Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Refrigerator will not hold temperature lower than 44 degrees!!
When I press the button to lower the temperature, 34 degrees pops up but will not stay there. Flexuates from 41 to 44 degrees. I have vacuumed the portion above the refrigerator, behind the grate. Any suggestions?
  • Mike Smith
    Mike Smith May 12, 2010
    You DO NOT HAVE A LEAK . He is not a trained GE technician , guessing at the problem , and he is trying to take your money . Find a reputable GE tech in your area .
I bet it's a GE Monogram? I have the SAME problem. Our refrigerator is stuck at 44 degrees. It was stuck at 47 degrees, but after 6 visits from the repairman we now have it down to 44 degrees! At first we didn't realize how bad it was, and we were eating food that was making us sick! My daughter was admitted into the hospital from severe intestinal problems and without getting into details... this has cost her health, and tens of thousands in medical bills.
We have thrown out a ton of food. The repairman has replaced a bunch of parts including a fan, a thermostat, replaced a switch, cleaned, checked the gaskets, replaced a thermostat control device, and possibly other stuff as I can't keep track anymore. He's has been coming 2-3 times per week for the last 3 weeks. And now says the ONLY thing it can be is a "leak" in the copper line. Since it is a sealed system he has to tap the copper line with a valve to check the pressure, and that valve will always have to stay in place once it is tapped. And we will have to have the freon filled every so often because valves will slowly lose the freon over time.
This GE monogram is suppose to be a top of the line GE appliance. Our entire kitchen is GE Monogram, and we have had many many problems with most all of the appliances. The dishwasher was replaced at approx. 4 years due to over priced service calls, and super expensive parts. GE wanted close to $300 for an upper dishwasher rack. It was less expensive to buy a new one.
Don't these appliance manufacturer's get it? They may save money on the manufacturing side, however they lost a customer for life. Not only did they lose me, they lost my daughter, my son, and my grandson.
These GE appliances that are built to fail end up filling up our landfills. GE should be embarrassed.
Possibly have your repairman check the copper line for leaks? We're waiting to see today if that will work.
Posted on May 12, 2010
  • kkdman2 Oct 31, 2011
    I had a similar problem with my GE side by side monogram. Went from extremes of too high a temp to too low. Repair wanted to replace the fan unit that draws cold from the freezer into the rapid cool of the fridge. Someone on line mentioned it was a programing problem, just turn the unit off for a few minutes, turn it back on, hold down all four of the temp controls buttons on front of fridge for a few secs to reprogram. It has worked fine since then.
Whst temperature do I set LG LFX 31945ST
Hey Rosalie,
The lower the temperature the better but do not operate to the extreme.
  • I would set the freezer between 0 and 7 degree F
  • The fridge between 34 & 37 degree F
  • Adjust Temp if necessary.
Here is a link to the fridge manual.
Good Luck!
JP
LG LFX31945ST Owner Manual
Jul 19, 2015 | LG Refrigerators
How do i set the tempature lower on a GE model GSS5QGTA side by side. I see a panel on the outside, but i am not sure what to do
If up push the button it tells you the set temperature . Push it twice and it will go into the set mode and then use the warmer or colder buttons to change the temperature. Do the same for the refrigerator
Jan 11, 2015 | Refrigerators
The temperature on my Heartland refrigerator fluctuate between 34 deg and 50 deg, is this normal?
How long does this temperature issue last? When you notice this issue how long does this sit at the hire temp, 1 hour? I am trying to understand why Heartland/Marvel would ask you to turn it off. Please let me know. Thanks
Aug 01, 2014 | Heartland Refrigerators
Fridge not cold enough
The higher the number the colder the temp is supposed to be.
In order to prevent the formation of bacteria and other such organisms to affect food the way it does, the ideal temperature range of refrigerators has been mentioned here. Before we look at these settings, it is important to know the format in which temperatures are represented within a refrigerator. Commonly, you will notice a dial representing the figures 1-5 or 1-9 in the refrigerator, and a dial representing the letters A-E in the freezer. The ideal setting is usually in the middle of such figures.
If the dial is in such a format in your refrigerator, try a setting at 3 if the range is 1-5, and at 4 if the range is 1-9. For the freezer, a setting at C is suitable.
The ideal temperature in the refrigerator ranges between 34 degrees F - 38 degrees F or 1 degrees C - 3 degrees C. So that foods such as vegetables and fruits remain fresh and crisp, the temperature may be set around 38 degrees F or 3 degrees C.
The ideal temperature in the freezer ranges around 0 degrees F (-18 degrees C) or lower.
Read more at Buzzle: http://www.buzzle.com/articles/refrigerator-temperature-settings.html
Mar 05, 2014 | Belling Refrigerators
Dorm refrigerator freezes everything
Lower the freezer letter by one letter, let set 24 hours for temp to stabilize, keep lowering until right temp/environment is achieved.
The temperature of refrigerators should not be allowed to exceed 41 degrees F as this will contribute to the growth of bacteria in the food, and cause different health problems, including food poisoning if consumed.
A temperature below 34 degrees F in the refrigerator may cause the food to freeze, and you will have to defrost it before using it. If this happens to vegetables and fruits they will go limp and will be rendered inedible.
At any time when you change the temperature, give it a minimum of 24 hours to take complete effect.
The external temperatures also influence the internal refrigerator temperature. This means, you will have to set your refrigerator lower in summer, and higher in winter, especially if you live in extreme climatic conditions. On the other hand, if the climate in your zone is moderate, your refrigerator temperature will be less affected by external temperatures.
In order to check and ensure the internal temperature of the refrigerator, you may place a thermometer kept in a glass of water in the fridge. The exact temperature will be available to you anywhere within 5-8 hours.
For your refrigerator to cool effectively, it is essential that your air vents are functioning well. Do not place any items before it, and clean it on a regular basis for maximum effect.
Mar 05, 2014 | Kenmore Refrigerators
Temperature of thermo defrost samsung
The ideal temperature in the refrigerator ranges between 34 - 38 degrees F or 1 - 3 degrees C. So that foods such as vegetables and fruits remain fresh and crisp, the temperature may be set around 38 degrees F or 3 degrress C.
The ideal temperature in the freezer ranges around 0 degrees F (-18 degrees C) or lower. See more at:
Mar 01, 2014 | Refrigerators
Food is starting to spoil more quickly than it should. The refrig temp on the door is set at 34 degrees which is the lowest it will go. The temp. on the refrig thermometer says it is 60 degrees. What...
You can get a small digital thermometer at your local hardware store for a pittance. ... For most refrigerators, this temperature coincides with the lowestsetting or one of the ... If your refrigerator is really full with items, lower the temperature a bit. ... they're not going to go bad because they were at 41degrees for a few hours.
Sep 12, 2013 | Samsung RF267AE (25.8 cu. ft.) Bottom...
Coils keep freezing up, and temperature in cooler won't go lower than 44 degrees. just installed new thermostat.
The refrigerant system is low on charge....you will need to have the leak fixed and the system recharged.
heatman101
Jun 12, 2011 | True TD-65-24 Commercial Refrigerator
What is the proper temperature for a refrigerator be and what is the proper temperature for the freezer?
A refrigerator should maintain temperatures at or below 40 degrees F. The freezer temperature should be 0 degrees F or lower
May 13, 2011 | Amana Refrigerators
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
1,095 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
