Question about Dell 924 All-in-One InkJet Printer
Sending a FAX
How do I send a FAX, I cannot find phone outlet on the printer.
  • Dell Master
  • 1,606 Answers
The fax is sent through the fax modem in your computer. All this printer does is scan the images for you and send them to your fax software which then dials the modem and sends the fax.
Posted on Apr 27, 2010
My company lexmark X642e all in one machine was faxing fine. I unplugged the fax line and plugged into another fax outlet plug and it would not work so I plugged back into the original fax line outlet and...
Make sure you plugged it back into the right port on the printer itself. The one I have actually has two different phone line plug-in ports - one is for the FAX line that connects to the wall. The other is so you can attach a separte phone as an extention to talk on. Good luck. Also, after it is plugged back into the wall, did you power down, wait 30 seconds and then power back on? Sometimes these things need to recognize at start up whether or not they are connected to other devices, etc. Good luck.
Jun 17, 2011 | Lexmark X642e All-In-One Laser Printer
Can't send fax. Getting transmission verification report stating NG: poor line condition/ out of memory. HELP!!
There are two possible reasons why your printer display the error message.
1. Poor Line Condition
- electrical interference on the line -Make sure electrical or electronic appliances do not interfere with the printer's phone line
- poor line connection - If you have a phone try connecting it directly to line outlet. Listen to the dial tone, if you hear noisy and static, then you will need to call your local telephone company cause there is a problem in your phone line. If dial tone is clear and stable then try checking the telephone line cord that you use to connect your printer from the line outlet, replace if broken.
- alarm system or another device on same line, these interferes with transmission / reception of the fax machine. Try connecting the printer all alone and then try sending a fax.
2. Memory Full
- There is no space to store incoming fax messages. Delete all stored fax messages.
Apr 09, 2011 | Brother MFC 6490CW InkJet Printer
WHEN I SENDING A FAX IT SAS COMM ERROR 363
It's a communication error between the printer and the sender or the receiver.
Unplug the fax phone cord from the wall. Plug in a telephone into that outlet and see if you can make a phone call.
Plug your fax back in, and try it again.
Jan 25, 2011 | HP LaserJet 3050 All-In-One Printer
Audible voices interupt fax sending
PLUG A CHEAP TELEPHONE INTO THE WALL OUTLET FOR THE FAX LINE AND SEE IF YOU STILL GET THE "OPERATOR VOICES".
IF YOU DO THEN YOUR PROB IS ON THE LINE OR WITHIN THE BUILDING YOUR IN..AND NOT WITH THE FAX. MACHINE.
Apr 28, 2010 | Office Equipment & Supplies
Do you need an extra phone line for a fax on your printer
it depends on what type of printer you have...i actually have an HP officejet j3500 series, it a fax, printer,scanner and copier in one.. when im using it for sending fax messages, i just dial the number where im sending it and it automatically faxes (phone keypad and handset is included)... and i use it as my printer too so its already connected to my pc..so easy to use...
but but but... i actually connected a separate phone line (our original phone from our provider) to the hp j3500 series cuz sometimes i need to speak first to thr person im sending fax before i send the message... i think that is for manual sending of fax...
so if you want to send manually (speaking first to the person before sending) a separate phone line is required (connected to ur fax)
but if u want autofax, then i dont think its necessary...
there u go...
visit this website to learn more.. hope this is useful
http://h10010.www1.hp.com/wwpc/sg/en/ho/WF05a/18972-18972-3328064-3328083-3328083-3440951.html
Sep 10, 2009 | Lexmark X2470 All-In-One InkJet Printer
No dial tone on my Lexmark X4270
There are two outlets in the back where you plug in your phone line. I had the same problem when I
was plugged into the far left plug (as you are facing the front of the all in one). I switched to the other
outlet and it worked fine. But still once in a while it seems to loosen up and I have to push it back in
farther. Today I got a dialtone but could not send a fax. I got a dialtone but still wouldn't send. So I
checked the outlet and sure enough, it was just loose enough to prevent the machine from registering
the fax number, but connected enough to get a dialtone.....go figure. Good luck
Apr 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
Difficulty sending a fax
Hello. Please make sure your telephone line is plugged into the correct outlet.
Most fax machines typically allow you to plug the line (the cord that goes from the fax machine to the wall jack) and and a telephone (the telephone connects to the fax machine).
In order to fax correctly, you must plug the line into the jack with a block (looks like a 'T') marked on it. Do not plug the line into the jack marked with a phone hand set marked on it.
http://gdlp01.c-wss.com/gds/0900002546/PIXMA_MP780_750_Easy_Setup_Instructions_EN.pdf
This shoulds in detail how to connect the line properly. For this printer the line cord must be plugged into the jack labelled "L"
http://gdlp01.c-wss.com/gds/0900002542/PIXMA_MP750_780_Quick_Start_Guide_EN.pdf
This will show you how to actually send the fax. On your PDF View select page 42.
Feb 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Fax machine stoped receiveing fax
First, check your fax's phone line. Put a regular phone on it and check for dial tone and line noise. If the line is dead or noisy, this will cause a problem.
You can also try dialing your fax number from another phone and see if the fax unit picks up the line and starts initiating communication. (sounds like modem noises)
Jul 30, 2008 | Brother MFC-7820N All-In-One Laser Printer
Whizzzzzing sound and will not send fax.
The problem is the power supply try to plug to different outlet and then send a fax if it fails then its a power supply fault please change it.............
May 27, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Fax not sending
Are you able to make copy...If yes..
Printer needs to be resetted.
Turn printer on...Disconnect power cord on the back of printer..
Then press & hold # and 6 key simultaneously while connecting power cord.....
& system will display reset or off...
Then check after alignment....
Nisar
Apr 24, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Dell 924 All-in-One InkJet Printer Logo
77 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
