Question about Philips 46PP9302 46" Rear Projection Television
Am i going to need the original remote for my panosonic projection tv to do the convergence repair? In other words should i not order the repair kit unless i have the remote?
  • Philips Master
  • 8,457 Answers
Most of the time,the convergence reset itself,after the Convergence ICS are change.But sometime seldom,u need the original remote to make minor adjustment.
Posted on Apr 27, 2010
Tv screen
Ur tv have convergence problems,it dead.U must know how to solders?U must repalced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-$350 for parts and labors.
Apr 23, 2010 | RCA HD52W59 HDTV Projection Television
Tip
Am i going to need the original remote for my panosonic tv to do a convergence...
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on Projection TV sets and a fairly simple DIY fix.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
47a7bc4.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from TvRepairKits.com
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
BEFORE
Set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
AFTER
724bcba.pngSolution #2 - CRT FLUID FIX
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
on Apr 27, 2010 | Philips 46PP9302 46" Rear Projection...
The red bar is falling from th etopof the screen
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a Sony convergenece repair kit from the link below.
  • Screen looks 3D
93a1209.pngCONVERGENCE SOLUTION
Their kits include a step by step instruction guide, original OEM Sanyo2_bing.gif STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
BEFORE
AFTER
93a1209.pngSolution #2 - CRT FLUID FIX
Feb 14, 2010 | Sony KP-65WS510 65" Rear Projection...
Convergence wont align on Magnavox 51MP392H/17
You will need the original remote to perform a convergence touch up on Magnavox TV sets. If you are using the original remote - but still can't get it working - go back to the site where you purchased the tv repair kit and ask for their help
Feb 06, 2010 | Philips Magnavox 51MP392H Rear Projection...
Red ghost images
Yes there is a repair kit for your model which contains the two Convergence ICs and the 6 feed resistors. The kit alkso has step by step instructions with pictures so you can easily do the repair. Heres the link for the correct kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
Jun 01, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Sony KP -46WT510 Convergence Problem
Yes - If you are failry handy and take your time its a DIY project.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Apr 19, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence. seeing three colors at once
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 07, 2009 | Akai PT4799HD Rear Projection Television
Bowing at top and bottom, can't adjust convergence replaced IC
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Mar 22, 2009 | Toshiba 57H81 57" Rear Projection...
Panosonic hd tv projection tv
Just click below for convergence repair kit;
The 3 blinks symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-150ICs and it's associated resistor,this resistor automatically chagne value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm Hope this may help you; Regards, VOTIT DON'T FORGET TO RATE;
Sep 05, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Hitachi 50" 50GX30B PJTV
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Using your original remote go-to the tv settings then goto the convergence or magic focus section
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Oct 20, 2007 | Hitachi 50UX57B 50" Rear Projection...
Philips 46PP9302 46" Rear Projection Television Logo
180 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
