Question about Karcher G 2600 VH Gas Pressure Washer
Pull cord seems to grab and can't get it to start since it grabs too quickly..... tried pulling it out slowly and then let it feed back... no good... manual doesn't address this at all
4 Suggested Answers
sailoff
  • 8 Answers
SOURCE: Pull cord is locked. Was running fine and just
any oil in the engine? pull cords are easy to replace but sounds like you run out of oil and the engine locked up!
Posted on Jun 21, 2009
  • 241 Answers
SOURCE: pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Posted on Mar 24, 2010
wmpcs
  • 100 Answers
SOURCE: Removing unloader valve
You can hook it up to the water supply but many times you are going to have to start the unit up to get the unloader to come out. I would recommend putting something over the top of the pump so when it comes out you don't lose a eye. If you still have an issue with it not coming out you are going to have to pour some white vinagur down the cylinder and let it sit for a couple hours, this will breakdown any build-up inside the cylinder.
Posted on Oct 25, 2010
How to install pull cord?
take off cap then take out old pull cord once done get a cord long enough some will hanging out when recoil rewinds rope next there is hole in rewind pulley make sure you find it then hard part rewind spring on recoil till it stop hold tight the unwind 2 winds hold on tight next slip cord trough houseing and through pull hole put screw driver threw holes in threw rehousing that will hold in place the pulley not the cord take a lighter heat the cord up this will keep the knot in place grab cord remove screw driver from houseing hold cord tight pull cord until knot is seated next two pulley slowly let reciol wind rope in until it stops should be cord hanging out grab hiold of cord next to recoil hole pull out for two pulley revolution hold there install handle on rope tie knot heat knot with lighter your done cut off excess rope reinstall cap and completey down let me no if you have problem i will help im the red neck i like helping people
Aug 28, 2014 | Garden
Hp deskjet 1280 won't print on card
?What, what is a silk grabber machine?
Dec 16, 2013 | HP DeskJet 1280 InkJet Printer
Needing break down on starting assembly! My start cord is fine, but dose not grab anything when I pull.
Danny by the pull cord on the back are two wings that come out when you pull the starter. They are on springs and fly out to grab the wheel. Spray these with lube oil and then let them rest for 10 mins then try.
Oct 17, 2013 | Stihl FS 85 Weed Eater
I have a 22in self propelled, how do i change the pull cord
Remove the motor shroud encasing the pull cord assy. What I do is turn the shroud over, leave the spring in it's slack position and gather up the two broken pieces of string. I lay then down in a circular motion on top of the recoil spool until the string is all coiled up, counting each loop made. That and once more is how many times you'll need to wind that spool up. When you are done winding, "round up" to make the hole in the spool meet up with the hole in the recoil housing. Once you're there, get a medium sized flat-head screwdriver and wedge it between the spool and the housing, hindering the spool from unwinding. Wedge it good. Melt the end of the new pull cord and begin outside the housing and feed the string thru the eyelet on the recoil housing. Keep feeding it ( recoil housing still upside down ) thru until you visibly see it pass thru the eyelet and into the hole of the spool. You may need to use a small pick to grab it and pull it home. Once it's out, it's not over. Pull enough string thru to tie a double-loop knot. When you're satisfied with the strength of the knot, reach down and grab the string, holding it tightly. Next reach in and pull the screwdriver loose. Nothing should move-you're holding the string. Hold the shroud with one hand and let the string slowly pay into the recoil spool. Bolt the shroud back on and go!
Sep 23, 2013 | Poulan Pro " Pro" Self Propelled Mower
Cub Cadet has broken pull cord
pull off cap first from engine look inside it pull the rest of the cord out to the end then grab the not onthe pully while holding it pull the rope out after that wind pully all thee way up shuve a new cord throug houseing pully then slowly let rewind up until it stops cut the rope 6 inchs in front of cap hole restall cap to motor slip your starter rope threw grip that you pull pullthe cord attached to handle out two feet hold onto rope cut handle loose slip[ and tie handle again to the houseing rope dont let go of the rope after that let it rewind back up done
Sep 04, 2013 | Garden
Repair of pull start to garden blower
To replace the pull cord line:
If your pull cord is still attached to the grab handle, it's likely your spring is still wound. Follow this if this is the case, purchase rope of the correct length (or cut) and the correct diameter at your local lawn/garden store, then:
1. Disconnect the long drive shaft by removing the small set screw and the clamp - pull the shaft out of the engine body.
2. Remove the recoil assembly (About 5-5 torx bolts). You may need to disconnect a wire to the kill-switch at this time.
3. Pull the cord until it stops and use a small piece of wood acting as a wedge to jam between the recoil and the housing.
4. Cut the line and pull the knotted terminating end from the hosing.
5. Keep the wedge tight so it does not spin back. If this happens, you will simply need to rewind the spring back (about five turns) and re-wedge it.
6. Feed line through the recoil housing and into the recoil. Pass line through the hole in the recoil and knot the end. Trip to about .25 inch tail. Pull the rope through the grab handle and single or double knot this.
7. Remove the wedge and allow the spring to pull the rope back into the recoil.
8. If it does not completely recoil, either your rope is too long or you will need to add a "wind" to your spring buy removing the line and wind back 1 more turn. Retry.
Sep 25, 2010 | Garden
Form feeding
try puting a piece of cardbord under the paper but tape it 3mm from the roller.
Jul 31, 2009 | AMT Datasouth ACCEL-6350 Matrix Printer
PAPER FEED DOESNT WORK KONICA MINOLTA COLOR PRINTER
This happened to me one time after I pulled out a jammed paper the wrong way. I pulled it from the paper tray. Heard the sounds, it tried to grab the paper, but couldn't. It happened a long time ago, so I'm fuzzy on which part I tinkered with...but I recall that because I pulled the paper (backwards) from the tray, it flipped a lever/feeder/roller/thing and that 's why it wasn't grabbing the paper. If you look in the paper tray as the rollers go down to grab the paper, you'll see what's not working......sorry, lame solution.
Mar 26, 2009 | Konica Minolta magicolor 2430 DL Laser...
Paper is jamed
I have a HP697c and sometimes it grabs more than one sheet and gets jammed. I take hold of the trailing edge and pull hard and slowly till it comes back out. Then I remove and straighten the feed pile and try again.
Nov 07, 2008 | HP DeskJet 920c InkJet Printer
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Karcher G 2600 VH Gas Pressure Washer Logo
100 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
