Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Makesvery little ice - Samsung RF265AA Bottom Freezer French Door Refrigerator
  • 311 Answers
Make sure you pull the ice cubes periodically from the back of the ice tray to the front. If the back of the tray is piled past a certain point the unit will think the ice tray is full and stop ice production. This was a design flaw most samsungs. Hope this helps _MJ_
Posted on Apr 27, 2010
1 month old Samsung RF28HFEDTSR. No ice in upper ice compartment. All Ice drops to bucket in freezer section. I press reset button it dings and soon one group of ice falls in upper bucket.
I believe something's wrong with your new ice maker. Are you sure that the ice maker is not turned off on the display? And take a little bit of time and go through your user manual if you don't have the user manual let me know I will send you one
http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/1509233L.pdf
Appliance 911 Sea Breeze
Sep 02, 2016 | Samsung Refrigerators
How can I get rid of those nasty little floater in my ice?
Replace your ice maker. Your ice maker mold is flaking and collects into the ice. Good Luck
Aug 12, 2014 | Frigidaire 20.6 cu. ft. Top Freezer...
The ice maker is producing very little ice. How
adjust the tempt of the freezer it needs to be around 0 to 5 deg .. . also ck the food around it as it may be blocking the air flow to ice mker .. mm
Jul 01, 2010 | GE PFSS6PKSS
Frigidaire FRS26ZNHD2-ice maker stopped making ice called Frigidaires 800# they told me to replace the 2 stage water valve did that still no water to ice maker
ice maker is bad has it,s own timer built in to let water in if you have water to your unit ,,, be sure the little lever is down on top of the ice bucket. if it is up this will stop the ice making process this i s a device to keep the ice from over filling the ice bucket
Mar 29, 2010 | Frigidaire FRS26R4A Side by Side...
Little door that lets ice fall into glass won't
need to check door chute hinge it could be broken
Nov 05, 2009 | Kenmore Refrigerators
My kitchen aid refrigerator model KSB251NBL..NO ICE
Problem could be a couple of things.One There is a little control in the very back,its should be on the lower right side looking at the freg. from the back.It has a water line running up to the ice maker.If that is ok,you will need to replace the ice maker.It is not a big problem on either.Cost is for the little controll about $30.For the ice maker about &90.
Aug 29, 2009 | KitchenAid Refrigerators
GE Bottom freezermakes little ice
The ice maker has a temperature sensor inside that lets the ice maker know its time to drop the ice and refill with water. That could be the problem or the water control valve for the ice maker is not opening when its called to refill the trays. I will try to help you, Sea Breeze
May 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker is crushing ice when cube ice button is on
We've had a similar problem, possibly the same, with our LG in-door ice maker. Whether cubed ice or crushed ice is selected, it crushes the ice.
We found that there is a little lever on the inside of the door, on the lower right behind the ice bin, which freezes in the down position. This is a literal "freeze up", as a block of ice forms in the little well under this switch and eventually freezes the switch in place. Since the switch needs to go up to provide cubed,.. we only get crushed. On 3 separate occassions we've thawed and chipped out (carefully) this little ice dam and gotten cubed ice capability back for a few weeks. At which point it freezes again. I have no idea why water collects there in the first place.
Feb 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
My fridedaire side-by-side only gives crushed ice even when cube ice button is chosen
take the ice bucket out of the freezer
from the back of the ice bucket, there is a little metal bar that stickes out (back left bottom)
that little metal bar inserts into a hole with a spring loaded 'up/down' mechanism...this is stuck UP, and needs to be jiggled with your finger to spring down.
Once that mechanism inside the hole springs down, the ice maker will go back to producing whole ice cubes.
Oct 04, 2008 | Refrigerators
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
151 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
