Question about LG WM2487H Front Load Washer
LG front loaded washing machine vibrates during
LG front load washing machine vibrates during spin cycle. I've level the machine numerous times, installed additional rubber pads under legs, lowered adjustment legs while leveling to the lowest position.
Still vibrates, any suggestions?
  • 311 Answers
If its on a pedistal then that will raise your center of gravity and cause the unit to be less sturdy during a spin. It could also be due to a weak floor. You may want to try a product called "shake away pads". The probably sell them at like home depot or lowes. They will run you about 40 bucks but they just go under the legs and help absorb some shock. Good luck _MJ_
Posted on Apr 27, 2010
Vibration during spin cycle
you can get settee foam the square type and stuff it down both sides on the in side make sure its not going to touch any electric bits i did this to mine works a treat
Oct 19, 2012 | Maytag Washing Machines
Maytag Washing Machine Out of Balance Even When Empty
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
May 15, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
Apr 08, 2010 | LG WM0642H Front Load
I have a Maytag 3000 washer and I have adjusted the feet numerous times to keep it from walking. Do you have any suggestions? The floor is good but likes to walk during spin cycle.
did you level the unit first as per owners manual, then after its level did you turn the "jamb huts" on the legs with a 9/16" open ended wrench above the feet up against the cabinet bottom?,if you dont do this step the vibration in spin will turn the legs again and un-level the unit
Feb 21, 2010 | Maytag EPIC MFW9700S Front Load Washer
LG WM0532HM is level but make my house vibrate Can anyone help?
Put 5 or 6 bath towels on a quick wash cycle.
During the spin cycle adjust the feet on the washer to smooth out the vibrations. Some times you only have to adjust one foot on the front to make a big difference.
If you have a pedastal snug up the washer feet to the pedastal then proceed above.
The washer came with a flat silver wrench to adjust the feet.
Jan 16, 2010 | LG WM-0532HW Front Load Washer
Washer vibrating badly
Hi, Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion......
Jul 19, 2009 | LG Washing Machines
Washing machine has a seizure during the spin cycle.
Try leveling the washer so that it is about half a bubble biased towards the rear. This usually helps front loading washers balance properly even if the installation instructions say that it should be perfectly level. This can also aid draining problems.
Also, some newer front loading washing machines are simply prone to dramatic vibration even when they is "anti-vibration" or "vibration reduction" systems. You can never go wrong installing an anti-vibration pad under the washer. Good Vibrations Inc, Kellett Enterprises and The Vibration Solution all have good products. The Vibration Solution seems to have figured out the best solution and offers excellent support and return policies.
Washer anti-vibration pads
If all else fails call the retailer and ask for an exchange.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 13, 2008 | LG WM2688HWM TROMM SteamWasher
LG1812CW Walks During Spin Cycle
The rear 2 legs are fixed. The front 2 are adjustable. There are lock nuts to prevent the adjustment from coming loose. The front legs are to be adjusted to the minimum. While not running if the machine rocks, continue the adjustment. For few clothes there is a half load switch; best the read the manual well before anything. Well if the walking continues, check the rear for any shocks or springs that may hv fallen off during transport. Plug off the wall socket first.
May 28, 2007 | LG WM1812C Front Load Washer
LG WM2487H Front Load Washer Logo
353 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
