Question about Dryers
LG Tromm Dryer will not get hot. It is about two years old. I have no flow sense indicator bars and no type of blockage. The model # is DLE5955W The S/N is 708KWDJ04154. Any help will be great. Thanks Jack
  • 438 Answers
All devices the produce heat, whatever it may be has a safety feature integrated into it`s design this device will open or brake the connection from the power supply to the heating element to prevent fire, this device may also be defective, this device has an egg shape with a mounting screw on each ear, normally located near the heating element, use and ohm meter to test for continuity this should show short circuit , you can also use the ohm meter to test for continuity of the heating coil to see if it is defective ohm meter showing continuity of the heating coil but not short circuit is a good sign the coil is good, if all else fails turn the unit on and check for AC voltage using your volt meter coming from the timer unit, be on guard for shock dangers when doing this test, good luck
Posted on Apr 28, 2010
  • 784 Answers
Usually the heater element needs to be replaced. Since your is just 2 years old, you may want to take off the back panel and turn it on to see if the blower is working. IT the heater is on but the blower is not working then you have no heat. Don't confuse the blower assembly with the moter to turns the drum, since they are 2 different entities. If the blower is on then your heater element is the culprit. Good Luck.
LG tromm dryer electric sounds like bearings are starting to seize
if the bearing are going it will sound like a plain taking off grinding banging them you will end up with grease all over your clothes was told from an engineer once never put you m/c on any thing over 900 rpm spin speed as the bearings ar not designed to go any faster i have a hotpoint and its over 12 year old still sounds like new and never had a problem with it hope this help
Sep 23, 2012 | LG Tromm Electric Dryer
My LG Tromm DLE5955W dryer has great airflow and heating but about 2 months after I bought it, it now takes 2 hours to dry a load of clothes. I have vaccumed it out and replaced the vent house already with...
You have a problem with the exhaust vent in the house walls. Try this. Disconnect the dryer vent hose from the back of the dryer and see how well it dries a load of laundry. If it comes out alright, then you know that the vent in the house is clogged and will need to be professionally cleaned out. Good luck
Jun 19, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG Tromm DLE5955W dryer won't dry properly. the flow sensor light is on and it stops after a few minutes no matter what setting it is on.
You would need to get a multimeter and run continuity tests on the thermistor relays as well as the heater which ever one shows you no continuity would be the one that you would have to replace the heater is located on this diagram as part number 110 http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fK0810191-00003.png the relays would be part number 130 and 140 please message me back if you have any further questions and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
.ps. the dryer is most likely stopping do to one of the relays they control the tempreture of the machine and if it starts getting to hot then it would shut the machine down
Dec 10, 2010 | LG Dryers
My two or three year old LG DLE5955W dryer is making a grinding/squeaking noise and from what I have read is most likely the worn rollers. How do you gain access to them and is it something for a do it...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 09, 2010 | LG DLE5955 Dryer
Check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Dec 23, 2009 | LG Dryers
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Dryer LG DLE5955w
are you missing any socks? if so you need to throughly check the duct chamber in the machine, get it serviced this is a fire hadzard.
Jun 23, 2009 | LG DLE5955 Dryer
Hi, I hooked up my LG DLE5955W dryer and it powers up fine but I have no heat. The outlet I had for my old dryer was different than the one required for the LG. I went to home depot and got the correc
The following link explains how to properly wire a three or four prong 220VAC appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Read through the link provided, and make sure you have the power cord wired correctly at the terminal block in the back of the dryer. NOTE: If this is a new installation, you are required to be using a four-prong outlet with 4-prong power cord. If you have any questions, please let me know. I hope this helps solve your problem.
May 03, 2009 | LG DLE5955 Dryer
Dryers Logo
592 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
