Question about Homelite Consumer Products 4.0 Amp, 13 In. Trimmer
Tried to reinstall the string head and the shft came out of the drive shaft housing
  • 4 Answers
,mjnhbgfdsfghjnb
Posted on Apr 27, 2010
Head not spinning shaft cable is.
place a screw driver in the slot the drive goes into and hold the trimmer head feel the head
Aug 16, 2012 | Troy-Bilt Troybilt Mtd String Trimmer...
I have a Echo Gas trimmer SRM-210 Rapid feeder dual line. I need to know how to remove the entire drum for the string spool? NOT how to re-string but how to replace entire head/spool, as if I was going to...
In your manual under section 12: Line Head Installation. You will do the opposite of what it says here. The key is to LOCK the gear drive so the flex-drive shaft won't turn WHEN you are removing the trimmer head. They use a special tool (maybe you have it). But a small-shafted Phillips screwdriver or the like can be put in the drive hole to lock the gearing up as well. Look for the hole in the upper plate and align with the notch in the drive housing and grasping the entire string head unit, remove it. Here is your manual, see Section 12
http://dl.owneriq.net/8/854215d5-44e4-4b5d-b773-77b331fd73b3.pdf
Jul 17, 2011 | Echo Rapid Loader, Trimmer Head
I was given a used 31cc trimmer but can't get the spool off to replace it. how do i do this?
A typical trimmer has a small bump knob, an inner spool with the plastic string wound on it and the housing for that which is the string head.To remove the small bump knob, hold string head firmly and turn the bump knob counterclockwise. To remove the head entirely, first remove the bump knob. Next, remove the inner spool with string. What should be left is the spring with the end of the gear shaft showing. Some heads are locked on and some just slip over the end of the shaft. Check the gear drive just above the string head for any holes in the collar. An object can be placed in one of the holes to lock the drive and twist the head off.Ryobi's use retaining clips on the shaft which have to be removed.
May 06, 2011 | Garden
Troy-bilt tb539e head wont spin starts, and idles great but I cant get the head to spin
Since this is a split-boom machine, disassembly and inspection will be required. This unit has basically, 2 drive shafts and a clutch (up near the engine at the end of the engine's crankshaft). There is a drive shaft in the upper boom and one in the lower boom. Either the clutch or one of the drive shafts has malfunctioned.The string head SHOULD NOT spin with the engine idling. There is a centrifugal clutch that engages when the engine reaches a certain speed, in turn, it turns the upper drive shaft.
First, check the string head area for tangled string, wire, line or debris around the center shaft. Long grass can end up wrapped around that area and severely affect movement. Dissasemble the head and inspect. Make sure you can turn the string head by hand. If so, good/
To inpect lower drive shaft, just uncouple it from the upper one. Grasp the end of the driveshaft and turn it. Does it feel OK? Does the string head turn when you turn the drive? If not, you at least have a problem in the lower boom. If all is well, then proceed to inspect the upper boom.
Unscrew the main (uppper) boom from the front of the engine. If you can remove it out of the clutch drum and off then you will be able to inspect it. If the throttle cable and/or wires from the STOP switch are restricting you, you will need to remove the throttle cable from the engine's carburetor and try to get some slack in the switch wires. Those wires go to the ignition coil module under the engine cover.
When you have the upper boom off and can access the drive shaft, turn it to check it. Make sure the other end of it turns. If both drive shafts check out OK, then the clutch will need to be inspected. Post back if needed.
Oct 26, 2010 | Troy Garden
Broken or worn shaft flex. Motor runs and head moves a little with no power. How to remove shaft from housing?
First, about 4 Torx screws hold the end of the flex-drive tube to the engine housing. Remove those.Then, remove the throttle cable from the throttle plate shaft of the carburetor. If any covers are in the way, remove them.If the handle has a stop switch on it, then you will want to remove the wires from the ignition module (unless you can pull the tube out far enough away to access the flex drive. If the stop switch is on the front engine cover, then fine.
Once the tube is free and clear, just grap the end of the flex drive and pull it out. If you reinstall it, reverse it end for end and grease it well with lithium-based grease. Post back if needed.
Oct 25, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Ref: Stihl FS46 string trimmer. Broken Flex shaft.
Remove orange sheild,remove single screw holding head in shaft then grab head with pliers and twist side to side until complete head is free.You should then be able to grab part of shaft.On power head loosen screws {about one turn each} that hold two white case halves near trigger,I think there are four,then there is a single torx screw on the bottom of lower case half in the middle that must be taken out to allow tube to be removed.Romove flexshaft from top.Check 4 plastic burnt to flexshaft,if there is you must replace tube liner as well,usally around bent part of tube the liner will go bad.
Nov 27, 2009 | Garden
Trimmer dust cover hot to touch ... trimmer head flew off and in reinstalling the trimmer does not turn or only turns momentarily before engine shuts off
sounds like the drive cable is jammed.you need to remove the shaft from the engine and head and see if the cable spins freely.
Apr 29, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Homelite Consumer Products 4.0 Amp, 13 In. Trimmer Logo
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
