Question about Tappan TMT104E1 Microwave Oven
I was using my microwave...pushed the button to stop it...door opened..but it was still running. Did this three times then unplugged it. Help
  • 1,606 Answers
That is not good at all! The safety lockout switch on the door is supposed to stop the microwave from doing this. This is rather dangerous and you can cause permanent eye damage with just a few seconds exposure.
Do not use this microwave again until you get it fixed by a repair shop. It may be cheaper to buy a new one than repair this.
Posted on Apr 27, 2010
  • Dave King
    Dave King Apr 29, 2010
    Please let me know if you have read this. I typed that first reply off as fast as I could as this is really a serious thing and wanted to make sure you knew that.
    When that switch fails and allows the microwave to work with the door open the energy is no longer safely contained. One of the real scary things is just how fast it will cause permanet eye damage. The doors open and you go to look and thats it. Attended a demonstration once where they used the microwave to pop balloons at about 300 feet distance (100 meters). In your house you are much closer and the energy is much higher than that.
Turns on when door is open; turns off when door is shut.
when mine did that it was the door switch had failed
Jan 21, 2016 | In Microwave Ovens
FFCM1134LS
The "6" pad on the microwave's membrane keypad is shorted.
If this is under warranty, refer to your owner's manual to contact Frigidaire customer service about finding a local servicer to fix it under warranty.
If it's out of warranty, looking at the retail price of this model, it may not be economical to have it repaired.
If you or a friend can get a new keypad from Frigidaire at a decent price, you can refer to a handy guide with pictures showing you what's typically involved.
Jan 30, 2013 | Frigidaire FFCM1134LS Microwave Ovens
Sharp Insight Pro microwave drawer KB6024MS not working
The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply do the following:
1) Push the draw all the way closed
2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears.
3) Hold the Start Button until the time reappears in the display.
4) Repeat steps 2 & 3 three more times
5) Unplug the Microwave for 30 minutes.
The drawer is now reset. The drawer will now open electronically (automatically) either by pushing the open button on the panel or by pulling the drawer handle slightly.
Feb 05, 2010 | Microwave Ovens
I have a 10 year old MH7130XE Whirlpool microwave oven. The oven and key pad both work, and the oven heats just fine. The problem is the oven begins running as soon as you open the door...without pushing...
I'm assuming you mis-typed and meant the oven begins running when you SHUT the door and stops when you OPEN the door. Please tell me this is what you meant! If the microwave oven runs with the door open, UPLUG IT IMMEDIATELY AND DO NOT USE IT!!!
If the oven begins running without pushing the start button then the controller is bad or the Start button is worn out and making contact without pushing it. (Most likely it is your controller.) Generally, it is not worth the cost to replace the controller on a 10 year old microwave. Probably time for a new one.
But if you want, you can call Whirlpool and see what they suggest at 800-253-1301.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Whirlpool MH7130XE Microwave Oven
GE Profile Microwave - door wont open
The only mode to service the door lock is the removing the lid. The screws are located in the back side and on the bottom of the oven.
First unplug the main supply !
Sep 07, 2017 | GE JVM1630 Microwave Oven
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Microwave shuts off by itself
The microwave has a safety door switches (2-3 micro switches)
The door mechanism should hit these micro switches. If you can open the machine, you can see that these micro switch has a holder that you can adjust and tighten to make sure that the hook of the door should activate them.
Mar 30, 2017 | Whirlpool GH8155XJ Microwave Oven
Microwave will not respond to any button being pushed
The service man just left it was the 20 amp line fuse. Have one on order.
Jun 11, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Panasonic NN-2501 Microwave Oven range hood
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Oct 05, 2007 | Panasonic NN-S251 Microwave Oven
Microwave Ovens Logo
211 people viewed this question
Top Tappan Microwave Ovens Experts
William Miller
William Miller
jdtech
Are you a Tappan Microwave Oven Expert? Answer questions, earn points and help others
