Question about Weber Genesis Silver B Grill
Will a propane tank thats not empty and has a new regulator cause a grill not to heat past 350 or so?
  • 140 Answers
No you may need to close your air flow on the burners
Posted on Apr 28, 2010
Genesis Silver B Grill: grill won't heat past 350 or so. put a new regulat...
An odd thing with many propane gas grills is how the regulator functions. If the tank is opened too fast the regulator over-adjusts and delivers no gas. Try this: Turn tank off and open all burner controls. This should clear the line of any gas. Close burner controls and open tank very slow. Now lite and temp should go up.
May 17, 2010 | Weber Genesis Silver B Grill
My q grill is not heating properly. I have a full tank of propane and the grill is clean but the burner is not getting enough gas to heat past 200 degrees
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Mar 30, 2010 | Weber Q Grill
Heats to only 300 degrees? i have replaced everything, sugestions?
This is a common problem with grills purchased after 2001. There is a new safety feature inside the regulator called a 'surge protector'. If you open your propane bottle valve too quickly or if you try attaching a tank with the tank valve in the 'open' position, the propane wants to 'surge' into the grill.
When the propane surges into the regulator (located on the grill hose) the 'surge protector' (inside the regulator) kicks on. When this happens you will not be able to get your grill lit, and if you do, it will be a small blue flame and the grill will not heat up.
So what to do if you trip the surge protector and can't get your grill to light or heat up?
Shut the tank off and shut the valves on the grill off. Disconnect the tank from the grill hose. When you disconnect the tank from the hose you will hear the excess pressure of propane release. This is an indication that you have re-set the regulator's surge protector.
Now that you have deactivated or reset the surge protector, reconnect the tank. Make sure the valve on the tank and the valves on the grill are in the closed and in the off position. After you reconnect the tank to the hose, SLOWLY open the tank valve (making sure the valves on the grill are in the OFF position).
Since you have slowly opened the valve on the tank, the propane did not surge into the regulator and the surge protector did not activate.
Now open 1 valve on the grill and light it. You should get a nice flame. If your grill has more than one valve, open each following valve in sequential order to extend the flames to the other burners.
Thanks for reading and I hope this helps.
Ben Gaetani
Tanks 2 You Propane
propanetanks2you.com
Tanks2youpropane@gmail.com
Mar 29, 2010 | Jenn-Air Grilling
My propane tank was filled but I cannot get a flow from the tank
This is a common problem with grills purchased after 2001 and also with full propane tanks or tanks with excessive pressure in them. There is a new safety feature inside the regulator called a 'surge protector'. If you open your propane bottle valve too quickly or if you try attaching a tank with the tank valve in the 'open' position, the propane wants to 'surge' into the grill.
Ben Gaetani
Tanks 2 You Propane
Mar 28, 2010 | Weber Genesis Silver B Grill
Is not heating properly , the flame is not as strong as it used to be.
Ben Gaetani
Tanks 2 You Propane
Jan 18, 2010 | DCS BGB36BQARN (NG) Stainless All-in-One...
Just bought new propane tank for my Charbroil grill. First two times it work perfectly. Very short cook times with only 2 out 4 burners on. Now the grill lights but only enough of a flow for a low heat....
Either you got short changes on gas or the regulator is not working properly. Check the tank to see if it is empty, if not then the regulator will need to be changed.
Nov 12, 2009 | Char-Broil CharBroil 4637318 Grill
Heating
It sounds like the regulator is shutting down and preventing the grill from getting all of the propane it needs. to remedy your problem disconnect the tank and then reconnect it. Usually that is all it takes to get the regulator to work properly. If the problem continues just get a new hose with regulator attached.
Jul 07, 2009 | Weber Spirit? E-310 Propane Grill
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
Gas Grill regulator freeze
yes you need to replace the regulator it sounds as if the vent is plugged.
Hope this helps
Jun 22, 2008 | Grilling
Weber Genesis Silver B Grill Logo
107 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Weber Grilling Expert? Answer questions, earn points and help others
