows cardstock paper, you'll get a mismatch error.
Aug 08, 2010 | Ricoh Aficio CL2000N Laser Printer
Paper too thick?
You will need to use the manual feed and insert the cardstock one page at a time. First look at the rear of the printer for a purple dial. Roll the dial downward. This will allow the printer to exit straight out the back of the machine. Allow enough room at the rear of the printer so the cardstock doesn't hit anything on the way out. Next look at the front of the machine at the **** just above the paper tray. You'll see an envelope icon. Align the cardstock when manual feeding one sheet at a time to the left side of the **** next to the envelope icon. When you hit "file, print" select MANUAL FEED in the print window.
The 4L will only do cardstock by one at a time in the way noted above as the feed system isn't strong enough to make the sharp bend coming out of the tray or in the back to bend it around and into the top tray.
Sep 22, 2008 | HP LaserJet 4L Printer
3010 dell color laser
Ok,
I've went around and around with the same problem (bug) and finally found a solution. Here is the deal. You have to exactly match the settings for the MPF tray in the aplication softwares to the MPF tray settings set from front panel on the printer.
I found this problem when trying to print on gloss paper. The MPF tray had to be set for "Coated 1 Side 2" in both the application and on the front of the printer.
Lets say I'm printing a Word Document. Go to file, print, select the Dell printer, then select properties, select paper tray, set paper source to MPF, set MPF settings to ""Coated 1 Side 2". Click OK.
Now do the printer setup. From the front panel on the printer.
Press Menu, press the down button to Tray Settings
Press center button to select.
Display now asks for paper type. Press center button.
Displays MPF. Press center button.
Push down button until you see Coat1 Side2
Push center button to select.
Press Menu to exit.
I only print on gloss so I have to set the MPF tray to Coated 1 Side 2. I was told this slows the feed and that is needed for coated papers. Now you could probably use another setting as long you set both the MPF tray in both the application and the control panel to match exactly.
Aug 19, 2008 | Dell 3000cn Color Laser Printer
Paper keeps jamming
To print card stock you must us the manual slot in the front of the printer and feed one at a time. Also open the back flap door so the card stock can exit out the back instead of trying to bend around for the try. That will give you the staight paper path that your thick stock needs.
Jul 08, 2008 | Brother HL 1440 Laser Printer
Printing Business Cards on Cardstock
It could be.
Part of the problem with that machine is that it has to bend the paper to get to the inkjets. If its too think it will stop running.
We use this Avery stock for printing business cards that might be a little thinner cardstock. I would look for some recommended for ink jet printers.
Jun 13, 2008 | HP Officejet 5610 All-In-One InkJet...
Choosing a paper type
Un fortunately it is often a trial and error thing. I would try all "special settings", even cardstock ect.
Mar 17, 2008 | Ricoh Aficio SP C410DN Laser Printer
Ink smudges when printing cards
If you are using cardstock you have to tell machine that you are using thick paper. Place cardstock in bypass select paper size then select thick 2 or thick 3 as paper type.
This increases trasfer charge ,increases fusing temperature ensuring image is bonded to card stock paper.
No more smudging
Jan 12, 2008 | Toshiba e-Studio 232 Black and White...
Dell 5110cn Laser Printer Logo
346 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
