Question about Maytag MER6772 Gemini Electric Kitchen Range
My upper oven on my maytag gemini double over doesnt turn off, any suggestions, its only 2 yrs old
  • I have the same problem. Now the bottom oven wont get over 150 degrees!
Posted on May 13, 2010
Only one burner doesn't work on my maytag gemini stove
MET8776BS Maytag Gemini Smoothtop Double Oven Range
reviews.us-appliance.com/.../MET8776BS-Maytag-Gemini-Smoothtop-D...
Rating: 4.5 - ‎94 reviews MET8776BS Maytag Gemini Smoothtop Double Oven Range - Stainless Steel - Reviews ... Really like the features, however one burner doesn't work, after a month.... 2 ovens sure beats the storage bin underneath! the only negative I can think of is ...I bought my double oven a few months ago and am very happy with it.
Oct 16, 2015 | Maytag Kitchen Ranges
Maytag gemini electric double oven, f1-f2 codes both ovens, tested both temperature sensor probes, both at 1100 ohms, called Maytag, said might be control board. Anything else to test before spending $$$...
make this test and fix it. God bless you
F1:-1 Runaway Cook Upper oven Test the temperature oven sensor replace if necessary F1:-2 Runaway Cook Lower oven Check the temperature oven sensor replace if necessary
Nov 04, 2013 | Maytag MER6772 Gemini Electric Kitchen...
We have a Maytag Gemini double oven. The lower element in the upper oven is not working. Tried replacing it, but that didn't work. It's getting power and everything. Any suggestions?
You may have a bad oven sensor. If you look in the oven you will see a small probe about the size of a pen that is the oven sensor. Hope this gets yu going in the right direction. Thank you for using Fix ya
Jun 24, 2011 | Maytag MER6751A Electric Kitchen Range
My Maytag Gemini oven is displaying an F9-2 error code...I believe this has to do with the upper oven door lock mechanism...anything I can do, or does this require a service call?
F9-2 error code indicates:
  1. Door latch motor failure/jammed. Latch motor switch failure.
  2. Oven control software failure, or component failure(stuck relay).
  3. Wiring problem.
  • Press the clear key.
  • If the Clear key does not eliminate the problem, turn off the power to the range for 30 seconds, then turn the power back on.
  • It is most likely to have a failed or misaligned door lock switch.
Feb 06, 2011 | Maytag Gemini 30" Self-Cleaning...
Maytag gemini oven tough controls won't work --
Check the door switch and the temperature probe. If they are ok, then the problem is likely in the control board. These boards can be rebuilt.
Jun 26, 2010 | Maytag 24" Built-In Double Electric Wall...
I have a Mytag Gemini i had it for 10 yrs. It gave a code that says F3-1 what is it mean.
This is a Common Error Message on this Model. This Refers to :-
Oven Temperature Sensor, Upper Oven.
You need to replace the Oven Temperature Sensor. On Most Models, it is inside the Oven in the Upper Corner.Once Replaced, this would fix the problem.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 30, 2009 | Maytag MER6772 Gemini Electric Kitchen...
The Maytag Gemini is didplaying an f9-3 code, what does this mean?
somthing wrong with upper door lock, bent, door misaligned, problem with lock itself
Dec 25, 2009 | Maytag Gemini 30" Self-Cleaning...
Maytag Gemini Dual Oven MER6772BCA
sounds like the broil elemnt in the upper oven is shorting itself out part number 74004106, probly 45 bucks. leave the circuit off adn replace it... the wire(s) leading to it are always live.theres a few screws across the top of the cavity holding it up
Apr 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
163 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
