Question about Actiontec GT701C DSL Modem
Connecting more than 1 desktop.
I want to connect a 2nd computer to my GT701C, is it possible?
  • 1,606 Answers
This is what a router does. The wire that now goes from the computer to the modem goes to the router into the port marked wan. Then you plug your computers into the ports marked lan. On a typical router you will be able to connect 4 computers. They will all be able to get out to the internet and will be able to see and share files from each other. You should be able to find a router for $20-$40. Then you will want to figure out where to run the wires so you know if you need to buy cables and what length they need to be.
If you want to spend a bit more money you can go wireless. This will mean buyng a wireless router instead of a wired. (the wireless does wifi and still has the 4 wired ports) and then you will need a wifi network card for each computer. Most laptops have wifi built in so no need to buy anything for them. Wifi is nice as you don't have cables to worry about or trip over and you can move around the house. If you have a laptop you can wander around the yard. Very nice to go out and watch movies etc in the back yard some days.
So to get a wired setup you wil need a wired router, and two cables. For wireless you need a wireless router and wifi cards for each device if not equipped. The wired setup is faster and cheaper but more of a fixed location setup. The wifi seup costs a bit more, is about 1/2 to 2/3 the speed but gives you a bit of freedom to change or move.
Posted on Apr 27, 2010
When i on my desktop it show blue screen and says no signal analog
That means that the monitor is not getting a signal from the computer. There are several possible issues involved. 1) Make sure that the computer tower is on. 2) Check that the video cable is connected to the active port on the desktop. (Computers often have video connections on the motherboard and an added video card. The motherboard connection is disabled when the video card is active. Similarly if there are several ports (VGA, DVI, HDMI, Display port) only one may be active.) 3) Try a new video cable (if possible) and one of the other video ports (again if possible). 4) Try connecting a different monitor to the computer or connecting this monitor to another computer.
Open up the computer and check if the card requires a separate power connection to the power supply. Make sure it is plugged in. Do the fans in the computer spin up?
If a second monitor doesn't work or the monitor works on another computer, then the problem is with the video adapter on the computer, the power supply or the power switch. Please add a comment with more information about the type of desktop and the current video graphics adapter (on the motherboard or separate card). I will provide additional help if possible.
(who has a computer in the company that needed a new monitor (power supply failed) a few months ago and lost the fan on the video card last week. Without the fan, the card overheated and shut down. Thus no signal to the monitor.)
Oct 02, 2011 | Computers & Internet
Tip
How to Reset Your BIOS
*Power down your PC.
*Remove the cabinet cover
*Find the 3-pin jumper near the power supply on the motherboard, typically labeled "clear cmos" or "reset bios".
*Remove the jumper from the default position (typically connecting the 1st and 2nd pins).
*Replace the jumper to connect the 2nd and 3rd pins.
*push the power button of ur pc once
*After a min Return the jumper to its default position, connecting the 1st and 2nd pins
* Turn on the PC now,
on Oct 25, 2010 | Computers & Internet
Laptop connected to projector get initial message "no signal" then projector continually searches through video, computer 1 and computer 2 - what do I do?
Make sure that you have enabled the 2nd screen output from the laptop. It sounds like there is no signal at the input of the projector. You can check this by connecting a monitor to the 2nd output of the laptop. Often you have to press one of the function keys (F5 possibly) to enable the 2nd screen from a laptop.
Feb 01, 2011 | Hitachi Performa CP-RS55 Multimedia...
1) difficult connecting to yahoo, computer slow
sounds like virus or spyware at first. get microsoft security essentials and scan you PC i bet it's riddled
the PC should power off if you hold the power button in for 4-6 seconds, rather than use the switch at the wall
Jan 13, 2010 | Computers & Internet
Can't print from local printer using remote connection
To print the reports on your local printer, go to
1.Start->Run->
2.Type 'mstsc' and click 'ok'. A window pops up for Remote Desktop Connection
3. Click 'Options' button and select the 'Local Resource' tab.
4. Select the checkbx 'Printers' from the 'Local Device'
5. Click Connect.
Aug 20, 2009 | Actiontec GT701C DSL Modem
Desktop wont connect to internet but laptop will!
repair the conection and also try a diffrent ethernet wire sometimes it could be bad
Jun 05, 2009 | Actiontec GT701C DSL Modem
Wireless adapter on 2nd computer is not connecting to my router
you put in the usb port then install the driver then you find it the wireless icon will came in the task bar right hand side in bottom then you right click on it then you got the option view viable networks click on it then you got the your ssid name just connect it then surf it
May 13, 2009 | NetGear WGR614 Router
No connectivity to 2nd desktop or laptop - although worked before
Hello....sudden loss of wireless on two computers, in the same home, may indicate that a powerful source of wireless interference has just arrived (since your wireless router light is still on).
1) Does the signal improve if you move the router, or move the laptop closer to the router?
2) Have you had any success with changing the channel on your router? (Login to router > select Wireless Settings > Channel)
If you have not moved furniture yourself, or installed a device which could interfere with the signal (eg a DECT phone), it's possible a neighbour's new router may be the culprit.
Please come back to Fixya if this does not help.
Jan 11, 2009 | NetGear WGR614 Router
I have a 2 year old CTX S760A monitor, when I switch on the computer the monitor switches on and off several times about 25-30 times before stabilising. It works well after that. This has been happening...
First, I would try connecting a different monitor if possible. If the problem persists, it would be a problem with your computers video card. If the 2nd monitor works fine, then your monitor is at fault and may need to be replaced.
Apr 06, 2008 | Computers & Internet
Cant go wireless
1st. check if you have a internet connection.
2nd. you should have a WIRELESS ADAPTER
wireless adapter is your main source for connecting you from wireless connection to your computer.
Mar 27, 2008 | Computers & Internet
Actiontec GT701C DSL Modem Logo
151 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
