Question about Samsung HL-T5076S 50 in. TV
Samsung 56 in dlp shuts off
Ok i replaced a bad bulb about 1 month ago no problem, tv worked fine, now it just turns off every half hour. i opened it up and cleaned it out for the second time. same thing happened it turned off.also checked the blue switch and it seems to be working fine so i dont think its anything to do with the blue switch when it does run for the half hour picture is great colors are great before i burn this thing help me both fans are running and the heat sinks are clean
    Guru:
  • 416 Answers
You need to eliminate the lamp door (blue) switch from the equation. Wrap the wire (blue/white) around in for the moment to lock it in an up position. Also, have a look at your lamp ballast (see picture). Look to see if the capacitor is swollen on top. If it is, change the ballast and power supply.
Posted on Apr 27, 2010
My Samsung dlp hlr5667wx/xxa has a signal intermittent problem through antenna connection and hdmi connection. what could this be? the light bulb and color wheel has been replaced 6 months ago. the...
Bad smd capacitors on the digital board. There are many and unlike regular capacitors are small and hard to replace. May just want to get a whole new digital board. Try Encompas parts.
Nov 04, 2011 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HLN5065W tv Black & White Picture
Yes,the problem is the colors wheel it dead.That one of the cause by the colors wheel,other are alots of squiling noises and making very loud buzzing sound.The cooling fan that u think is overheating,does it stop sometimes,when the tv is still on?Yes,than replaced it also,no than it still ok.Just hire the tv repairman,the parts he'll take care of it,don't order the parts,u might get the wrong parts or different sizes,that will not fit in ur tv.
May 23, 2010 | Samsung DLP HL-P5663W 56" TV
Buzzing sound on samsung
it sounds that u have a color wheel problem my friend
Jan 19, 2010 | Samsung DLP HL-P5663W 56" TV
I have a 56" DLP Samsung (HLR5668W) Right side goes solid black
The color wheels will never fix an issue like that. The only things that will cause that issue is a bad DMD board which is part of the light engine or the digital board which is not. Freak Squad need to replace the digital board.
Sep 10, 2009 | Samsung HL-R5668W 56" HDTV
Samsung tv is shutting off by itself.
Your DLP bulb is going bad. Get a replacement bulb (about $280 if not covered by warranty) and your problem will be fixed. If not, it will eventually stop working.
Sep 08, 2009 | Samsung DLP HL-P5663W 56" TV
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-R-5667W lamp LED comes on solid, no picture, then turns off
DO you have the owners mannel if so read it and see what they would do ,have you removed the lamp and if so how did it look? some lamps only last for 5,000 hrs and others 8,000 hrs If lamp is bad TV will not come on.
Feb 20, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung hln567w dlp tv
after 3 years it is a good chance that the lamp is going,,however if it plays its melody when it turns off there is a possibility thateither the lamp door switch or the thermostat are failinf
Nov 28, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HL-T5076S 50 in. TV Logo
300 people viewed this question
Jerry Greenberg
Jerry Greenberg
