Question about Sony Televison & Video
Sony kv-34hs420 no picture our soud standby flashes 7 times
  • joaorocha73 Apr 28, 2010
    kv-34hs420 flashes 7 times
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. 7 blinks means High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. Also check the flyback transformer. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Apr 28, 2010
  • 10,594 Answers
Standby light flashing 7 times shows problem of Horizontal Deflection Stopped for some reason and it is hardware problem as few damaged parts would be replaced by qualified tech to get tv fixed.
Local tv repair shop will help you to repair it as it is not user level repair or matter of push few buttons on remote etc.
Hope this info will help you.
Thanks.
Posted on Apr 27, 2010
Sony FD Trinitron WEGA KV-34HS420 34" TV Stand by
I have the indentical tv and problem. Cost to repair was about 250.
Aug 19, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Have Sony KV-34HS420 with no picture or sound. Timer/Stand By light flashes 7 times with pause in between. What is the likely problem and cost to repair?
Hold hair dryer to back right side on high heat for a couple of seconds while you hit the power button several times. It only took 2 times for my set to power on. Good Luck!
Aug 12, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV-34HS420 shuts of and stand-by light blinks
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Source
Sep 01, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony kv-34hs429
The 6 blinks are a diagnostic code to indicate the problem circuit. I'm on the road at the moment, but will look up the code when I get to the shop. In the mean time, a few questions:
1) Does this occur all the time or just after or before a warmup period?
2) Have you noticed that this is occurring more frequently lately or did this just start?
Thanks,
Dan
Aug 07, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV-34HS420 Random Shut downs
i would say this is a internal problem how long have you had it?
May 28, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
normally this is because of a failed capacitor or two that is located on the power supply board. replacing the power board in this unit will fix this issue.
Mar 16, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Standby LED blinking 6 or 7 times and TV won't turn on
That is an error code that tells the tech where the problem lies. It is probably somewhere in the power supply stage. Your best bet is to take it to a TV repair shoppe and let them deal with it. They have all the documentation in order to repair the unit, and they can tell you what the problem is before they work on it.
Cheers
Jan 02, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Random Turn-Off on KV-34HS420
Hello there,
7 times blinks shows that Horizontal Deflection Circuit doesn't work properly.
I think, its not big fault and can be resolve in low cost at nearest Sony repair shop.
Feb 18, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Televison & Video Logo
24 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
