Question about Toshiba Satellite A100-S8111TD Notebook
My screen has 2 vertical green blue lines, eye sore
I really can put my finger on why there there.
  • 29 Answers
Sorry to say this is usually a bad signal cable or a sign of a dying notebook. Try in the following order, reinstall your graphics drivers. Open the laptop and see if the monitor cable is dislodged from the mainboard, otherwise your screen is dying and needs to be replaced, seen it a million times. Let me know if you have any questions.
Posted on Apr 28, 2010
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
Vertical lines on screen
3 problems:
1. your monitor but i doubt it
2. vga component in your computer
3. atx component in your computer.
try go to a friend and make some changes. don't buy anything first. just test them to see what's bad.
Nov 01, 2009 | BenQ FP71G+ 17" LCD Monitor
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
All color guns out of alignment
Needs convergence amps replaced. Sometimes resistors burn and need to be replaced. This repair requires soldering/desoldering equip. and a trained eye, but usually can be done for 175.00-325.00 at a reputable service center. Good luck, Russmann.
Nov 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Vertical lines in my laptop screen
I had the same problem - sent it in to Acer and they replaced the LCD for 500 bucks!
Aug 18, 2008 | Acer Aspire 9500 Notebook
Picture shows only about a 2-3" blue,green,or red vertical line down the middle
If your seeing vertical line across the screen you need to check the components in the vertical stage as well as the vertical IC could be bad, or the yoke could open.
Also check if any voltage reaching the vertical stage.
Good luck.
Was this help full.
Oct 31, 2007 | Panasonic PT-47WX53 47" Rear Projection...
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Vertical Line of Blue Down 1/2 an inch from center screen
Usualy a problem with the LCD screen itself, that takes replacing the whole screen to fix. Sorry. Did you know that it had a problem when you bought it? Could also be an internal connector that has gone bad. There are tiny transistors on most displays that control whole rows and columns. It sounds like one went bad, causing a dead, or constant on, column. Unless you are REALLY handy, it will probably need to go to a service center for repair, which could be more expensive then what you paid for the player. Good luck
May 08, 2006 | Panasonic DVD-LX8 Portable DVD Player
Toshiba Satellite A100-S8111TD Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
