Question about KitchenAid KERC700LBS Electric Kitchen Range
Self cleaning does not work
Kitchen Aid " Superba" self cleaning electric range.
When starting the self cleaning cycle for the oven, the door lock and after about 1 minute an error msg appears. It says FS:E1. What does it mean and what can be done to fix this problem.
We pressed the clear button and the door did not unlock by itself, it needed a little bit of help to release the lock so we could open the oven door.
The oven works properly.
  • Coldlake Apr 18, 2008
    Does anyone have an idea of what might be the problem?
    I hope to get some kind help, I don't really wants to call the service tech for this.
  • Coldlake Jun 23, 2008
    For my problem about the self cleaning not working the code is F5:E1 which is "the self cleaning latch won't make" it is out of the troubleshooting book. The field service action ask to "check the latch system" How do you check the latch system?
  • 15,935 Answers
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$$$$
Posted on Oct 01, 2010
SOURCE:
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
Kitchen aid gas range KGRS807, 901 or 907
The only time that the oven door should be locked is during the internal "Self Cleaning Cycle," due to the high temperatures used. Make sure that the display does not indicate that the oven is not in it's self-cleaning cycle, and try wiggling the door slightly to see if you can dislodge the sticking lock pin.
If this does not help, then I suggest that you Call the KitchenAid Customer eXperience Center toll free: 1-800-422-1230
Aug 30, 2015 | Kitchen Ranges
Gas range oven door with not open
Your self cleaning cycle is running. When self cleaning is running the door is automatically locked and will not unlock until the self cleaning cycle completes or self cleaning is turned off. You should be able to just turn off the self cleaning cycle and the door will unlock. Do not try to pry open the oven door. You will just damage the door and/or the catch.
Oct 15, 2014 | Amana ARGS7650SS Gas Kitchen Range
The self cleaning oven cuts off before cleaning cycle. I push the self clean button after locking the oven door: the bell dings several times and the self clean cycle cuts off. This is a new stove--what...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 09, 2010 | GE Spectra JBP78 Electric Kitchen Range
When I set the self-clean cycle, all seems to be working - the light goes on, door locks, but no heat. Fuses appear to be okay.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
Sep 26, 2010 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Can not open the door of the self- cleaning electric Range after cleaning operation
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures
Mar 11, 2010 | Kenmore 99123 Electric Kitchen Range
Kitchen aid double convection oven - glass needs cleaning!
Had to remove the screws on the BOTTOM of the outside door, then panel came off after all the screws (inside oven door included) were off...
Reversed the order to put back on.. Cleaned (all) three glass pieces nicely... Now after reading the problems with the self cleaning part (doors getting stuck!) - I'm afraid to try mine!
Jan 22, 2010 | KitchenAid KESC307 Electric Kitchen Range
PUT THE OVEN ON SELF CLEAN AND IT DIED
the operating feature i that it will not let you open untill the oven has either fineshed cleaning or the oven has cooled off
Oct 29, 2009 | KitchenAid KESC307 Electric Kitchen Range
How do I unlock the oven door?
If the lock is engaged, is the oven in a self cleaning cycle? If so, cycle power to the oven, that should cancel the self cleaning cycle.
Reply back if that worked or not and I'll try to help you further.
Jan 24, 2009 | Frigidaire FEF352 Electric Kitchen Range
Self Clean does not work
heatman101
Oct 30, 2006 | KitchenAid KEBS177 Electric Single Oven
KitchenAid KERC700LBS Electric Kitchen Range Logo
314 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
