Question about Toshiba Satellite A215-S7437 Notebook
Keyboard and mouse will not work
When I boot up my laptop, the OS works fine. But when my log-in screen comes up, the mouse and keyboard will not move or work. I tried to restore to out-of-box state will no effect. Help someone
  • tbbeckham Apr 28, 2010
    ok now the keyboard and touch pad work...but windows will not load. just says windows can not configure to work with the hardware.
  • 157 Answers
Sounds like you have some corrupt files. Here is what should help you.
Use your restore disk, or if you have a Windows OS disk, bootup with that.
When you see the screen that gives you an option to "Repair Windows" hit the "R" key. You will be taken to a DOS prompt. Choose the Volume you want to repair (Usually number 1) then it will prompt you for an Administrator password. If you have never put one on the system, simply hit Enter. The it will take you to "C:\Windows" Type in the following...
"CHKDSK /R" (without the quote marks and hit Enter. Let chkdsk utility see if it can repair the volume. It will prompt you when it is finished.
Posted on Apr 28, 2010
Lenovo R60 freezes and no response from mouse or keyboard
1) try to RESTORE to some point where the computer was working.
2) Update the BIOS +CHIPSET and RUN it.
2a) see if working. If NOT working go the step #3
3) update the USB driver from the supplier company.
4) updae the driver for keyboard +mouse , uninstall and reinstall.
God bless you
Oct 18, 2012 | IBM Lenovo ThinkPad R60 Notebook
It comes on but the screen and keyboard dont help
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode
Click start control panel keyboard hardware make sure you have the right keyboard selected
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver
hope it helps
May 29, 2012 | HP Computers & Internet
Keyboard and mouse not working when booting into OS
i feel its like an virus prblem.. but first you have to try and clean with an bootable antivirus kit.. first
Sep 27, 2009 | Micro Innovations PD7250LSR Wireless RF...
I have keyboard and mouse does not work and usb port too
Does the keyboard respond upon system boot. It should.
Press F8 repeatedly until you come to a black screen with text and select command line with safe mode or command line depending on the type of operating system you have.
If it is Windows XP, type in the command prompt: c:\windows\system32\restore\rstrui.exe and restore windows to a time when it was working properly.
If it is Windows Vista, type c:\windows\system32\rstrui.exe.
Jul 25, 2009 | Computers & Internet
MOUSE PROBLEM
run a virus checker through i had the same problem with the moving mouse thought i had a good virus checker but somehow it got through hope this helps regards Jim
Apr 23, 2009 | Computers & Internet
Dell Dimension 3100 e10 ...usb won't work
Does the system respond to boot keys (F2, F12) when the DELL logo appears? If so the problem is with Windows drivers and probably can be resolved by reinstalling or rolling back the drivers, but how? Do you have access to another keyboard? Does the system have PS/2 ports? Do you have access to a PS/2 keyboard or adapter? If boot keys work, you could also choose F8 for Last Known Good Config (XP) or System Restore (Vista).
Have you tried different ports (front if using back or visa-versa)?
Try using just keyboard or mouse to see if one has somehow shorted. Also check the ports for any sign of damage.
Jan 10, 2009 | Dell Dimension 3100 PC Desktop
Mouse or touchpad not working
add an external mouse/keyboard to fix the onboard fault.
check the device manager for any yellow exclamation marks. as there may be a faulty or corrupt. keyboard/mouse touchpad driver.
other option, is to add remove touchpad drivers, and re-install.
finally, you could check if the settings are correct in the bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 05, 2009 | Toshiba Satellite A105 Notebook
Recovery of xp
The safemode may not be accessable probably because you have the Other Gadgets connected to the comp.
Turn Comp off...
Remove every thing(except Keyboard,mouse,monitor& power.)
Then Keep Tapping F8 to enter "advanced screen options menu".
***If the safemode would not enter then enter the safemode with command Prompt.
***Log on to your computer with an administrator account or with an account that has administrator credentials.
*** Type the following command at a command prompt, and then press ENTER:
%systemroot%\system32\restore\rstrui.exe
if all this do not work and the OS is an OEM then the manufacturer of this computer should have a to Recovery the OS by formatting the comuter.
Jul 18, 2008 | Medion Computers & Internet
My Keyboard and mouse are not responding
try plugging in an external keyboard & mouse, hopefully that should work
Sep 15, 2007 | Acer Aspire 5100 Notebook
Toshiba Satellite A215-S7437 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
