Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
Drive making a clicking noise and not mounting
  • 119 Answers
Not good... Sounds like a hardware failure in the drive. That clicking sound is the solenoid inside the drive. Hope its under warranty.
Posted on Apr 28, 2010
How do I stop the front disc brakes from clicking on my 95GMC g3500 Vandura.
YOU NEED TO REPLACE THE HARDWARE . THE LITTLE CLIPS THAT MOUNT ON THE CALIPER ARE LOOSE ALLOWING THE PADS TO CLICK
Dec 19, 2014 | Cars & Trucks
1998 land rover discovery transmission makes loud banging noise when shifting from pari to drive?
Tons of possibilities here (transmission, differential, motor mounts, transmission mounts....), so I'll ask some debug questions to help narrow it down. Does it make the noise when shifting into reverse? Also, does it make the noise only when shifting from park, or also when shifting from neutral (into drive or into reverse)? Did the noise start as an occasional, softer noise and get worse over time, or did it start suddenly? Does the vehicle lurch at the same time as the noise? What happens when you go from Reverse to Drive, or vice versa? Has any work been done recently (brakes, tires, alignment, suspension, transmission)?
Jul 20, 2014 | Land Rover Cars & Trucks
Clicking noise, won't mount
the controller on the external drive could have gone bad. i would first try removing the hard drive from that external enclosure and use a usb or esata dock and see if itll mount.
Nov 26, 2013 | Fantom Titanium Hard Drive
Transmission mount might be broke
Yes that sounds like it could be it, or possible an engine mount also. Good luck
Oct 22, 2012 | Toyota 4Runner Cars & Trucks
It is making a loud clicking and beeping noise and it won't mount to my macbook.
Loud clicking usually means that the device has failed mechanically. You could try connecting it to another computer, but it's most likely a dead drive. Sorry for the bad news. Steve.
Jan 12, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
Makes "clicking" noise and will not mount
that is a common noise when your HD just failed it can be internal or external most of them work the same way, there is 2 metal readers that hover on top of the actual disks to read the information. Those readers get stuck or keep going back and forward trying to read (that is the clicking noise) a way to try to fix the problem (it works sometimes) is replacing the circuit board attached to the hard drive (inside the metal enclosure) and you have to find one with the same characteristics as the one you have now. sometimes when we really need to recover the information we try that and it may, may not work
if it works for you, don't forget to rate me
thx
Jun 03, 2010 | EZQuest Cobra Plus (B12660) 120 GB Hard...
Same clicking Problem
Glad you worked it out cheap switch mode supplies can make a clicking noise when pooched. Now if the hard drive itself makes that noise you are in trouble. Almost any replacement power supply will do so long as it is capable of delivering not only the correct voltage but the correct current as rated in "mA" milliamps or "A" Amps.
You can of course exceed the current rating and quite often that can be a good thing to do as it may well prolong the life of the supply even if it may cost a few pennies more.
I can usually judge a good supply by its size and weight VS its power ratings. I like em large and heavy
Aug 11, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Buffalo External Harddrive problem
check the connections for abnormalities, then attempt to mount the drive to another system to determine if the problem is with the drive or system
Jul 01, 2009 | Computers & Internet
Car is messed up someone please help!!!!!!!!!
The first problem sounds like a engine mount has broken. the loud click sound seems like it may be some sort of bearing going or injectors knocking or valves knocking
Jun 03, 2009 | 1993 Oldsmobile Cutlass Ciera
HDD keeps clicking
The clicking noise is the sound of the read/write heads going to the home position. The arm or bracket the heads are mounted on make the noise when they hit up against the equivalent of a *door stop*. This is the drives attempt to reorient itself when it can read something where it expects to find it. As you have guessed its probably a mechanical fault and definitely not repairable.
Jan 07, 2007 | IBM TravelStar 4GN 4.32 GB Hard Drive
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
710 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
