Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Upright carpet vac will not pick up - Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
  • 142 Answers
Broken belt or bloked hose replace belt. Take hose of machine off and take outside Use garden hose to push up one end and out the other.
Posted on May 10, 2010
My dc07i has power to hose but isn't picking up when hovering carpets or hard floors the roller is going round but there is no suction
I would guess that the line is plugged between the pick-up where it goes to the dirt tank. Lots of time when something big gets sucked in, it still lets the dirt in the tank. However over time dirt collects around the wedged object and gradually over time plugs the passage way. It may take a little time to pick out the blockage. You may have to somewhat take it apart. to get at it. This happens to my shop vac a lot.
Dec 31, 2014 | Dyson DC07i Bagless Upright Vacuum
What kind of upright or steam Vac should I buy which can make my carpet clean and SOFT?
I recommend looking at the miele S7280 for an upright vacuum cleaner and the royal RY7910 carpet extractor.
Jan 20, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac doesn't pick up all cleaning soluation when cleaning carpet? I have clean both filters
Please look to make sure the rubber ring gasket is still in place under the recovery tank. The tube on the bottom of the recovery tank must seal to the rubber ring to get suction.
Dec 29, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Bought a new sweeper and brush ( beater bar ) does not turn. The large belt is fine and turns. The small thin belt is also fine but does not turn the brush. It is either the wrong belt or is there...
Jim, To put tension on the brush, tilt machine forward when upright, move carpet selector knob to carpet. then turn vac on. Brush will only spin when vac is tilted back to operate. brush stops when upright and on to use hand tools so the er is no danger to carpet or persons with moving roller.
Sep 29, 2009 | Hoover U6630-900 WindTunnel Bagless...
The vacuum cleaner does not pick up anything from carpet. It does not even pick up pieces of thread laying on carpet. On tile floors it blows dirt away instead of picking it up. I've tried all the settings...
Sounds like there is a clog..
Usually its in the hose - look closely.. Stretch the hose out straight and look in there good..
Or a clog could be in the vac close to where the hose conects to the vac on either end..
This is most case scenario with these types of vacs..
I hope this helps !!
Please rate me good ;o)
Jul 10, 2009 | Hoover U5269910 Bagless Upright Vacuum
HOW DO i GET THE WATER OUT OF THE CARPET ONCE IT'S CLEANED?
Do you have a shop vac . Take the bag out of the shop vac ,and **** up the water . When you are done open your windows and do not walk on the carpet for at least one hour . You want your carpets to dry with the pile standing up. Carpet rake is the best thing to use . Best of luck Ed.
Jun 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
No suction
I have found more vacuums on the way to the dump because they were full. Check. Is it full?
If not the air way is clogged.
May 17, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
The vacuum isn't picking anything up. Nothing is getting in the filter. Dirt is just being redistributed back onto the carpet.
hi from uk if you could please verify what type of vac you have ? upright with dust bag? of dyson no bag? or is it a cylinder vac with flex hose? it would helpto advise on possible cause of vac not working and possible remedy ?
Oct 31, 2008 | Vacuums
Using attachments...can't find my manual ; when using attachments the
hi in answer to your question regarding the belt driven roller/brush on bottom of vac ? the nswer is yes it still rotates when you are using the tools on connection to flex hose ie stair carpet or areas the vac will not enter one word of advice ! if you use the vac/tools to vac the car interior as i and others do ? then ensure that whilst vac is stood and the flex hose and tool are in use? suggest you stand the vac on a flat surface(not the tarmacdrive or any porouse surface) preferably a rubber mat? or board so the rollerbrush is not subject to damage or apt to pick up stone chips etc which will eventually damage the motor impellor hope this helps answer your question and understand the safety point i mentioned best wishes
Oct 23, 2007 | Hoover U5018-900 Bagged Upright Vacuum
Kirby Ultimate won't clean carpet
when you install the hose connector it trips a switch that switches the vac motor into high speed because the vac path is longer using the hose. check the belt after you remove the front. make sure the direction of rotation is in the direction of belt travel stamped in the impeller. try adjusting the head height
Aug 13, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
49 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
