Question about Vizio VW32L 32 in. LCD HDTV
AUDIO WENT OUT
FINSIHED A SHOW AND NO MATTER HOW HIGH YOU RAISE THE VOLUME "NOTHING"
  • 50 Answers
Audio amp damaged, on this tv its on the main board, will have to replace the main board
Posted on Apr 27, 2010
    Habit-Forming:
  • 16 Answers
If you are connecting via HDMI, it is also possible that the source is the problem. If the programing is not sending an audio in the manner that is expected by the tv you can sometimes lose one or more audio (you might hear the background noises but no speech or vice versa). Check the source device's audio settings.
Posted on May 20, 2010
Volume button sticks and raises to max level and cannot be turned down.
It sounds from your description there is a fault in the audio section electronics rather than with the button.
Dec 06, 2015 | Car Audio & Video
How do you raise the volume? Mine is weak with it all the way up.
With the deck off av off, press setting, audio, menu will come of you need to set the amp gain to high. Volume will now go to 50 not 30. Cheers.
Jul 28, 2014 | JVC KW-AVX740 Double-DIN DVD/CD AM/FM...
My speaker volume is very low no matter what i play. All volume controls are up as high as they will go
Have you checked your system audio volume?
If you are using Windows XP go to Start menu -> Accessories -> Entertainment -> Volume Control
Make sure that the volume is set to the highest value.
Mar 04, 2011 | Polk Audio AMR50 Computer Speakers
Amplifier cuts off after raising the volume
just a tad is all that it takes to throw it in protect mode so check the gain and the cross over and make sure they are set at a decent level and see if that works a little bit
Mar 30, 2010 | Jl Audio 500/1 Car Audio Amplifier
There's no audio coming out on my computer. Do I need an installer software to make it work?
lets just go stepwise
1. check to see if the Audio drivers are installed in the device manager if not then you might have to install them
2. check to see if the Volume button on the task bar beside the time is not showing mute symbol and the volume is raised
3. if no then double click on the speaker symbol and in the properties check to see that none of the other tabs are on the mute or at very low volume
4. now check to see that the speaker jack is connected to the right colour coded jack on the PC and the volume is appropriately high
Jul 30, 2009 | Labtec Audio Players & Recorders
Speaker error
Generally, an indication of "speaker error" means that something hashappened to an internal circuit of the unit. This can be caused byover-heat or over-current conditions which sometimes are due to runningthe volume high. If your problem occurred during a very loud passage ofaudio on the TV, this may be the cause of the problem. If so, it willnot matter which input you feed the TV sound into. In fact, the sameproblem might occur running the DVD player. The shut down condition inthe Yamaha is a protective circuit that keeps the unit from beingdamaged.
Now--it may well be that you were not running high volume at all andthe same problem could occur due to heat build up in the amplifier orto a circuit problem. If the system is in a warm area of your home,this may raise the internal temperature of the sub high enough totrigger the shut down. I do notthink that an external source is the reason for the problem--unless, ofcourse, the input signal level is too high and causes the volume to gohigh.
If you have the unit closed up in a shelf whith limited ventilation orthe sub is located where it has no cooling air, that could also be acause for the problem. You may want to try changing locations of theunit and see what happens. If you still have the problem, I recommendthat you go up on the Yamaha web site (www.yamaha.com) and click ontheir customer service area. Then ask about the problem and see whatthey recommend.
Oct 12, 2008 | Yamaha DVX-C300 System
My panasonic sa-ak58 home stereo, it turns on o.k. but after a couple of seconds i loose audio, on all speakers, but the led screen shows normal volume level, no matter if is high or low on volume.
go on the back of the stereo take a aux cable and hook to the back and touch the end were it plugs in to the mp3 r what ever you use and if its still making the nosie your amps fried
Aug 28, 2008 | Panasonic Audio Players & Recorders
My hp speakers dont work
re-install drivers for your sound card
Aug 18, 2008 | HP Pavilion dv9000z Notebook
VOICE
make sure the surround is off. Also, there is a setting on the remote that changes the volume on certain speakers. I think its 'CH.SELECT'. Just lower the front speaker and raise the center channel.
Apr 17, 2008 | Panasonic SC-AK78 CD Shelf System
Have a kenwood KR-V990D and can't seem to bring the volume up
kenwood has always showed negative numbers 00 is as high as it will go
Jan 06, 2008 | Kenwood KR-V990D Receiver
Vizio VW32L 32 in. LCD HDTV Logo
95 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
