Question about Exercise & Fitness
The belt on my treadmill is off to one side. how
The belt on my treadmill is off to one side and is rubbing the side. how can i fix it?
  • 83 Answers
Here are two solutions one is to get the belt centered on the treadmill and the other is to tighten the belt.
There should be two bolts in the rear of the treadmill, one on each side. These bolts adjust the rear roller of the treadmill. The walking belt will always go to the side that is looser. To get the belt back on track, (if you can start the treadmill so the belt is running) tighten the bolt on the side that the belt has slipped to. Tighten the bolt a little bit at a time. If you tighten the bolt too much, then the belt will go to the other side.
To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns.
Posted on May 01, 2010
Testimonial: "Great info. Thank you so much!"
  • 34 Answers
SOURCE: On my Sears ProForm 730 treadmill, I cannot make
The belt does not need to be replaced more than likely. The problem is probably because that adjustment bolt is stripped out causing it loosen and keeping it over on that side. ProForm sells star washers that help them stay steady and not slip out. I would call them and ask for a couple of star washers and a new adjustment bolt for that left side.
Posted on Aug 18, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have a Proform 380 Treadmill. When the treadmill
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered.
Posted on May 24, 2010
  • 19 Answers
SOURCE: proform treadmill belt won't stay centered.
Adjust the tension on the right side rear using an allen wrench. Try 1/4 turn clockwise( should tighten). then run tread mill for 30 sec. to see if it centers itself. repeat again if not. if its to tight then turn the left side in a 1/4 turn
Posted on Apr 28, 2009
  • 20 Answers
SOURCE: the belt has slowly moved
There are two allen bolt adjustments on the bottom left of the treadmill as you are facing it to get on. o adjust the side-to-side position, turn one one way and the other the other way.
Posted on Oct 26, 2010
GodBlessU
  • 3513 Answers
SOURCE: belt shifted to the lrft
First please donot use it. Try to use a I shaped wrench to make the belt shift more to the right hand side. I am posting you the manual for complete reference:
http://www.academy.com/images/pdf/Ironman/Ironman_Elliptical_530e.pdf
Please accept the suggestion if it's helpful, you can also get back to us if you have any further query.
Have a nice day.
Posted on Dec 23, 2010
The right treadle is rubbing against the right upright why
please see the video and proceed according for fix it.
Please remember to LUBE the deck belt+roller bearing too.
God bless you
Feb 27, 2013 | Bowflex Treadclimber
The belt keeps moving towards the left side of the treadmill and rubs the side. How can I adjust the belt to fix the problem? It is a Weslo Cadence SR12 model. Thanks!
There are Allen bolts on both sides of the bottom on the front (away from the console) of the treadmill. Turn one one way and the other the other way to adjust the belt. If this does not work, your belt is probably worn and stretched and needs to be replaced. See Treadmill Parts to order a new one.
Aug 29, 2011 | Cadence Weslo 825 Treadmill Walking Belt
The belt on my proform 680LT has an excessive amount of rubber powder rubbing/shedding off. It makes a mess.
Is it rubbing off the sides of the belt? If so, adjust the lateral movement of the belt with the hex bolts at the base of the treadmill. If not, you may need a new belt. See Treadmill Parts
May 03, 2011 | Proform 680 LT Treadmill
I have a used Weslo Cadense 927 treadmill. I need to adjust the the tread, it's rubbing the side.
When you purchased the treadmill it came with an allen wrench to assemble the machine. That is the adjustment tool.
Inspect the rear plastic cap (the adjustment bolts are there) make sure it is not damaged. If the plastic is broken, it will need to be replaced. This job is not easy. If it is not broken, adjust the belt as follows..
If the belt is already rubbing, locate the adjustment screw at the back of the treadmill on the side that is rubbing.Adjust that screw tuning it 1/2 turn clockwise. Move the belt manually 3 full rotations.. If it is still rubbing, turn another 1/4 turn. Again move the belt manually 3 rotations. Once the rubbing stops, run the machine slowly and watch the belt from the back of the machine..
Dec 16, 2010 | Cadence Weslo 927 Treadmill Walking Belt
The belt has slowly moved all the way over to the right and is rubbing up against the right side. How do I adjust the belt back to the middle of the treadmill? It is a Health Rider XL Soft Strider.
Oct 25, 2010 | HEALTHRIDER R60 SoftStrider Treadmill
On my Sears ProForm 730 treadmill, I cannot make the belt move to the right (it is rubbing on the left side) by turning the left-side back belt screw clockwise (in any amount). The belt is walking back...
Aug 16, 2010 | Proform 730 Folding Treadmill Model...
The belt keeps going to one side+ rubbing,, is there anyone that
there should be adjustment screws on the rear roller.
only adjust one of them (usually the left) if the belt rubs on the left turn the screw clockwise 1/4 turn and if the belt rubs on the right turn counterclockwise. Make small adjustments until the belt stays in the center
Mar 24, 2010 | Proform 6.5q Treadmill Walking Belt
Tread is sliding and rubbing agianst right side of track.
Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
Jul 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
Weslo pro tread belt
Hi, Yes it is! the belt is not free floating but travels on a slide. When there is pressure on it ( from someone) it rubs on the slide underneath. When you step off it should stop the rubbing noise. There you go, this should Fixya!
Mar 24, 2009 | Weslo Pro Crosswalk 7.8 Treadmill
Exercise & Fitness Logo
369 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
