Question about Brother HL-2070N Laser Printer
The printer keeps whirring away.
I reset the printer to get the toner yellow light out of the way. Since then it has been whirring away
Printer has had a drum replaced and the light will not go off.
I tried several times.
  • 655 Answers
Please follow this link:
There is details of your printer error messages and their solutions.
If any doubt or stuck any where please Ask Me.
Thanks
Iqbal
Posted on Mar 25, 2008
  • Brother Master
  • 13,433 Answers
Is ther a error message and witch light / led is on?
Printer Status LED is Red and Drum Light is Yellow
Hi, this error shows when the corona wire is dirty, some times I clean the corona wire with a small screw driver pressing the corona wire down and slide the screw driver to the both sides also once you clean in the up I press from the side and slide the screwdriver after that with a cotton swab with isopropyl alcohol slide from side to side, or replace the drum unit and reset, if you install a new toner, there is a mechanic control for reset the printer toner counter, this only works the first time that you install the cartridges, for example If you install the cartridge in 1 printer and then move to other printer the other printer keep the counter for the old cartridge, if you are sure that your cartridge is new you need to open a return the gears to is original position in order to install in another printer.
Jul 26, 2013 | Brother HL-5240 Laser Printer
Replaced toner and maintenance kit -keep getting yellow lights on exclamation and toner
If the toner and the exclamation lights are blinking yellow after replacing the toner and maintenance kit, then you will need to reset the photoconductor counter. But if the exclamation and the toner lights are steady on yellow, then that means there is something wrong with the toner.
Jul 27, 2010 | Lexmark E260dn Laser Printer
How can you reset a brother HL-5170DN with out the password either with it connected via USB or ethernet i cannot remember my password
You'll need to reset your printer to factory settings. BE SURE TO PRINT A CONFIGURATION PAGE FIRST.
VIA THE PRINTER CONTROL PANEL
  1. Switch the printer off.
  2. Make sure that the front cover is closed and the power cord is plugged in
  3. Hold down the Go button as you switch the printer on. All the LEDs light up. Keep the button pressed down until the Toner LED lights. When the Toner LED lights, release the Go button.
  4. Hold down the Go button until the Yellow Status LED lights. When the status LED lights, release the Go button.
  5. When all the LED's light, the printer will start warming up. The print server has now been reset to its factory defaults.
Nov 02, 2009 | Brother HL 5170DN Laser Printer
Toner exhaust yellow toner
samsung clp color leserjet printer writes this massage toner exhaust yellow toner. i have done the toner refil without the reset chips about two times now and i have been printing for some time now i get the message "toner exhaust yellow toner"
Oct 01, 2009 | Samsung CLP 315 Laser Printer
Printer problems - solid yellow light down on HP P2015
Take the Tray 2 out and check if all the paper guides are moving freely if they are than remove the toner cartridge and check if any toner sensor is not align correctly.
If they are aligned correctly than next to the pickup roller there is a small piece of plastic make sure it should be hanging freely if it is than we need to perform cold reset of the printer.
Switch off the printer press and hold down the go button and switch the printer on keep holding down go button till the time three lights lit up on control panel, as soon as three lights lits up release the go button and let the printer initialise of it s own.
If that doesn't fix than Formatter Board of the printer is faulty.
Logic:
If there is no paper jam and printer rep[orts the jam means either any of the sensors is not aligned correctly and reporting the jam or formatter Board(Motherboard) of the printer is faulty and showing incorrect display.
Thanks and Regards
Apr 20, 2009 | HP LaserJet P2015dn Printer
Xerox phaser 7300 toner cartridge problems
Sometimes on this machine as there is a lot of loose toner around it can cover over the sensors in the machine, what I would advise is to remove all the toner cartridges and check for the copper contacts on both the machine and under the imagining unit (which the toner is placed in). Once you have cleaned that away slowly close the lid and reboot the machine and it should return to normal. Its just toner getting caught up in the sensors. Follow the instructions below, when you remove the unit, lift it over your head to find the copper contacts and clean them, be careful not to spill toner everywhere. Good luck!
Reseating the imaging unit
    Remove the toner cartridge:
  1. Open the top cover.
    caution_image88x30.gif The imaging units are sensitive to light. Do not expose the imaging units to light any longer than necessary to remove it and cover it. Failure to follow these instructions may damage the imaging units.
  2. Identify the color of the toner cartridge to be replaced (Cyan, Magenta, Yellow or Black).
  3. Move the orange lever on the toner cartridge to the right so that it unlocks.
  4. Lift on the back side of the toner cartridge first, then guide the cartridge out of the printer.
  5. Set the toner cartridge on paper to avoid any toner spilling.
    Reseat the imaging unit:
  6. Lift the imaging unit straight up out of the printer.
  7. Line up the guide pins with the printer's frame and lower the imaging unit back into the printer.
    Reinstall the toner cartridge:
  8. Install the toner cartridge by guiding the front onto the new imaging unit first then lowering the back.
  9. Move the orange lever on the toner cartridge to the left so it locks.
  10. Clean the LEDs with the supplied wipe.
  11. Close the top cover.
Sep 06, 2008 | Xerox Phaser 7300DN Laser Printer
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Mar 05, 2008 | Brother HL-2040 Laser Printer
Yellow run out how can i still use printer?
Hi , You can try to do a disable cartridge check in the printer menu? But more than likely in order to get the full printing you might have to wait. Also you should check to see if the toner low message is set to on or otherwise when the printer runs out of ink it stops completly. Good Luck!!!
Nov 29, 2007 | HP LaserJet 3600dn Printer
Samsung clp-510n printer
1 Could be toner on the contacts (inside the printer) that mate with the contacts on the cartrdige.
2 Are you sure they are 510 toners and not 500 ones ?? 510 toners have a chip that identifies the cartridge (Colour, Capacity) and maintains a count of the pages printed.
500 toners have a reset fuse that resets the toner counter in the printer, and a resitor that identifies the capacity
3 Are they new cartridges, remanufactured, or 'home refiled'.
if either of the later two, were the chips replaced ? - if not the cartridge still thinks it has printed its full life of pages.
Nov 28, 2007 | Samsung CLP-510 Laser Printer
Brother HL-2070N Laser Printer Logo
67 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
