Question about LG LMVM1935 Convection/Microwave Oven
I have this unit and it just stopped working. NOTHING! NADA! My wife said the circuit had flipped but no one was cooking anything at the time. Do these things just short out? Lights, fan and microwave oven out. Thanks in advance for any advise or help.
  • 5,911 Answers
If the model number is correct, there is a 125V, 20 AMP line fuse inside the microwave. Its usually mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven, UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at searspartsdirect.com based on the model number you listed this question under:
http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2f50026410-00007.png
The line fuse is listed as item 8 (part number 3B74133K). There is a another fuse listed as item 2 (part number 3B72974C), but this is a thermal fuse for the fan motor.
You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended. If you wish to order on line, use the part numbers to search by comparison as the model number you listed this question under is not available at all the websites I have provided. The parts, however, ARE listed.
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit. To answer your initial question, "yes", these ovens can blow a fuse by simply sitting idle. This can occur from any power fluctuations, brown outs, voltage spikes, etc. Or, it could be the symptom of a component that may have failed. If you find any of the internal fuses blown and replace it, only to have it blow again, you have a more significant problem than a simple blown fuse.
Posted on Apr 28, 2010
FMV156DCA turns on, cook indicator lights but not cooking, timer counts down fine too
Hello epinvegas - Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, then it sounds like the microwave has a faulty magnetron, wiring failure or control board. Contact a professional to assist with the repairs.
Feb 07, 2013 | Frigidaire FMV156DC Microwave Oven
My new Haier microwave isn't working! I just plugged it in for the first time, and set the clock on it. Then I tried to turn it on. No matter what cook time I enter, and then press start/30 sec., nothing...
When it times down but doesnt heat it is typically a problem with the door switches, especially one you just bought, may have been from shipping . A switch or connection may have been disodged when being shipped to you. Most machines have something like 4-5 wswitches, If 1 doesnt report right it will stiop the unit from running. But since some of them are closed it will accept the programing and try to operate. So a lot of times you get fan running and tray turning but no power to the secondary circuits. You will need to find out who does warranty for them or return it where you bought it as a defective unit.
Aug 14, 2017 | Haier Microwave Microwave Oven
Panasonic Genius Sensor 1300W
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Aug 30, 2009 | Panasonic NN-SN657SMicrowave Oven
GE SpaceMaker JVM140001 just quit
Same thing happened to our unit. My wife had started cooking potatoes and we left house for an hour. Came back and unit was dead, nothing worked. Verified power @ plug. Unplugged, pulled control panel and checked fuse which is mounted @ top of circuit board (will now refer to as CB), back side of interface panel. It passed continuity test. Inspected wiring and was all intact, no sign of burn thru. Varistor visual also looked good, no discoloration or burns. Removed (5) fasteners that hold CB to interface and inspected back side. Noted minor "blackening" @ pin location #1 of the (5) pin plug immediately beneath fuse. Resoldered because connection looked poor. Plugged back in and tested, all features worked correctly!
Mar 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Looks as though thr circuit braker is being reset.
I BOUGHT ANOTHER ONE........................
Aug 27, 2008 | Maytag Microwave Ovens
Micro wave does not work EM-Z2100GS
First you check the fuse at the out put of highvoltage of the transformer. If the fuse is ok, replace the magnetron.
Feb 28, 2008 | Sanyo EM-Z2100GS Microwave Oven
GE Profile turned off as soon as it start
If you can program it and the problem occures when you push START. Then the problem is a door switch, or the control panel not having a completed circuit. Think of your control panel as an off-on switch.COOK, the control panel switches on for 100% of the time programed. DEFROST,The control panel turns the Cook-Relay on for 30% and off for 70%, on, off, on, off,for the time you programmed for DEFROST. This is how it works. There is no lowering of the output. The output is 100% anything other than COOk is done in % of time on, % of time off. This is why you can hear a "Bump" when Defrosting. The "Bump" is the Cook-Relay sending power to the High Voltage Side, 30% on, 70% off.
Jan 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
LG LMVM1935 Convection/Microwave Oven Logo
468 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
