Question about Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A
Frigidaire Upright freezer Baskey
The pullout baskdet on our 20cuft. freezer keeps slipping of the track. It appears the basket is slightly to narrow in width. The tracks which bolt on to the inside freezer wall also keep loosening. I tighten them but will not remain tight. When tight the basket falls easier. Need a solution. Model is FFU20FC6AW4
    Genius:
  • 1,073 Answers
Remove the basket sliders frome each side and install a couple of nylon washers between the slide and the side of the freezer on each side it will narrow the distance and the nylon washers will not rust
Posted on Apr 21, 2008
Chest freezer not working. Light inside chest freezer comes on but green power light doesn't turn on and freezer makes no sound. What could be the problem.
Could be your thermostat is bad and not calling for the compressor to come on. If you are able see if there is power getting to the compressor. If not then back track to where you are loosing power (thermostat) etc.
Nov 04, 2014 | Magic Chef Chest Freezer MCCF5WBX
Bottom basket in freezer
Flo Shirley,
I understand that you are having trouble removing the bottom basket in your Frigidaire freezer. To remove the basket, pull out, and lift up. This basket clips in to the actual glides that hold it at the bottom of the basket.
-Best Regards-
Jan 17, 2014 | Frigidaire 13.7 cu. ft. / 388 liter...
How to insert a freezer drawer
Try lifting up on the drawer while trying to insert the drawer in the track
Mar 13, 2013 | Freezers
Our two lower slide-in baskets will not stay on track. Even when the load has been reduced, the baskets fall off the track. I have tried to bend the sides to better reach the track, but it doesn't work. ...
No, very rarely internal shelves can be moved between generations. Unfortunately all you can do is an improvisation to keep them in place: you need to make the channel walls higher by gluing some small pieces of thick plastic on them using a powerful adhesive - not superglue, something like Loctite Sumo Glue.
Sep 10, 2010 | Kenmore Freezers
Water coming out of the lid of a Kenmore 5 cu. Freezer
Funny. We just spent an hour trying to figure out the same problem with our Kenmore. It is the third or fourth time that we've noticed water on the floor under the freezer, but the first time that we've been able to track it to the lid.
The only thing that makes sens to me is that this problem may be happening when our freezer has a frost buildup around the top of the unit which doesn't allow the lid to close perfectly snug. I'm thinking that this causes a bit of melt in whatever frost may be inside the lid from regular air circulation around the unit. It runs out the back of the lid when it opens.
Check that there is no frost around the rim of the freezer that may be causing a slight (it only takes a very small opening to allow warmer air to circulate under the lid) irregularity in the lid seal.
Jul 06, 2010 | Freezers
Lower shelves keep falling down out of wall supports
replace gromments and reduce the weight that you put inside the shelf/basket.
Apr 22, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Trying to find parts for a Holiday brand chest freezer
Try on amazon, take a look here: Amazon com chest freezer parts. Wish you best of luck. Cheers
Dan
Feb 26, 2010 | Freezers
Whirlpool fridge is fine but freezer not
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again.
Also check to see if anything is blocking any airflow at the vents.
Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 17, 2010 | Freezers
How do I change the door seal on a gibson UR freezer?
The most important thing is to make sure the new seal is warmed up to room temperature so it is soft and workable. Since the seal on mine is attached to the top door there is nothing to gain by leaving the door attached. Working upside down would leave the door open longer than just taking it off.
If you still have food in the freezer just put blankets over the top until the door is back on. If you have screws holding the seal it will go much easier. Mine has plastic pins that break easily pulling them out.
Get the edges as straight as possible to avoid leaks.
Sep 19, 2009 | Freezers
Freezer Baskets fall off Guides
I have the same freezer and have the same problem with the baskets. I hope they come up with a solution because my baskets are inoperable right now...
Apr 27, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A Logo
194 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
