Question about Haier BC112G Wine Cooler
Dimensions for haier bd00t0e0200
What are the dimensions for haier bd00t0e0200 wine cooler...also this cooler was already in the home that we recently purchased but my husband and I don't drink...do you know if and where we can purchase soda racks by haier to replace the wine racks instead?
ramon49
  • 111 Answers
SOURCE: My Haier 12 wine bottle cooler is dead. No fan or cooling .
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
Posted on Mar 09, 2009
SOURCE: haier wine cooler
Hold + and - keys down together until LED blinds (about 4 or 5 seconds), Then press + or - key to lower or raise temp. Once you've reached the desired temp press the set key.
Posted on Mar 18, 2008
SOURCE: HAIER WINE COOLER HVW18bss I
IS THERE A THERMOSTAT YOU CAN JUMP OUT WITH A SMALL PIECE OF WIRE?IF THAT DOES NOT WORK A THINK YOU HAVE A LEAK SOMEWHERE,CHECK ALL THE PIPE CONNECTIONS TO SEE IF YOU SEE ANY OIL,LET ME KNOW-MIKE
Posted on Sep 21, 2008
SOURCE: Haier Wine Cooler won't cycle on and off automatically
Hey all,
For those of you who have problems with one or both or your zones not cooling on the HVTB18DABB or similar wine cooler/cellar, the problem lies the Peltier-style thermoelectric cooling module. The original part is "TEC1-12706" and information on it can be found on google. Finding this or a similar part on ebay can be done by searching for "thermoelectric cooler". If the exact TEC1-12706 part cannot be found, then any similar part that's 40mm x 40mm in size, and 51 to 69 watts should do fine. For $25 I was able to get 3 modules...one to replace the bad zone I had, and then I'll have 2 spares in case the other zone, or this new one, ever go bad again.
To replace the part you must remove the back panel from your Wine cellar. You will see 2 big fans attached to two large heat sinks. (If a heat sink on the back does not feel warm to the touch, the the other side is obviously not cooling, which means that zone is broken.) Remove the screws from the fan and the heat sink of the zone that is not cooling, and while holding the heat sink, pull the whole cooling assembly for that zone out. Dont be alarmed if you feel some insulating foam separating as you pull it out, its a tight fit so that is to be expected. Once you have the cooling assembly out of the fridge, take it apart and you will see the square ceramic cooling module inside. (REMEMBER which way the module was oriented before you remove it, so you know how to put the new one in.) Clip the red and black wires near the module and remove it from the assembly. DON'T wipe away any of the white thermal grease left behind on the heat sinks. If you have any extra thermal grease handy (available at Best Buy, or online at sites like newegg), apply an extra pea-sized dab to both sides of the new module. Put the assembly back together and splice the wires from the new module to the loose wires left behind going into the back of the Wine cellar. Mount everything back in place as before, close up the back, and youre done!
This is really a lot easier to do than it sounds, especially if you're comfortable doing this sort of thing...a few pictures would explain much better if anyone wants to illustrate.
These are actually great units, so I hope this helps somebody fix theirs!
Posted on Sep 24, 2008
wilsodfarm
  • 986 Answers
SOURCE: We have Haier Wine cooler that has power but not
Its trying to protect its self ,it low on freon and you have a leak,sorry that not what you want to hear.
Posted on Dec 10, 2009
Haier BC-112G not working
as stated already:
  • first replace the temp sensor: $4.76 from Haier RF-6250-01
Still have the dreaded 25 degree & LL in the temp box?
  • Replace the control board: $26.81 from Haier RF-0668-04
Oct 23, 2011 | Haier BC112G Wine Cooler
How to adjust the temperature of the wine cooler
How is temperature adjustment set for proper cooling,my Haier holds [9] btls of wine ,please help.
Jan 05, 2011 | Haier BC112G Wine Cooler
Wine temp on Haier wine cooler BC112G went to LL, opened up and some champagnes frozen, other wines very cold, condensation all over door, how do you fix this error?
The error is likely caused by a bad temperature sensor. The control board may still be Okay.
Replacing both of them is recommended.
Check this link for parts: http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/BC112G.aspx
Dec 31, 2010 | Haier BC112G Wine Cooler
Haier HVTB18DaBB Wine Cooler has stopped working. It was working yesterday and today it isn't.
check if it still has power, if it does check the back of the cooler to see if the fans have stopped running, you might need new fans.
Oct 03, 2010 | Haier HVTS18DABB Wine Cooler
Are red wines stored on the top or bottom of the Haier BC112G wine cooler? How about white wine? Have lost my owners manual and don't know where to put red wine when the temp is set cooler for white wine
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Jun 14, 2010 | Haier BC112G Wine Cooler
I have a Haier Model BD00T0E0200 that is getting power, the compressor is warm to the touch, is clicking occasionally, but does not cool. Any suggestions?
Hi and welcome to Fixya. I am Kelly
First of all unplug the unit for at least 30 minutes and let the compressor cool off. That clicking your hearing is the "KliXon" thermal overload trying to protect the compressor because it is not starting.
Failure of a compressor to start can be caused by several things.
1. A bad PTC Relay / KliXon mounted on the compressor
2. A bad run capacitor
3 The bad news... a LOCKED rotor in the compressor.
There is one other possibility and that is that the power cord plug is not making good contact with the wall outlet terminals. (very rare that this happens)
Just make sure to unplug the unit for at least 30 minutes. Use a fan for cooling the compressor if you can by just pointing it toward rhe area of the compressor. After 30 minutes plug the unit back in and cross your fingers...... If it starts your in luck... If not then your going to need to service the unit.
Again thanks for using Fixya and if you need further assistance just reply here. We get notified of all responses. Kelly
Feb 07, 2010 | Haier BC112G Wine Cooler
Want to purchase relay. Can't find part locally.
The best thing to do is go to your local appliance parts warehouse and match up the relay with what they have in stock.
Be sure to briung all relevant info you might have on the unit.
That way you can ask for the RF-5600-01 to compare it before purchasing. Thats exatly what a service tech would do if you called one, only they will charge you 50 to 100 bucks to do it.
Aug 25, 2009 | Haier HVFM20ABB Wine Cooler
Haier wine cooler freezes the wine.
You may find that the thermostat is not working. Try to turn the thermostat to the warmest setting, the compressor should switch off within two hours, if not change the thermostat.
Mar 09, 2009 | Haier BC112G Wine Cooler
Haier BC112G Wine Cooler Logo
253 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
