Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
My desktop computer used to be able to recognize my Passport drive. I've had to replace the CPU and Motherboard and reload XP, but now it is having trouble recognizing the drive. Can you help?
My problem was a totally simple one...the connection of the USB cord to the Passport drive just needed to be moved in and out a couple of times and then the computer recognized the drive again.
Posted on May 26, 2010
    Genius:
  • 1,189 Answers
“To install, and Update Hardware, click to open “Computer” from the “Desktop”, check to see if there is a by the ("Name, Passport") or DVD-RW Drive (D :), for external different (E or F:).
I. Look in the “Device: Removable Storage area,” see if the device is present, if so? Do the following: to “setup” the ('player') for “Installation.”
II. Right click on "Passport," or how shown listed, (DVD) “Media Player” select (“Install”) follow all instructions thereafter.
III. If the area is (Blank?), “go to,” and 'click' on the "Start button" click all “Programs” scroll for a Media Disk Player”, open, and do the (“same as above”) for the installation. *Note: “Do the same for “Setup” (above) “Install.”
"Once everything is finished; restart the computer" "Ratings the solution is appreciated, thanks ”
Posted on Apr 27, 2010
I tried to format my 500gb WD passport essential with exfat using windows 7 for my mediastar pvr . Now neither pvr or windows 7 can see the harddrive
Windows 7 does _NOT_ support 'exfat' drives, as you have found out.
You can "format" the drive, to use 'FAT32' or 'NTFS' file-systems.
Dec 27, 2010 | Western Digital My Passport Essential...
My netbook does not recognize my wd
Did it ever recognize it?
Connect the Passport to a different (desktop) computer.
If it still is not recognized, then the Passport has a problem.
Nov 01, 2010 | Western Digital Passport WDXML800UE...
Desktop will shutdown as Windows XP screen comes up. Shuts down while trying to load into all safe modes. The computer is a custom built computer, and I have cleaned the inside of dust, and tried to...
I would start out by getting a power supply tester (which can be picked up fairly cheaply on Ebay) and checking out your power supply. If it is anything deeper than that, I would look into having a TECH look at it since it could possibly be a ground in the motherboard. You may also want to check and make sure that any expansion cards (memory, video) are seated correctly. If you don't have any expansion cards, it may be your onboard video going bad.
Aug 24, 2010 | Computers & Internet
I had to replace the motherboard, now have problems with XP
A few hints where to start looking:
  • Open the Task Manager, switch to the Performance tab and check the CPU load. If you see a constant high CPU usage, switch to the Processes tab and check which process causes the high CPU load (column "CPU").
    Also check the memory usage graph on the Performance tab. Memory usage should be low, let's say around 400MB if not many programs are running.
    In the "Physical Memory" section, check the Total value. It should (approximately) show the amount of memory actually installed.
  • Open the Device Manager (Control Panel --> System --> Hardware tab --> Device Manager).
    If error icons are displayed, try to reinstall the drivers for these devices (download the latest versions from the manufacturer's website, if possible)
  • Open the Event Viewer (Control Panel --> Administrative Tools --> Computer Management --> Event Viewer) . Check all logs for errors and warnings. Try to understand and to solve the problems. Especially pay attention to those that did not occur before the time that you changed the motherboard.
Mar 10, 2010 | ZT Group Cisnet PC Desktop
Dell Dimension 8200 turns off in BIOS
If the dianostic lights A & D are yellow an IDE bus failure has occurred. Reseat the IDE cables at the motherboard and drive(s). If this does not resolve the issue you may need to contact Dell for a motherboard repair or replacement.
Mar 13, 2009 | Computers & Internet
Getting an old Dell Dimension to recognize a WD Passport
In the end, I assigned a different drive letter to the device and it worked.
There's a lot of info out there on how to assign a letter. Here's one link:
http://lifehacker.com/software/windows/change-windows-drive-letters-167525.php
Feb 17, 2009 | Western Digital WD Passport 250GB Portable...
I can't use my external HD
Do you have any kind of security software/firewall installed? It will often block hard drives because it sees them as a security threat. Disable the firewall or security should do the trick.
Oct 19, 2008 | Electronics - Others
Seagate 320g internal hard drive
Hi-
How bout on device manager? right click on my computer icon then go to manage, go to disk manager and check the disk management and configure the new hard drive
hope this helps
Aug 16, 2008 | Computers & Internet
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
174 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
