Question about Sony Playstation 3 (PS3) Console
Usb keyboard will not work - Sony Playstation 3 (PS3) Console
    Scholar:
  • 85 Answers
First check your batteries, then make sure you have synced it with the transmitter the usb piece plugged into the ps3 sometimes both that and the keyboard have a button to push or just one of them.
Make sure you are not to far away from the Ps3 sometimes cheap wireless keyboards wont even let you go more then 5ft no joke pretty lame but that is how they are.
Posted on Apr 28, 2010
Keyboard doesn't work
Try connecting an USB keyboard to your Acer laptop. If the external USB keyboard does not work the the laptop is faulty.
If the USB keyboard works then reseat the laptop's keyboard connector to the motherboard, it may have become loose.
Mar 02, 2012 | Acer Computers & Internet
Keyboard does not work
My Acer KU 0760 keyboard is not working at all. Seem as if the computer doesn't recognize it at all. The mouse works in the USB ports, but nothing from the keyboard. Had old gatway keyboard laying...
Try the keyboard in the USB port you've been using for your mouse. Just move your mouse to a different USB port. I know, this seems like a "too simple" solution, but USB ports sometime get cranky.
A question I would have would be: have you been using a PS2-type keyboard prior to trying to use the Acer USB one? Sometimes the BIOS needs the item "use USB port for keyboard" turned on.
Oct 26, 2010 | Acer NSK8458AN Keyboard
Brought a CS62US and Mircosoft KB with mouse. When USB combo plugged on the left USB, only KB is worked together with switching function. When USB combo plugged on the rigth USB, both KB & Mouse worked...
Unfortunately, this switch has a dedicated port for keyboard that listens for the keyboard keystroke. You MUST plug the keyboard into the dedicated keyboard port on the KVM switch for the hotkeys to work. I recommend putting the mouse that comes with your keyboard to the side, and using another mouse, plugged into the dedicated mouse USB port on the switch. Not the prettiest solution, but some of those mouse/keyboard combos have some funky hardware!
Feb 17, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
I just buy a4 tecch keyboard (X-slim multimedia) and PORT USB doesn't work... Pleace help me
Hai,
If your keyboard has PS/2 port you have to purchase PS/2 to USB converter and then attache it to your keyboard. Then in your BIOS you have to confirm whether USB keyboard is available and it is enabled or not. If not you have to enable then your USB keyboard works.
Regards
Dec 28, 2009 | A4tech A4 KL-23MU X-Slim multimedia PS/2...
My computer only has usb connection for keyboard. The keyboard does not work during start up, therefore I cannot connect to bios or setup. How do I resolve this issue?
try putting your usb keyboard in another usb slot and see if it works. If not get another USB keyboard and use that. Also make sure other usb deives are working so you know its a keyboard issue and not a usb issue.
Sep 13, 2009 | Dell Dimension E521 PC Desktop
Windows Vista, my keyboard stopped operating. I changed the old keyboard with a different keyboard that was working on another computer. Now that keyboard will not work on either computer. HP was NO h
What type of keyboard are you using? Is it a PS/2 or USB type of keyboard? If it's a PS/2 keyboard (with round purple connector), you may need to restart the computer after connecting it to the computer. But if it's a USB keyboard, there's no need to restart the computer because USB is just a Plug-n-Play device.
You need to isolate the problem. If you're using a USB keyboard, try connecting the keyboard into different USB port of thecomputer. Or try different computer to see if the keyboard is still functioning or not.
If you got the same problem after pertorming some test, it's better to consult the computer manufacturer for second opinion.
May 30, 2009 | HP Computers & Internet
Trying to install windows and at the boot screen have my keyboard and mouse plugged in windows doesnt see it.. I tried the USB keyboard and nothing I just recently replaced the MOBO using anti-static wrist...
I have seen this before, and the best answer I can offer you is some Motherboards are better than others when working with usb devices while no OS is in place. I actually tried using usb / to / ps/2 adapters and it still would not recognize the usb keyboard in a couple of instances. I had to get a ps2 keyboard for the installation of windows. After windows was installed I hooked up the usb keyboard and it worked fine. (just speaking from my own personal experience here)
Sorry I do not have a more technical answer for you but I'm almost 99.9 % sure this should work, providing there is no problem with the ps2 keyboard port on the Motherboard. I have never failed to install windows unless there was another hardware based issue of some kind, but never a problem with a known good ps2 keyboard.
Just double check everything is seated properly and try to get into the bios setup, if you cannot use the usb keyboard for this, you can try the usb / ps2 adapter, but if that doesn't work either then use a regular ps2 keyboard. That should work fine, then after setup is complete, windows is installed, then your usb keyboard should work fine.
Mar 03, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
BIOS not reachable due lack of PS2 or USB keyboard
just to clarify, your system works well with USB keyboard but doesn't with PS/2.
Jan 06, 2009 | Asrock P4i65GV Motherboard
Keyboard not working
Minimal information to go on. Since you didn't specify whether this is a laptop or desktop, I'll respond with the assumption that it's a desktop.
Power off computer.
Install new (known working) keyboard.
If that doesn't correct the problem, your issue is probably with the PS/2 or USB port your keyboard is plugged into.
If you are using a USB keyboard, first try moving it to a different USB port, then booting. If that doesn't help, try a PS/2 keyboard.
If you cannot get a known good (working/new) PS/2 keyboard to work in replacing a PS/2 keyboard, try a USB keyboard.
Jul 22, 2008 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
46 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
