Question about Canon EOS-AE-1 35mm SLR Camera
Ae1 when i advance film the shutter releases abd takes a photo
  • 55 Answers
You have bad mirror release magnet.
The magnet became weak and not holding the mirror so when you wind, the mirror goes up and takes pictures or releases the shutter by itself.
Posted on Jun 17, 2010
I cannot press down the shutter release and the film advance tab will not move, therefore making it impossible for me to take photos. Please help.
I guess it is actually an AE1 and not an EOS, as EOS is a digital camera! You will have to scrap the film in the camera by opening the back and removing the film. Take out the film can, then pull the film off the take up spool press the windback button on the bottom of the camera. This should get it working again. Try a few shutter releases and wind ons before putting a new film in. If you have important images on the film you don't wan to lose just do the above in complete darkness, and wind the loose film back into the can using the knob at the bottom.
Jan 04, 2011 | Canon EOS-AE-1 35mm SLR Camera
FILM ADVANCE/SHUTTER STUCK
Start simple and go from there.
I don't know if you have film in the camera so I'll read the following and choose what works for you.
I will assume the battery is working if applicable.
As stupid as this sounds press the shutter release button. If the shutter is cocked it will hold the advance. I've had people come in with this problem.
Not it?
If the film rewind has been pressed in it will disengage the film advance and stop the shutter mechanism as a result. Open the camera and close the back again resets the release.
If there is film in the camera remove it.
It there are important photos on the film and your rewind is not working use a coat to make a light proof black box. Just turn the sleeves inside out and put the camera in the coat. Wrap it so as it is closed to light. Open the camera remove the film and roll the film back in by hand.
OK so now we have a camera open with no film in it.
Open the back and look just below the shutter. On one side will be a very small "lever". This tells the camera that the film has been advanced and the shutter is cocked. Gently move the lever to the right. It should click. Now try pressing the shutter release.
Note that without film in the camera some cameras will not advance the shutter.
It should clear the problem.
If not something physical in jamming.
The film advance system could be jamming. On the side the film advance is on there will be a plastic "gear" inside the camera. Try moving by hand it should turn. You can reset the shutter this way.
Give this a try.
Hope this is helpful, if it gives you some direction please rate this answer.
Thanks
Mar 14, 2010 | Photography
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Film advance
In most film cameras, a battery is not necessary to manual advance film using the lever. Your Canon AV-1 is no exception. I have owned two cameras from the same group, the AE-1 and the Canon A-1. Neither required a battery for manual film advance.
Make sure the ring around the shutter release button is set to "A", otherwise the shutter won't release and the film lever won't work correctly. If the ring shows an "L", the shutter release is locked.
Here's a graphic of the batteries that can be used in your AV-1:
Nov 17, 2008 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Canon AE1 Shutter Problem
It could be a simple issue with the shutter magnets, or something more severe with the electronics. What does the meter needle do when you push the shutter release down? With the speed dial set at 1/125 or higher and no lens, the needle should move fairly high. If it pegs to the bottom right away, that is a bad sign.
You can check the magnets from the bottom with the cover removed. (2 screws) You can release the mechanicals of the shutter by pushing the silver lever arm (located next to the plastic shield around the magnet on the rewind side of the camera) toward the front of the camera. Be mindful of the spring attached
Sep 17, 2008 | Canon EOS-AE-1 35mm SLR Camera
Film advance lever.
Do you press the shutter button to release the lever for the next photo? That's how you advance the film from the exposure to light, when first insterting the film.
Sep 16, 2008 | Nikon FE 35mm SLR Camera
Takes a picture when film advance lever is moved
The magnets that control the shutter are the likely suspect. Dirt and debris can cause them not to hold properly. Hence, it fires the shutter when you advance the film. It is something you can repair yourself. I can describe the procedure if you are interested.
Sep 09, 2008 | Canon EOS-AE-1 35mm SLR Camera
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
Film advance lever
Your camera is cocked but since the shutter is not working you cannot release it and hence your film advance mechanism does not work. ME-super will work without batteries in full manual mode so set your shutter to B and try to release it. If the shutter will not release in B mode then the shutter/mirror box will need servicing : rubber components in the mirror box mechanism have perished and need replacing. After that your camera will be fine for another couple of years.
Sep 18, 2007 | Pentax ME Super 35mm SLR Camera
Film won't advance
Perhaps you've already solved the mystery. There are 2 parts to the back of that camera, the film back + the part that it slips onto. And they have little safety latches/pins that couple in order to advance the film & release the shutter. I'm sure those just aren't in the right place. Here in Los Angeles you could take it to any major camera store or repair shop & they've help you out.
Mar 06, 2007 | Mamiya RB67 Pro SD Medium Format Camera
Canon EOS-AE-1 35mm SLR Camera Logo
162 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
