Question about Whirlpool LSR5232L Top Load Washer
Whirlpool Washer LSR5233 Top Load is not draining water after washing, so stops working. What is the problem? Can this be fixed?
  • 5,911 Answers
Check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare. If the model number you posted this question under is correct, the part number for a replacement switch is 285671.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful.
Posted on Apr 28, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
My washer won't stop running.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
This sounds like a Timer problem. See the following Whirlpool / Kenmore Service Manual for top load / direct drive washers. It has a troubleshooting section and test procedures.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Apr 06, 2010 | Kenmore 24032\24036 Top Load Washer
Washing machine stopped working and water will not drain
if washer does not spin then you need to check lid switch. if just not draining but everything else is ok then drain pump is restricted. check for restrictions in drain hose
Jun 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpoole gold top loader stop working
Try pushing down on lid switch. common problem for these models.
May 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
PORTABLE WASHER LCE4332PQ1
did you fix this? i have the same problem.
Apr 06, 2009 | Whirlpool LCE4332P Top Load Washer
Whirlpool Ultmate Care II won't drain
You will have to remove pumps hoses and make sure they are not clogged.
May 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSR5232L Top Load Washer Logo
501 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
