Question about Texas Instruments TI-89 Calculator
How to you turn decimal into fraction - Texas Instruments TI-89 Calculator
  • 20 Answers
Press the MATH button and use the FRAC> converter. note: this only works if the fraction is roundable to the nearest hundredth to form a normal difference. it will not work on complex numbers, variables, etc.
Posted on Apr 28, 2010
SOURCE: Changing result display from fractions to decimals
Struggled with this and found answer on about page 19 of the instructions on the Internet. Answer also appear on paper instructions under: "Displaying Calculation Results...etc just under "Note" Trick is you must have calculator in "LineIO" mode For setting MODE see "Calculation Modes & cal. Setup in paper instructions.
Posted on Sep 01, 2007
SOURCE: fractions appear when I divide; not decimals
press 'yellow key' then press 'enter' to see answers in decimal format instead of fractions
Posted on Sep 10, 2008
  • 6 Answers
SOURCE: Is answering in fractions, and I'd like decimals.
what you do is click on the 'mode' button and go down to the 'Exact/Approximate' parameter and choose Approximate. hit enter and you're good.
Posted on Sep 20, 2008
supportthe85
  • 35 Answers
SOURCE: fractions multiplied by fraction to get fraction
In the CATALOG there is a >Frac command that can be used with parentheses to multiply fractions.
(1/2)(1/3)>Frac
1/6
Posted on Nov 25, 2008
SOURCE: When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Posted on Dec 08, 2008
How do I convert decimal to fractions, and fractions to decimal with this unit?
Decimal to fraction: Type in your decimal (i.e. .5) Then press [MATH] > press [ENTER] on [>FRAC] Then press [ENTER] again Example: .5>Frac 1/2 For a fraction to decimal: Simply type in the fraction and press [ENTER] Example: 1/3 .33333333333 (*Note that the decimal value is truncated to fit the screen)
Hope that helps! Have fun calculating!
May 03, 2011 | Texas Instruments TI-84 Plus Calculator
How to turn a decimal into a fraction
To change a decimal to a fraction using the TI 30, insert your decimal number, then press [2nd][PRB].(the PRB button says F<>D above it for Fraction <> Decimal)
May 03, 2011 | Texas Instruments TI-30 XIIS Calculator
Can you convert a decimal to a fration on the fx-300MS scientific calculator? If so how?
To convert a fraction to a decimal or a decimal to fraction you use the [a b/c] key.
While converting a fraction to a decimal number is always possible, converting a decimal to a fraction may, at times, not be possible.
Sep 10, 2010 | Casio FX-300MS Calculator
How to convert fractions to decimals
To convert fractions to decimals, and decimals to fractions use the [a b/c] key. If the total number of symbols (num, denom, fraction bar) to display a fraction exceeds 10, the fraction is automatically converted to decimal format.
Jul 19, 2010 | Casio FX-300MS Calculator
How do you change decimals to fractions on a casio
If you enter an improper fraction or a mixed fraction with the the [a b/c] key it will be displayed as a fraction. This result being displayed you can press the [F-D] key to convert the fraction to decimal. If you do nothing else and you press the [F-D] key again, the original fraction will be restored.
However, it seems that you cannot enter an arbitrary decimal number and convert it to a fraction. The [F-D] key seems to work one way : from a fraction to a decimal number. You will only recover a fraction if the original number was a fraction.
Jan 19, 2010 | Casio FX-9750GPlus Calculator
How do you turn off the fraction output. I want just a decimal output
When you have a fraction output, press the [S<->D] key to convert to decimal, the same key to convert from decimal to fraction. Beware that fraction results are exact, while decimal values are approximate.
However if you cannot stand the sight of a fraction, there is a way to get rid of this type of output.
Here is how you do it.
[SHIFT][MODE][2:LineIO]. All your results will be in decimal. However you will lose a lot of functionalities, such as calculating the logarithm in any base, manipulating radicals.
My advice, if you allow, is to activate the [SHIFT][MODE][1:MathIO] and press the [S<->D] whenever you want a result (be it a fraction or radical) in decimal format.
Hope it helps.
Oct 06, 2009 | Casio FX-115ES Scientific Calculator
Cant get answers in decimal format, I would like to set up my casio fx83es so that the answer is in decimal format all the time.
To make sure that results are always in decimal format, put a decimal mark (point) at the end of one integer.
ex: 1./2 or 1/2. or 1./2. display as 0.5, so does 1. + 1/2
To convert from decimal to fraction and from fraction to decimal press a b/c
To convert from proper to improper fractions use [SHIFT][d/c]
Hope it helps.
Oct 04, 2009 | Casio fx-300ES Calculator
I need to convert decimals to fractions
Press [MATH][1:ToFrac] to convert an aswer to fraction.
If you enter 18.52[ToFrac] [ENTER gives 463/25
[MATH][2:ToDEC] converts a fraction to a decimal number.
Hope it helps.
Sep 22, 2009 | Texas Instruments TI-84 Plus Silver...
HOW TO INTER FRACTION ON A TI-83
Once you enter a fraction the calculator calculates it and displays a decimal result.So basically you cannot do fraction manipulations. However you can convert a decimal result into a fraction. To do the conversion, you enter the decimal number then you Press [MATH] and [1]. ( -->Frac) The number will be converted.
Similarly you can enter a fraction to a decimal number (-->Dec)
[MATH] [2:] [ENTER]. But I see no point in doing that, because any fraction entered is displayed as a decimal number.
Hope it helps
Sep 03, 2009 | Texas Instruments Office Equipment &...
Texas Instruments TI-89 Calculator Logo
197 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
