Question about HP LaserJet 2840 Printer
My hp color laserjet 2840 keep gave me error 79 ask to turn off then turn on I did it several time but it don't fix the problem. Please help me fix this problem.
  • 3 Answers
79 Error
Turn off then on
The device has experienced an internal
firmware error.
Turn off the power by using the power
switch, wait at least 30 seconds, and then
turn on the power and wait for the device to
initialize.
If you have recently installed a memory
DIMM in the device, turn off the device,
remove the memory DIMM, reinstall the
DIMM to verify that it is seated properly,
and then turn on the device.
If a surge protector is being used, remove
it. Plug the device directly into the wall
socket. Use the power switch to turn the
device on.
If the error persists, upgrade the firmware.
See Updating or recovering the firmware
code.
If the error persists, replace the formatter.
See Removing the formatter assemblies
Posted on Jan 21, 2011
I installed an original Q3971A toner into the HP 2840 laser printer, However there is still a notice to install cyan catridge. Can you help please
PDF]HP Color LaserJet 2840 and 2820 All-in-One for small and ...
h10010.www1.hp.com/wwpc/.../clj2820_clj2840_bro.p...
Hewlett?PackardColour laser printing. HP Color LaserJet ... •Convert hardcopy documents into digital format for easy ... Color LaserJet 2820 All-in-One gives you high quality, ... Oth ring. Why HP. Save time. Printing a file. Printing a paper fax. Receiving a .... Install, configure and manage multiple networked ... Replace toner cartridges easily.
HP Environment: Product Safety Information - LaserJet ...
Dec 18, 2015 | HP LaserJet 2840 All-In-One Printer
HP Color LaserJet 2840 keeps showing 50.2 Fuser error message. Nothing helps correct problem. What to do? Have tried repeatedly turning printer off, waiting several seconds and turning on again. Each time...
The fuser is the heating unit near the paper exit, and that error means the lamp is burned out, the overtemp sensor is out, or the thermistor in the fuser is bad. About all you can do is replace the fuser. www.precisionroller.com will have a new fuser for you.
Jan 12, 2010 | HP LaserJet 2840 All-In-One Printer
52 scanner error on HP Color Laserjet 2840
The device has experienced an internal hardware error. Recommended Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If the error is still unresolved, contact Hewlett-Packard for technical support to troubleshoot the problem. Call HP for telephone support
Mar 22, 2009 | HP LaserJet 2840 All-In-One Printer
For my hp color laserjet 2840
You have a bad scanner assembly. Very expensive to get fixed
Mar 02, 2009 | Office Equipment & Supplies
HP Color Laserjet 2840 refill problem
It may be that the cartridges are the problem? Usual fix is to go back to before the problem and start again. If you don't have old good cartridges, you may have to get new cartridges.
Feb 15, 2009 | HP Color LaserJet 2550n printer + HP Color...
My HP Color Laserjet 2840 and is saying "50.1 Fuser Error"
HP error message 50.X is usually a fuser error. replace fuser
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
Scanner error 6 for hp color laserjet 2840
After the hp color laserjet has finnished initiallizing it gives me error code 6
Dec 07, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 2840
The error your having caused by the scanner assembly in the Auto Doc Feeder. The part is not real difficult to replace however it is not cheap. Here's the part number: Q3948-60191.
The part is available through HP online at http://partsurfer.hp.com for $130.76 plus shipping. It is also available (probably a little cheaper) from Seattle Platen, Dale - 1-800-221-2388.
We have been sucessful a couple times in disassembling the lower (scanning) section of the Auto Doc Feeder and thoroughly cleaning all mirrors and lenses. It's about 1 in 8 that will clear up the issue. Replacement is 100% cure.
Here's a free copy of the HP 2820/2840 service manual that will help you in the disassembly.
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%202820,%202830,%202840%20Parts,%20Service%20Manual.pdf
Hope that helps solve your printer issues. :)
Aug 26, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 2840 Printer Logo
1,799 people viewed this question
Seeker5211
Seeker5211
