Question about Mtd LAWN MOWER PART # 983-04052 DECK Assembly-SD 46" LT
Riding mower mtd lt briggs 12.5hp 38'' cut. model 286707. starves for gas, runs great for about 10 min. , then fuel filter empty sucked dry, takes about 10 min. to fill back up then runs great again. just tried cleaning gas tank and replacing gas cap without any luck. not sure what to do next
  • 86 Answers
Something stuck in the fuel line just before the filter...take all the lines off and blow air thru 'em
Posted on Apr 28, 2010
18.5 hp 42 inch cut, craftsman riding mower loses power after 10 min.
Us start here, remove fuel line from carb. Hope fuel runs out.
Check the direction of fuel filter. There arrows on it. Arrow toward
carb.
Aug 09, 2012 | Craftsman Garden
Stalls after 20 mins. of running fine. (Starving for gas)
From the rear of machine look at the top left of fuel tank for the fuel line.Where line comes out of tank see if it is pinched where it goes down between frame and tank,grab line and see if it moves freely.If that is OK loosen fuel cap after 10 minutes of run time to see if your vent hole in cap is working.These are 2 common problems for the L series mowers.
May 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Briggs and Stratton 20 hp intek runs great idles great but after running for 15 min. it acts like is running out of fuel and dies. it starts back up if you wait a few min.fuel filter new , plugs new air...
Had the same problem with an almost new Craftsman w/ Intek 20.0 HP. Check all the "usual suspects" and had to have a tech come out. He had me start it. It ran for a few minutes and stopped (per usual). He immediately went to the Anti-Backfire solenoid. It is an electrically operated "plunger-style" fuel line blocker. They are famous for going bad. The part is about $65 and its sole purpose is to starve the engine of its fuel supply at shutdown so it won't backfire. If it is disabled, the user must throttle the engine down for 10 seconds or so before turning the key off in order to avoid backfires. Gee... let's see, 10 seconds of my time each time I use the mower vs $65 part ... No contest! Remove the solenoid, take a pair of electrician side cutters and snip off the tip of the plunger and reinstall it. Problem solved ! ! !
May 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Ryobi lawn tractor mtd the problem is it begins
YA IT DOSE THAT WONT STOP IT FROME RUNING SOUNDS LIKE TO ME THAT YOU HAVE SOME TRASH IN THE CARB YOU MAY WANT TO CLEAN IT OUT IT MAY NEED A CARB KIT
Oct 15, 2009 | Briggs & Stratton Garden
Engine starving for fuel, fuel filter very low, almost empty
your fuel pump is diaghram actuated by pulses from crankcase pressure, if you look there is a small tube that runs from pump to valve cover, pull fuel line off carb and have some one crank it over to see if it's pumping. could be pump or blockage between tank and pump, if fuel flow seems good to carb, i would pull bowl off and check for dirt and also make sure anti run on valve, the thinghy that holds the bowl on to carb is opening properly, it should open and close when you turn key from off to run, beyond that it could be you have some water in your gas.
Jun 26, 2009 | Briggs & Stratton Briggs Stratton Intek V...
15.5 ohv briggs and stratton
It could be "starving" for gas, not getting enough gas. Check the plug, if it is white then the engine is running to lean and will overheat. If this is the problem, then the carbertor will have to be adjusted, and or cleaned, or replaced.
Jun 23, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I have a 1977 model 137-495/ 8 hp electric start MTD riding mower with a 38'' cut, my problem is I want to change my oil and I have no idea how much oil I need with the filter.
I take it that the motor is a briggs and stratton?
Briggs makes their own sae 30 weight oil which you can pick up at lowes for 5 bucks or so and it is packaged in a 48oz. container
this is what you need for an oil change and filter,
being this old and 8 horsepower have you located a oil filter?
anyway start with 48oz do you have a screw in dip stick to check your oil or a cap you take off near the base of the motor? if you have a cap you take off then you add oil here until it covers the top of the threads and your done.
if you have a dip stick add 1qt 32oz..then check the level with the dipsticks safe range and adj as needed.
if you cannot find briggs oil then use a reputable brand sae 30 weight
hope this helps you some
Jun 07, 2009 | Mtd Garden
Engine on riding lawn mower surging
Dirty air cleaner.
Clogged fuel filter.
Replace or clean both...
May 29, 2009 | Garden
Mower starts up great and then dies
If it's a briggs engine, sounds like you have water / debris in your carb fuel bowl. Using spray carb cleaner will only work if you remove the bowl and clean the carb jets. Also, you could have water in the gas tank as well. First, remove your air filter, then remove the 3 screws that attach your filter bracket to your carburator and mower. Take off your fuel line at the carb and drain all your gas into a clear jar. If it looks very yellow, cloudy, or see water in the bottom of the jug, change your gas. Using a half inch socket wrench, after gas line is disconnected, remove the fuel bowl and clean with carb cleaner. Also, examine the bolt you just removed. There are 2 jets in the side and one at the end. Using the carb cleaner, make sure they are clean as well. Use the carb cleaner extension tube to spray up inside the bottom center of the carb, where the bolt threads, to clean that area as well. After all this make sure ur float assembly is intact and reassemblt the bowl to the carb and reattach the the fuel line. finish bt reattaching the air filter support bracket makinf sure the gasket between the carb and the bracket isn't damaged.
May 21, 2009 | Mtd 22" Yard Machine Push Mower
When mower gets hot it cuts off crank back up run a min cut off
1 of 2 things happening
first change the fuel filter seams that the gas is vapourizing
If that does not fix it replace the engine coil as it heats up it is breaking down in voltage causing the engine to die
Apr 05, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Mtd LAWN MOWER PART # 983-04052 DECK Assembly-SD 46" LT Logo
801 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
