Question about Rotary Leviton White Commercial Dimmer Switch 800w
Wiring diagram for leviton 806 switch - Rotary Leviton White Commercial Dimmer Switch 800w
Wiring diagram for 3 way 2 socket lamp
Where is the switch located? If you buy a replacement switch at Home Depot it usually comes with a diagram that shows you how to wire it. If the switch is built into the light socket just replace the socket the switch is included.
Jul 29, 2014 | Leviton Electrical Supplies
I have a leviton double switch that i can't get to work. I have 3 white and 3 black in the box
Try the link below for a diagram.
I would think that you have one black feed and two black legs going out, and three common wires that should be wired together with a wire nut. Is this for a ceiling fan with a light? or ?
May 14, 2014 | Leviton 5634 Dual 1 Pole Switch Decora...
Wired in 5224 switch using (1) white wire and (3) black ones and it popped the breaker. I switched the wires and now both toggle switches control same light. The previous switch controlled a light and a...
10-25-12
Copy following link for wiring diagrams for Leviton double switch.
http://waterheatertimer.org/How-to-wire-switches.html#double
Only 3 wires will connect to switch. Not 4
If you blew breaker than you connected Neutral wire to switch.
Neutral wire never connects to switch.
Identify Hot wire.
There is only one Hot wire that carries power to switch box.
This wire connects to one side of device ... which side? ... the side where both screws are bonded together.
Oct 25, 2012 | Leviton Electrical Supplies
I replaced my old 3way toggle switches with the LEviton 5613 3way lighted rocker switches. Wired exactly the way the older toggle switches were wired. Switches work fine just like the older ones but one...
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=4044§ion=10103&minisite=10025
The Leviton page for Leviton 5613 does not have a troubleshoot.
Manual shows simple wiring diagram.
3-way switches will not operate lights if switches are wired incorrectly.
Check your ground wire is connected.
Leviton 5613 series is illuminated.
Check that both switches have 5613 number.
Swap switches and see if problem is inside switch.
Nov 13, 2010 | Leviton 5613-2WSP Grounded Switch
Wiring diagram for Grounding switch with a pilot light. Cat # 1221-PLC
http://www.leviton.com/OA_HTML/ibcGetAttachment.jsp?cItemId=y8QWKImQP7cPVn3GRND9ig&label=IBE&appName=IBE
Jul 18, 2009 | Leviton Electrical Supplies
Rotary Leviton White Commercial  Dimmer Switch 800w Logo
325 people viewed this question
Top Rotary Electrical Supplies Experts
ken skalski
bobalix
Chuck Graybill
Are you a Rotary Electrical Supply Expert? Answer questions, earn points and help others
