A "supplemental filter" field disrupts "show slips"
While under "show slips" feature (Time and Expense Slips List), and "view by Date Range" is selected, a solid "supplemental filter" appears as one of the "selected filters) which can not be removed or deleted, and the problem is that the search result for case A would include all cases. We don't know how that "supplemental filter" is added. However, if ""view by client/case" is selected, the search results are correct...please enlighten..thanks a million. Nicolie.
Press the Windows key on your keyboard to display the taskbar if it isn't visible.The Windows key has the Windows logo on it.
Right-click the Date/Time display on the taskbar and then choose Adjust Date/Time from the shortcut menu.
The Date and Time dialog box appears.
Click the Change Date and Time button.
The Date and Time Settings dialog box appears.
Enter a new time in the Time field.
You can also use the up and down arrows next to that field to change the time.
If you wish, click on a new date in the calendar display and then click OK.
You can also change the time zone, if necessary.
Click the Change Time Zone button, choose another option from the Time Zone drop-down list, and click OK.
If you don't want your computer to adjust for Daylight Saving Time, click Change Time Zone and click the Automatically Adjust Clock for Daylight Saving Time check box to turn this feature off.
1; low level or too high ATF.
2: filter packed. do the service now.
3: low pump pressure.
4: bad clutch packs, if it slips now, it will get worse faster.
5: or any of the other vast ways to get the wrong pressure to the servos. (huge list)
the fsm covers on car check for a/T why not read that.?
every step.
You can use Microsoft official powertoy "TweakUI" to easily hide/show control panel applets.
Download TweakUI from here.(http://download.microsoft.com/download/whistler/Install/2/WXP/EN-US/TweakUiPowertoySetup.exe). Run it and click on "Control Panel" in left side section. Now in right-side list, you can easily hide/show desired applets by just enabling/disabling the appropriate applet checkbox.
That's a sign of hardened seals. They're stiff and leak when cold and soften and seal better as they warm up When did you change fluid last? You can try a fluid flush and a bottle of Lubeguard supplement. But really, start saving for a transmission rebuild.
This is caused by the document using a "field" and not an actual date. Press <ALT+F9> to see the date's field code. You will probably see: { DATE } or { DATE @ "M/d/yyyy" } (NOTE: The M/d/yyyy formatting may be different for you; since this is personal choice). You can manually delete the field and type in your date. To automate this, open the TEMPLATE (*.DOT) and change the field by using: Insert > Field... and selecting "CreateDate" from the Field names list. Also - set your desired format too and then click <OK>. Save the change to your template and it will use the date you create the fax and keep that date if the fax is saved as a document and reopened in the future.
All dates are actually date-time fields - if you don't specify the time, Oracle defaults to midnight. To filter date-time specify the date-time string as a formatted field like this:
select count(*) from mytable where dttm > to_date('20080610181907','YYYYMMDDHH24MISS');
This is the date June 10, 2008 at 6:19:07 PM as an example.
For Current Date - you can use the =Now() function in your cell where you want the date.
For Contract #, I don't know what you're using, but you can link to a database of contract #s (see below), or you can name a range like current contract #, which gets updated by 1 each time you add another contract, which then is automatically posted on your EXCEL
DGET(database,field,criteria) Database is the range of cells that makes up the
list or database. A database is a list of related data in which rows of related
information are records, and columns of data are fields. The first row of the
list contains labels for each column. Field indicates which column is used in the
function. Enter the column label enclosed between double quotation marks, such
as "Age" or "Yield," or a number (without quotation marks) that represents the
position of the column within the list: 1 for the first column, 2 for the second
column, and so on. Criteria is the range of cells that contains the
conditions that you specify. You can use any range for the criteria argument, as
long as it includes at least one column label and at least one cell below the
column label in which you specify a condition for the column.
