My shredder was working fine. I removed the shreds of paper that had gotten stuck underneath. It now works on "Rev" but not on AUTO ???
I have the same problem
Posted on Apr 28, 2010
My shredder won't shred
If the motor will not run, then probably there's paper clogged in the shredder. Turn over the shredder, after unplugging the power cord, and remove the papers.
If the motor will run but not shredding any paper, then the drive gear has broken teeth. This is not usually worth fixing.
Hope this helps.
Mar 27, 2015 | Shredder Office Equipment & Supplies
Reverse works fine, but I cannot get it to accept new paper to shred
Your Fellowes p600c-2 shredderappears to have the same problem I had, it would run in reverse but would not shred new paper. I removed the 6 screws that are visible on the top assembly, but could not get the top assembly to come apart. There is a seventh screw hidden under one of the adhesive labels. I removed that screw and was able to disassemble the shredder. The plastic trigger mechanism that starts the shredder when paper is put in was stuck. I freed the trigger mechanism and reassembled the shredder. Now it works fine.
Oct 01, 2010 | Fellowes P600C-2 Shredder
Jammed in Auto, but works fine in reverse. How to unjam?
Continue to alternate between auto and reverse a number of times. Try to shred narrower pieces of paper at opposite ends to see if it can trigger the auto trigger wire. All else fails, carefully take the shredding part apart and you may find a hugh paper jam underneath.
Sep 02, 2010 | Aurora Electronics AS662C Shredder
Ativa X1000 paper shredder that doesn't turn on
took the shredder section apart, cleaned out the gears of paper and a broken mount (plastic piece), and hand turned the electric motor to free it up. After assembly, the ready light works and so does the FWD/REV directions for shredding.
Nov 10, 2009 | Office Depot Ativa DQ60M Shredder
Paper shredder not working
sounds like the cutting wheels have something jammed inside them , can you take it bak and return it ? or open it up and see if anything looks bad inside ?
Jan 07, 2009 | World Office Products Papermate PM-600C...
Will not shred will go in Rev
I just fixed a similar issue. My AS702MX shredder fell off my desk while I was emptying the basket. When I tried to use it after that it only ran in reverse, not in auto/forward (it was not jammed). This meant that the motor was still working. Since this shredder is so old, no longer under warranty, and not working anyway, I decided to open it up. I unscrewed the 5 screws on the bottom (that's all), then the plastic covering opened up. While looking at the shredder from the top (without the plastic cover) you will see a small black plastic trigger mechanism in the middle (this is what the paper hits to start the shred) this piece will push a copper filament onto the motor to complete the "auto" circuit. Well the fall had caused the plastic trigger to dislodge on one side... I popped it back into place and closed it up, and its working fine now. It was really simple to fix.
Aug 04, 2008 | Aurora Global AS702MX Shredder
Shredder won't shut off after paper goes thru
Note that the sensors that tells the shredder to stop are underneath the unit.
Pull out the tray, put the unit on the side and you'll see two places where there are two flat-head phillips screws holding the optical sensors in place (no need to unscrew them). Just wipe the visible part of those two sensors with a rag.
The sensors that are readily visible on top of the unit tells the shredder when to start.
Aug 29, 2007 | Fellowes DM15C Shredder
Shreader won't turn off.
The paper sensor is stuck, actually a pretty common problem with many auto shredders. Basically the sensor for auto shredding thinks that there is still paper in the unit so it won't shut off. This can easily be caused by shred debris. Shooting some compressed air into the unit may help but usually it requires a bit more effort. Sadly, these guys can be quite hazardous to repair so I would not really suggest trying to open the unit unless you really know what you are doing.
Aug 18, 2007 | Fellowes Powershred 220CC Shredder
Shredder
Check for stuck paper and remove if any. Then check if motor is ok with a multimeter and also main switch.
May 20, 2007 | Aurora Global AS501X-MS Shredder
53 people viewed this question
jasbo
jasbo
