Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
How to instal file 'asms The file 'Asms' on Windows XP Professional Service Pack 2 CD is needed" when installing WinXP Pro,
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 101 Answers
When you install Microsoft Windows XP, you may receive the following error message:
[Files Needed]
The file 'Asms' on Windows XP Professional CD-ROM is needed. Type the path where the file is located, and then click OK.
This issue may occur if the Setup program cannot communicate with the CD-ROM drive.
To resolve this issue, use the appropriate method for your computer.
Hard disk formatted with FAT or FAT32 file system
If the hard disk is formatted with the FAT file system or with the FAT32 file system, follow these steps:
Use a Microsoft Windows 98 Second Edition or Microsoft Windows Millennium Edition (Me) Startup disk with CD-ROM drivers to restart the computer.
Copy the Xcopy.exe tool from the Windows 98 Second Edition CD-ROM, the Windows Millennium Edition (Me) CD-ROM, or the hard disk to the Windows Startup disk. To do this, use the appropriate method.
Insert the Windows 98 Second Edition CD-ROM in the CD-ROM or DVD-ROM drive, and then at the command prompt type the following lines, pressing ENTER after you type each line, where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive:
c:
copy cd-rom:\win98\smartdrv.exe
copy cd-rom:\tools\oldmsdos\xcopy*.*
Insert the Windows Millennium Edition (Me) CD-ROM in the CD-ROM or DVD-ROM drive, at the command prompt type the following lines where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive, and then press ENTER after you type each line:
c:
copy cd-rom:\win9x\smartdrv.exe
extract cd-rom:\win9x\win_17.cab xcopy.exe /L c:\ xcopy.exe
extract cd-rom:\win9x\win_17.cab xcopy32.exe /L c:\ xcopy32.exe
extract cd-rom:\win9x\win_19.cab xcopy32.mod /L c:\ xcopy32.mod
Hard disk
At the command prompt, type the following lines where drive is the drive letter of the hard disk where Windows is installed, and then press ENTER after you type each line:
c:
copy drive:\windows\smartdrv.*
copy drive:\windows\xcopy*.*
Eject the Windows 98 or Windows Millennium Edition (Me) CD-ROM, and then insert the Windows XP Professional CD-ROM.
Copy the I386 folder and all its subfolders to the hard disk. To do this, type the following lines at the command prompt where cd-rom is the drive letter of the CD-ROM drive, and drive is the drive letter of the hard disk, and then press ENTER after you type each line:
smartdrv
xcopy cd-rom:\i386 drive:\i386 /e
Restart the computer, and then start the Setup program again.
When you receive the error message, click Browse, and then type the path of the I386 folder on the hard disk.
Note You may be prompted several times for the location of this folder. If Browse is not available, see the "Hard disk formatted with NTFS file system" section.
If the hard disk is formatted with the NTFS file system and you are upgrading an earlier version of Windows, use one of the following methods.
Method 1
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
When you receive the error message, press SHIFT+F10 to start a command session.
Type regedit.exe, and then press ENTER.
Click HKEY_LOCAL_MACHINE.
On the File menu, click Load Hive, and then load %Windir%\System32\Config\System.sav.
When you are prompted to specify a name, type Test.
Locate and then click the following key:
HKEY_LOCAL_MACHINE\Test\ControlSet1\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the UPPERFILTERS and LOWERFILTERS registry keys.
Repeat steps 6 and 7 for the other ControlSet# keys under the Test hive.
Click File, and then click Exit to quit Registry Editor.
If the path in the error message is the correct drive letter for the CD-ROM drive, click OK to continue the Setup program.
If you receive the error message again, the Setup program cannot correctly read from the CD-ROM drive, or the path information is incorrect. In this case, restart your computer and let the Setup program resume.
Method 2
If you cannot start Regedit.exe at the command prompt, and there is another available partition where you can install Windows on the hard disk, follow these steps:
Install Windows in the other partition.
Start the new installation of Windows, and then start Regedit.exe.
Follow the steps in method 1, but load the System.sav hive from the original Windows folder.
Method 3
If you are not using a retail Windows XP CD-ROM with a hologram (for example, if you are using a burned CD-ROM), try to run the Setup program from a retail CD-ROM with a hologram. To verify this, start the computer by using Recovery Console, and then check the C:\$win_nt$.~ls folder. Look for the Asms folder. If the folder is missing or the files that it contains are zero bytes, the CD-ROM was not burned correctly.
For additional information about how to use Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base:
307654 (http://support.microsoft.com/kb/307654/ ) HOW TO: Install and use the Recovery Console in Windows XP
Posted on May 06, 2010
NEED SATA DRIVERS FOR LATATUDE D800 REINSTALLING XP PRO
This is the sign of either Faulty RAM or RAM with a Timing Issue. Quite often if more RAM has been added to a computer and it is not identical from the same Manufacturing Batch there can be Timing Issues that do not show a problem while the OS is working but prevent the installation of Windows Particularly.
The answer here is to either remove the added RAM till after you have reinstalled Windows or replace the faulty RAM if one has failed.
Nov 09, 2013 | Microsoft XP Computers & Internet
Ayudad
I don't know if you understand english but you may have a problem with your motherboard
Aug 28, 2009 | Microsoft Windows XP Professional With...
Reinstalled Windows xp professional to my acer aspire 3610
1.change another Installation CD of Windows XP service pack 2 or install Windows Vista.
2. if any track of your CD is corrupted, then this type of error comes.
3. sometime if your hard is not formated correctly, then also some fatal error comes.
4. when formating always do full format, donot do quick format.
Jun 23, 2009 | Acer Aspire 3610 Notebook
Need file asms to complete installation
The problem is some files in your installation cd cannot be read anymore.
Options:
1. When the error appears try to redirect the wizzard to the directory of your CD ROM and locate the file.
2. If you have back up copy of your xp cd use it to replace the xp cd you are installing when the error appears.
3. If you have a copy of your xp installer on your hard disk re direct the wizzard to that directory.
Apr 27, 2009 | Microsoft Windows XP Professional
Installation Error
there could be either one of the 3 parts which is giving u this error
1) instalation cd ...(try installing from a different cd )
2) cd/dvd drive ( try with a different drive )
3) faulty memory card
mostly this issue is being created by faulty memory card if possible try that first
Oct 31, 2008 | Microsoft Windows XP Professional With...
Windows XP Service Pack 2 shows asms missing
My understanding of this problem is as follows: When you put the Windows XP CD into the drive and switch on the computer Windows starts from the CD. In order to access the CD it uses the BIOS. However, at a certain point it decides to use its own drivers instead of using the BIOS. Oops! it doesn't have the right driver because your CD drive is too new, so it can't read the CD, and thus can't continue the install. The solution then is to copy all the necessary files onto a place where Windows can read the files. Solution 1 Do you have another computer? Take the hard drive out of the machine you are installing and put it into the second machine as a secondary hard drive. Switch on the second machine and copy the i386 directory and all its files and subdirectories from the Windows install CD on to the secondary hard drive. Remove the hard drive and put it back into the machine you are installing and switch it on. When Windows then asks for the missing file you can direct it to the I386 directory on the hard drive. This should be C:\I386. It will ask for the location of about 10 files. Give the same answer each time. Solution 2 You will need a bootable CD such as Hiren's boot CD, and a second CD drive. Put Hiren's into the primary CD drive. Put the Windows CD into the second CD drive. Switch on, and choose the mini XP Copy the I386 directory and all its sub-directories onto the hard drive. Again, when Windows asks for the location of the files direct it to the appropriate directory on the hard drive.
Feb 05, 2008 | Microsoft Windows XP Professional With...
Win xp pro setup
if you have the original xp disk with a cd key , then its perfectly legal for you to download a iso copy of xp , and install it, if not try and make a copy of the disk , and use that , or someone u know may have a friend with a xp disk , thats fine also aslong s you use the key that comes with your disk
Nov 26, 2007 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
901 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
