Question about Goodman Heating & Cooling
Outdoor fan runs on my amana a/c unit but the compressor does not
    Guru:
  • 1,524 Answers
Check for 24V. on contactor coil.
Posted on Apr 28, 2010
A amana French door fridge no fan water or.icemaker lights come on but no fan turning on or cold
Many Amana model fridges have the freezer fan wired through the bi-metal thermostat that is clipped to the evaporator. Either your compressor has a bad start device and that is why it is not cooling, or the compressor IS running and the unit has lost its refrigerant charge. Running compressor with no cooling = buy a new fridge.
Compressor hot, but not running = start relay replacement to get the compressor going. Start Device 8201786
May 13, 2016 | Amana Refrigerators
How to troubleshoot thermostat wiring?
I'm not sure if the thermostat is wired correctly. First, the thermostat is wired directly to the outdoor unit (compressor/condenser unit). It is NOT directly connected to the indoor unit. It connects to a low voltage control panel in the outdoor unit that sends a signal to your indoor fan/evaporator. This wire is called the fan relay switch and physically runs between the low voltage controls of the indoor and outdoor units. If the fan relay is bad it's possible that the unit runs continuously. To prevent destroying your outdoor unit there is a safety feature that prevents the indoor fan from shutting down while the outdoor unit is running. If the indoor fan did shut down while the outdoor unit was running than you would slug your compressor. That is, your compressor normally sees refrigerant gas but is instead seeing refrigerant liquid. That would not be good since this scenario would destroy your compressor. It sounds like a faulty fan relay. The actual contactor portion of the relay is in the outdoor unit.
Aug 22, 2014 | Honeywell Electronic Programmable...
4 ton Amana -heat comes on sporadic in spring and fall (Every season change) Heat worked through 20 degree weather. Thermostat at 74. Today is 100% humidity and 52 degrees outside and heat won't work. By...
Assuming this is a heat pump I'm guessing you have a bad temp sensor. Your outdoor fan is likely controlled by a temp sensor so it only runs as needed during heating. Fan not coming on and compressor still needs cooled therefore compressor protection kicking in?????
Aug 12, 2017 | Amana Heating & Cooling
Amana ptc123 UNIT STOP WORKING
Indoor or outside. Im pretty should the compressor has gone. If you turn it on does the indoor fan and outdoor fan work but not cooling . or does it not turn on at all.
have you checked your fuse box.
Jan 30, 2012 | Amana PTC123B35AE Air Conditioner
My Amana AAC101SRA doesn't cool like it used to. We have cleaned the filter, but that doesn't seem to help. Should we call a repairman or think about getting another unit?
Is the outdoor coil blocked? Is the outdoor coil clean? Is the compressor running when you start unit. When you turn unit off after running it can you hear a hissing sound from within?
Aug 02, 2011 | Amana High Efficiency AAC101SRA Air...
Thermastat is on, fan is running, but outdoor unit is not coming on
By "outdoor unit", do you mean the compressor? The unit you describe is a window-mount, single-piece a/c.
Failure of the compressor could be:
Disconnected/damaged power wires.
Damaged current protector.
Defective control board.
Seized compressor.
Aug 14, 2010 | Amana Comfort Zone 12M32PBEH Air...
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Airconditioner wont come on
Does the indoor blower come on? If not you might have a low voltage problem in your thermostat circuit or blown breaker or fuse for your furnace which energizes the contactor outdoors. If indoor blower runs check if their are any fuses in your outdoor disconnect.
Apr 30, 2009 | Heating & Cooling
I have a Amana air command 80 sse central air unit. The unit is comprised of a big fan unit outside, and a unit in my garage. The big fan stays on even though I turn the thermostat off. Do you know what...
This sounds like your condenser contactor, contacts are stuck. They weld together if an ant or other debree get between the contacts. Turn off the electric breaker to the outdoor unit as if the outdoor unit runs without the indoor unit running you may damage your outdoor unit compressor.
I would suggest you call a service company. The part should run retail @ 30 to 40 dollars then the service call charge. This repair should take less than 1/2 hour.
Oct 16, 2008 | Amana Heating & Cooling
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
