Question about Canon PowerShot SD600 Digital Camera
Camera states Lens Error, Restart Camera
My canon poweshot SD600 is not allowing me to take pictures. When I turn on the camera it extends but its fuzzy then beeps and says Lens error, restart camera. When I turn it off and on again it still retracts and does the same thing.
  • Jillypoo Jun 19, 2008
    its about the same problem. but my lens wont retract and it says Lens Error restart camera and then beeps and it sounds like its trying to retract but it wont. and i keep restarting it but it wont fix. i think a gear might be stuck inside.???
  • 104 Answers
I think ur camera dropped, u try ur local repairer repairable
Posted on Apr 05, 2008
My camera (canon PoweShot SD660) in giving me an error that reads, "lens error, restart camera" and it turns off. How do I fix it?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 07, 2011 | Canon PowerShot SD600 Digital Camera
Lens error on cannon powershot sd600. When I turn it on it gives me a "lens error, restart camera" and it turns off.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
When turn on, lens won't extend-error message Canon SD 600 digita
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Oct 10, 2009 | Canon PowerShot SD600 Digital Camera
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 28, 2009 | Canon Cameras
Apr 16, 2009 | Canon PowerShot SD600 Digital Camera
Canon SD600 lens jam
I followed the directions contained in http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/ and by disassembling the camera and turning the rotor just a little bit (page 4 of the instructions), it freed up the lens and it is now working perfectly! The camera had been put down on the lens as the lens was retracting and I assume that jammed the retract mechanism. While the camera was open, I blew out whatever dust/dirt was there (didn't see much). The fix took me probably 20-30 minutes, and I am very pleased with myself!
Oct 24, 2007 | Canon PowerShot SD600 Digital Camera
Canon sd600 lens error
Manually rotating sensor rotor inside camera and cleaning gear fixed the Canon "lens error" for me.
I placed instructions with photo's here: http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/
Aug 22, 2007 | Canon PowerShot SD600 Digital Camera
My lens wont fully extend
My sister's camera was having the same trouble and after trying a few different things, i came across a solution that fixed her camera. Her error said "lense error, restart camera."
I held down the shutter button for a few seconds, then i held down the power button as well. I tried it once or twice and then it worked. I hope this helps!
Mar 29, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
164 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
