Question about Swintec Office Equipment & Supplies
My typewriter won't type what I tell it to until I press tab
  • Swintec Master
  • 3,594 Answers
You are in the delayed print or line print mode. Press the mode key until the display arrow points to NP.
DickyO
Posted on Apr 28, 2010
Wheelwriter 6, flashing #3 beeps 3 times. press any keys twice and it will type.
You batteries need to be replaced, and or the battery holder is
corroded. Should be removed and cleaned so acid does not leak inside the machine.
Batteries hold the margins and tabs when turned off, not real necessarry.
Jan 22, 2016 | IBM Wheelwriter 6 Typewriter
How can I set a right hand tab
I assume you are talking about Flush Right Tabulation.
To set a flush right tab:
(1) Position the carrier (or cursor) at the point where you want a flush right tab to be set.
(2) Hold down the Tab set/clear key and press the 2 key.
To clear a flush right tab:
(1) Press the Tab/back tab key to move the carrier (or cursor) to the flush right tab position.
(2) Hold down the Code key and press the Tab set/clear key.
To use a flush right tab:
(2) Type the text. Characters will appear on the display as they are typed. Corrections can be made on the display before the text is printed.
(3) Press the Print key. The text is printed aligned with the flush right tab position.
To find out more about your Swintec 7040 typewriter, you can buy a PDF manual for only $10 at:
Swintec Typewriter PDF Operations Manuals 10 emailed
May 15, 2014 | Swintec 7040 Typewriter
How do i release the tab position?
At each tab stop, press the "tab release" button. Then tab to the next tab position and do the same. OR
You can put the machine in "service mode" which will erase all tab stops and reset your margins to their default positions. Easily done by turning the typewriter OFF. Then while off, press and hold "mar rel" (margin release) key on upper left side of keyboard. While holding it down and keeping it down, turn the typewriter ON. Then take your finger off the Margin Release key. The typewriter will start typing all by itself. Turn the typewriter off, then on. That will reset everything. All tab stops will be erased and margins reset to their defaults.
Jan 04, 2012 | Swintec 7040 Typewriter
How to clear tabs?
Tab to the position press tab clr. To clear all tabs Press tab clr. then the repeat key, 2 beeps will sound. If you have a tab that won't clear it is probably the R. margin.
DickyO
Apr 22, 2011 | Olympia Supertype 330 Typewriter
How do I reset/unlock the tabs?
in type mode press the tab key the print hear will go to the next tab stop to remove the stop press (tab - )key then press the tab key again to the next stop press tab - again you have just removed two tab stops.
to set them you space bar to the position you need a stop and press tab + key
Mar 07, 2011 | Nakajima AE-830 Typewriter
My typewriter carriage doesn't move along as I type.
I just have an underwood 18 typewriter and when I type the carriage doesnt move the margins are in the end and when I press the tab key It is moving but if press the space bar it doesnt move..what should I do?
Sep 18, 2009 | Royal Office Equipment & Supplies
How do I set Decimal Tabs?
From the User's Manual:
Margins and For each setting, move point. key(s) indicated:
• LMar to set left margino
• RMar to set the right margino
• MarRei to the!" left of the margino
• TSet to set a tab. Vou set at the left and right margins. Vou • TClr to clear a tab.
• TClr + CRln elear ali The earrier does not margino when the carrier is tive margino Vou type or space through ríght margino saved when the oft.
Tabs
the carrier to the desired point, and press the
the margin.
margin.
MarRel release the left margin, ther Backspace or +- to move
margi n.
You can up to 26 tabs. Permanent tabs exist
You cannot clear these tabs.
CRtn to clear all tabs.
carrier lock at the right margin. The typewriter beeps
about five spaces before the right margin. You can
the right margin. Margin and tab settings are
typewriter is turned.
You can download the User's Manual from LEXMARK:
http://images.lexmark.com/publications/pdfs/2007/index/en.html
Look for the title 'IBM Typewriters' at the end of the page, open the list box and select your typewritter model.
Aug 07, 2009 | Lexmark Wheelwriter 1000 Typewriter
Typewriter wont type past center point
You probably hae th R. margin set there. Space to that point touch the margin release ke sapce to hefar rght, press te R. mar. key.
DickyO
Jul 01, 2009 | Olympia Startype 3 Typewriter
I have a swintec 8016. please tell me how to clear the tabs that are set so that i can set new ones.
Space all the way to the right press and hold the tab clear ket, press return, all the tabs should clear. Space to the points that you want tabs and press tab set. To clear an indivual tab tab to that position and press tab clear. DickyO
Jun 11, 2009 | Swintec 7040 Typewriter
IBM Wheelwriter 1000 - How to clear all tabs
Using the space bar move the carrier (print head) all the way to the right, press and hold tab clear key and hit the return key.
Dec 14, 2007 | Lexmark Wheelwriter 1000 Typewriter
56 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
